- Oct 9, 2007
- 47,217 (7.55/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
MSI, the world's leading manufacturer for true gaming hardware, is proudly expanding the hardware possibilities for all gamers. Formerly known as Ἄρτεμις and derived from Greek mythology. It is at the same time known as Luna (New Moon) and Goddess of Hunting. When hunting, she wore a silver bow and rode a silver cart pulled by a female deer with golden antlers. The image shows both kindness and majesty, just like the moon's surplus and deficiency.
1000R, The most suitable curvature for the human eyes. It can Perfectly fits the curvature of the human eye so that you can see the entire screen without any fatigue. The curved surface design can also enhance the sense of coverage and immersion so that you will not be disturbed by the outside environment during the game, which greatly enhances the gaming experience.
The Perfect Curve - 1000R—Perfect for Human Eye Curvature
The MSI ARTYMIS series is the most curved 1000R gaming monitor on the market. It perfectly fits the curvature of the human eye so that you can see the entire screen without any fatigue. The curved surface design can also enhance the sense of coverage and immersion so that you will not be disturbed by the outside environment during the game, which greatly enhances the gaming experience.
The curved-screen also has an advantage that is often overlooked. The left and right edges of the curved-screen can be seen at a glance and is ergonomic, which helps with the response speed of the human body.
In summary, for a player who has been in front of the computer for a long time, the 1000R Perfect Curved Monitor is one of his best choices when choosing a gaming monitor.
Console Mode—Optimized for Console Gamer
For PS5, we designed an exclusive Console Mode for the consoles, which can automatically accept 4K signals on QHD monitor, and support HDR simultaneously. This gives you the best gaming experiences and allows you to enjoy console games even with a QHD monitor.
Curved Gaming
The curved display panel of the MSI gaming monitor has a curvature rate of 1000R, which is the most comfortable and suitable curvature for human eyes for general computing to gaming. Curved panels also help with gameplay immersion, making gamers connected better to their games.
21:9 UWQHD
The MPG ARTYMIS 343CQR 21:9 ultrawide Gaming monitor is built to step your game up by giving you extra POV to enhance your peripheral vision. With a 3440x1440 resolution and a 21:9 aspect ratio, enjoy the latest AAA title games the way it was meant with gorgeous details that span across your entire peripheral view.
Rapid Boost (165 + 1 ms)
MPG ARTYMIS 343CQR is equipped with a 165Hz refresh rate and a 1ms response time panel. It will undoubtedly be beneficial to professional gamers, especially those playing fast-moving games. Games will no longer look quirky since our monitor will be able to keep up with any FPS your graphics card produces.
Adjustable Stand
The MSI Optix Gaming monitor is built to make you as comfortable as possible while gaming. Through adjustments of tilting (-5°~20°), lowering, raising (0~100 mm), swiveling (-75°~75°), you can easily change the position of the monitor for maximum ergonomics and optimum viewing experiences.
HDR 400
High Dynamic Range (HDR) display delivers better color and contrast accuracy. MPG ARTYMIS 343CQR is equipped with HDR technology that can produce images with more details, a wider range of colors, and look more similar to what is seen by the human eye when compared to traditional monitors.
Mystic Light
With MSI Mystic Light, the ARTYMIS curved Gaming monitors provide a soft ambient light that can easily be synced with any other Mystic Light enabled gaming product. Select any of the colors from the palette using your smartphone or the Mystic Light App to match your system style to your taste.
Curved Gaming
21:9 UWQHD
Adjustable Stand
HDR 400
Mystic Light
