msi B450M PRO-VDH MAX -- AMD Ryzen 5 3400G -- NO BIOS UPDATE
113 (0.05/day)
I would like to know if the motherboard msi B450M PRO-VDH MAX is compatible with the apu AMD Ryzen 5 3400G without the need to update the BIOS and what are the differences compared to the msi B450A-PRO MAX.
should I buy this?
Thank's
Regards
734 (0.17/day)
Malaysia
System Name Cypher-C4
Processor Ryzen 9 5900X
Motherboard MSI B450 Tomahawk Max
Cooling Deepcool AK620
Memory 32GB Crucial Ballistix Elite 3200MHz
Video Card(s) Palit RTX 3060 Ti Dual
Storage 250GB Crucial MX500 + 2TB Crucial MX500 + 2TB WD Black + 4TB Toshiba + 1TB Samsung F3
Display(s) Acer XV272UP
Case Corsair Obsidian 750D
Audio Device(s) Behringher UMC202HD Audio Interface + Mackie HM-4 + Sennheiser HD 280 Pro + Shure SM58
Power Supply Corsair HX750i
Mouse Steelseries Rival 310
Keyboard Keychron K8 + Kailh BOX Crystal Jade switches + Ducky Good in Blue keycaps
Should be compatible. Nothing that would indicate otherwise AFAIK.
3,881 (0.85/day)
should I buy this?
Thank's
Regards
You could just click "Support", "Compatibility", "CPU" and have your answer(s).
4,841 (1.53/day)
Processor Core i7-13700
Cooling Cooler Master RGB something
Memory Corsair DDR5-6000 small OC to 6200
Storage 970 EVO NVMe M.2 500GB,,WD850N 2TB
Case Phantek Eclipse P400S
Audio Device(s) EVGA NU Audio
Power Supply EVGA 850 BQ
Software Windows 11 Professional v23H2
You can also look for AMD Ryzen 3000 Desktop Ready on the box.
131542
222 (0.11/day)
System Name Temp SFF Rig :'(
Processor Q9550
Motherboard HP OEM
Cooling just about...
Memory 8GB DDR2 :rockout:
Video Card(s) Gigabyte GT 1030 LP OC to 1850+ Boost!!!
Storage 120GB SSD & 160GB HDD :(
Display(s) Acer ED242QR - 24" Curved 1080p 75Hz Freesync
Case HP SFF Desktop
Power Supply HP SFF 260w
Software Windows 10 1903
Max indicates it has a larger bios rom to support the larger agesa updates that ryzen 3000 cpu require without dropping other functionality from the uefi and in turn will be ryzen 3000 ready out of the box
AlienIsGOD
Vanguard Beta Tester
5,113 (0.86/day)
Kingston, Ontario Canada
System Name Aliens Ryzen Rig | 2nd Hand Omen
Processor Ryzen R5 5600 | Ryzen R5 3600
Motherboard Gigabyte B450 Aorus Elite (F61 BIOS) | B450 matx
Cooling DeepCool Castle EX V2 240mm AIO| stock for now
Memory 8GB X 2 DDR4 3000mhz Team Group Vulcan | 16GB DDR4
Video Card(s) Sapphire Pulse RX 5700 8GB | GTX 1650 4GB
Storage Adata XPG 8200 PRO 512GB SSD OS / 240 SSD + 2TB M.2 SSD Games / 1000 GB Data | SSD + HDD
Display(s) Acer ED273 27" VA 144hz Freesync |TCL 32" 1080P w/ HDR
Case NZXT H500 Black | HP Omen Obelisk
Audio Device(s) Onboard Realtek | Onboard Realtek
Power Supply EVGA SuperNOVA G3 650w 80+ Gold | 500w
Mouse Steelseries Rival 500 15 button mouse w/ Razor Goliathus Chroma XL mousemat | Logitech G502
Keyboard Corsair K65 Mini w/ Cherry MX brown keys | Logitech G513 Carbon w/ Romer G tactile keys
Software Windows 10 Pro | Windows 10 Pro
JadierJuan
4 (0.00/day)
Why wouldn't it? There is an m.2 slot pictured
The motherboard needs to support Nvme. In the specs of the board it doesn't say nvme. In other boards they specified that nvme are supported. Having a M.2 does not mean you will get the fast speeds if you put it a motherboard that only supports M.2 and not Nvme
222 (0.11/day)
Processor Q9550
Motherboard HP OEM
Case HP SFF Desktop
M2 is the slot type, If its wired to pcie which it is then you can use any nvme pcie 3.0 ssd and get pcie 3.0 x4 speeds
As quoted by msi, you must have missed it...
. Turbo M.2: Running at PCI-E Gen3 x4 maximizes performance for NVMe based SSDs
JadierJuan
4 (0.00/day)
I know my way around computers. Just that i did not see that. Thanks for pointing it.
Deleted member 67555
It's also very understandable even with people that know their way around computers.
Not that long ago someone lost a SATA port and asked for help on here and as it turned out he had a SATA M.2 but the model he bought was listed as NVME everywhere and alas it ended up being a revision which was only discovered after a BIOS upgrade a fresh w10 install...etc etc.
it's relatively new still and since the socket is both SATA and NVM-Express it makes your question quite reasonable.
17,112 (4.65/day)
I'm considering this mobo too. especially since oc'ing ryzen is basically dead in the water, don't really care about the top part being cooled.
JadierJuan
4 (0.00/day)
Im pretty sure a light oc is posible. Im making a R5 2600, Rx 570 8Gb, 120GIG nvme. This mobo. 1tb hdd. And 16 gb 3200 ram. 500 watt psu. I want a bigger psu but well. All for 530. With a nice case.
