- Nov 11, 2004
- 17,841 (2.42/day)
- Sweden
Keyboard | Corsair K70 Max |
Software | Windows 10 Pro |
MSI, a world leader in high-performance and innovative computing solutions, announced the PRO DP10 13M Business & Productivity Mini PC. This pint-sized enclosure is packed with more technology than what meets the eye. Featuring a compact chassis, powerful processor options, exclusive software, and Thunderbolt 4, the PRO DP10 13M is designed with efficiency and productivity in mind.
Powerful Ideas with Limitless Potential
PRO DP10 provides limitless potential while being less than 1.1 liters in volume. The small design helps tidy up a desk and save space, while the available robust hardware and software configurations support users in multitasking. Up to a 13th Gen Intel Core i7 processor with 12 cores and Iris Xe Graphics enables users to edit graphics and work with multiple programs faster and more seamlessly than previous generations. Furthermore, it supports up to 64 GB memory with a dual-channel design to address specific task requirements, delivering a robust and stable computing performance. In addition, the rich selection of IO ports includes one DP-out, one HDMI-out, one D-Sub (VGA), and one Thunderbolt 4, which supports up to 40Gb transfer speed and display output up to 8K resolution. The PRO DP10 can support up to four displays simultaneously, so users can view different programs in great detail.
Connect and Work with Efficiency & Security
Connect and rapidly transfer data with high-bandwidth and low-latency 2.5 Gbps Ethernet LAN or a Wi-Fi 6E that emphasizes transmission security and signal improvement. This way, it can be connected to more devices simultaneously. A reversible USB 3.2 Gen 2 Type-C helps users to conveniently back up projects or files rapidly. Additionally, TPM 2.0 helps protect sensitive data & passwords with encryption keys for advanced security. A physical Kensington lock slot is also implemented to deter theft. As a result, the PRO DP10 provides a safer environment for businesses to reduce worry about information leaks.
The exclusive MSI Cloud Center allows you to transfer your data between the PRO DP10 and your mobile phone while under the same network domain, ensuring photos and data are moved safely between devices. With one click, the MSI Cloud Center will automatically backup all of your photos & videos to a desired storage location. The MSI Cloud Center app also supports multi-file upload and download, making file backup more efficient. In conjunction with MSI Cloud Center, the included MSI Center software helps users configure CPU hardware resources to prioritize the most critical software on the system and optimize user productivity.
