MSI GF65 THIN 10SDR i5 10300H throttlestop settings help ?
banjospiegel
2 (0.00/day)
Hey, I've recently installed throttlestop on my machine and would like some help on what to do to have the best render in terms of performance and temps :)
Thanks a lot !
here are my current settings (base EPP was 128)
(same settings for CPU Cache)
didn't change anything else :)
unclewebb
8,032 (1.33/day)
Check the MMIO Lock box in the TPL window and that is about it. Your voltage settings look correct for a 10th Gen mobile CPU. There is nothing else you can really do.
Your CPU is reaching 100°C at 52W. You can disassemble your laptop if you want to try and improve cooling. I would probably just leave your laptop as is until your cooling problem gets worse.
banjospiegel
2 (0.00/day)
well it's been like this since i got the laptop (~2 years ago) and haven't run into any problem, but i've considered switching thermal paste :) thanks !
