Having some weird problems. Before I say more this is what I have done to this laptop so far:
1. Max upgrade for Ram from 16-32GB
2.from 512GB to 1TB NVME m2.
3. Tested deep through with few different best Thermal paste on CPU and GPU and ended up with Thermal pads from graphite on CPU and GPU. Replaced original silicon pads with much better one and added few more heatsinks, heatpipes.
4. Bought and modified Laptop cooling pad COOLER MASTER, took out original set of coolers and bought Noctuas 2x and connected all via extern adapter.
5. Tested that everything and got like 30c drop, I mean seriously tested like all new games on ultra and nightmare graphic details, played games many hours temperature without ThrottleStop max 87c. and with ThrottleStop max temp is 70c. So Doom Eternal on Ultra is 65-70c.
6. Now here comes interesting facts.....When I do video editing, processing my temp is 60c but I keep getting on ThrottleStop so many red lights that is really bothering me. When i start TS Bench I get first Red warning and after test at idle yellow warning on Core and Ring PL2 and EDP OTHER. If I start heavier tasks these two get red and often I see other warnings but the temps are 60c.....so wtf is wrong here? Also I unlocked full access to bios with following: R-CTRL+R-SHIFT+L-ALT+F2....When you enter bios with Del just press these buttons and you will unlock whole a lot of other hidden functions: R-CTRL+R-SHIFT+L-ALT+F2. So here I see I can enable ProcHot which is by default Disabled. I can control PL1 and PL2, I can manually overclock and underclock and much more but the thing is I dont want overclock I want stable 3,9GHz without throttling at 60-75c so I didn´t dare to change anything in bios. So any idea tips? Here comes Screenshoots.
