Mp4 1080p AV1 vs H.264.
TUF FX506HEB
15 (0.02/day)
Probably yes, but can't really tell without comparing the two videos directly. AV1 is a newer, more efficient codec, so it would make sense that it would compress more efficiently while retaining video quality.
9,672 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
I mean if you can't tell, I guess they are the same.
ir_cow
4,729 (0.79/day)
USA
Seems about right up to 50% file reduction for the same quality.
304 (0.37/day)
I noticed the bitrate was also half, it dosen't need much bitrate in AV1? I guess AV1 is only supported on newer processors? Not on 2010 Intel Xeon models?
ir_cow
4,729 (0.79/day)
USA
I noticed thebitrate was also half, it dosen't need much bitrate in AV1? I guess AV1 is only supported on newer processors?
Hardware acceleration for igpu is 7th gen and on (UHD 750). Idk about other CPUs or video cards.
21,732 (3.40/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 64GB (2x 32GB) G.Skill Flare X5 @ DDR5-6200 CL30
Case Thermaltake Core X31
AV1 is a cutting edge format, so yeah if you can play it back, it's going to do more with less.
