MSI Lifts the Lid on Their GeForce GTX 1080 Ti GAMING X Graphics Card
Raevenlord
3,755 (1.24/day)
Portugal
System Name The Ryzening
Processor AMD Ryzen 9 5900X
MSI's top of the line take on the GTX 1080 Ti - The GAMING X - has just been detailed by the company, building upon the previously-released teasers. The GAMING X features MSI's two-and-a-half slot TWIN FROZR VI dual-fan cooling solution with Torx 2.0 fans, which have the ability to completely turn off in low-load scenarios through their Zero Frozr feature. The card comes with a custom PCB, equipped with dual 8-pin power connectors and 8+2 phase design.
The GAMING X comes with three different overclocking profiles: an OC Mode, with 1569 MHz Base, 1683 MHz Boost, and 11124 MHz memory clocks; a Gaming Mode, which brings these down to 1544 MHz,1657 MHz, and 11016 MHz respectively; and a Silent Mode, which brings these even lower towards 1480 MHz Base, 1582 MHz Boost, and 11000 MHz memory. So between the highest-performance and lowest-noise modes there is a delta of 89 MHz Base, 101 MHz Boost, and 124 MHz Memory clocks. MSI will also sell a non-X version of its GAMING GTX 1080 Ti, which will come with necessarily lower clocks.
MSI GeForce GTX 1080 Ti GAMING X features:
The Ultimate GAMING: TWIN FROZR VI
  • Smooth Heat Pipes: Squared shape at bottom maximize heat transfer from the copper base plate.
  • Zero Frozr: Stopping the fan in low-load situations, keeping a noise-free environment.
  • Airflow Control: Technology Deflectors thrusts air onto heat pipes for lower temperatures and better gaming.
TORX FAN 2.0: Supremely silent
  • Dispersion fan blade: Steeper curved blade accelerating the airflow.
  • Traditional fan blade: Provides steady airflow to massive heat sink below.
  • Double ball bearing: Strong and lasting core for years of smooth gaming.Gaming App
Gaming App
  • Instant Performance Gain: Unlock extra
  • Instant Performance Gain: Unlock extra performance or keep your card silent
  • during light use in one click.
  • LED control: Full control on your RGB GAMING LEDs to set the mood.
568 (0.20/day)
System Name ACME Singularity Unit
Processor Coal-dual 9000
Motherboard Oak Plank
Cooling 4 Snow Yetis huffing and puffing in parallel
Memory Hasty Indian (I/O: 3 smoke signals per minute)
Video Card(s) Bob Ross AI module
Storage Stone Tablet 2.0
Display(s) Where are my glasses?
Case Hand sewn bull hide
Audio Device(s) On demand tribe singing
Power Supply Spin-o-Wheel-matic
Mouse Hamster original
Keyboard Chisel 1.9a (upgraded for Stone Tablet 2.0 compatibility)
Software It's all hard down here
/initiate random
If one had a GPU stand/bracket/support thing, would it make sense to remove the backplate from such heavy GPUs?
My impression is that their sole purpose is to supposedly reduce the sagging, right?
/terminate random
65 (0.02/day)
System Name Titan
Processor Intel Core i7-5820K
Motherboard ASUS X99-A
Cooling Phanteks PH-TC14PE
Memory Crucial Ballistix Sport 4x4GB DDR4-2400
Video Card(s) ASUS Strix GeForce GTX 970
Storage Crucial MX100 2x256GB & Seagate Barracuda 2x2TB
Display(s) Dell P2414H
Case Fractal Design Define R5 Titanium with Window
Power Supply EVGA SuperNOVA G2 750
Software Windows 8.1 Pro
Benchmark Scores 11613 in Firestrike
The box art shows a heat sink with a horizontal fin array. The card itself has a heat sink with a vertical fin array. :roll:
354 (0.12/day)
Indonesia
System Name Nero Mini
Processor AMD Ryzen 7 5800X 4.7GHz-4.9GHz
Motherboard Gigabyte X570i Aorus Pro Wifi
Cooling Noctua NH-D15S+3x Noctua IPPC 3K
Memory Team Dark 3800MHz CL16 2x16GB 55ns
Video Card(s) Palit RTX 2060 Super JS Shunt Mod 2130MHz/1925MHz + 2x Noctua 120mm IPPC 3K
Storage Adata XPG Gammix S50 1TB
Display(s) LG 27UD68W
Case Lian-Li TU-150
Which box are you looking at because the box pictured here you can't even see the fins
Edit: After looking from my PC and not through the app on my phone I can now see what you mean lol
105 (0.02/day)
Processor Intel Xeon E5-1650 v2
Motherboard ASUS P9X79
Video Card(s) NVIDIA GTX 1080 FE
Display(s) ASUS PG43UQ
VR HMD Valve Index
Software Windows 7
They used the 1080 box and put in a Ti on the text. :D
105 (0.02/day)
VR HMD Valve Index
Software Windows 7
The card looks amazing. Things I usually look/care for are:
* Heatsink mounted on more than 4 screws around the GPU to prevent sag.
* VRM makes contact with heatsink.
* Clean PCB with good component layout.
So this one easily passes. The massive heatsink with large diameter fans are only a great plus. I wish though they turned the fins towards the bracket 90 degrees so it at least expels some heat out the case.
rtwjunkie
PC Gaming Enthusiast
13,995 (2.34/day)
Louisiana
Processor Core i9-9900k
/initiate random
/terminate random
The #1 reason is to help support the PCB against sagging, yes.
#2: Protection from things falling onto back of PCB (could be bad).
#3: Depending on the card and manufacturer, and the design of the backplate, a backplate may assist in cooling. There are some cards that it assists in cooling VRM's. Not this card though. It's equally possible that a poorly thought out backplate could hurt cooling.
All things being said, the benefits outweigh the negatives.
14,112 (3.82/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
/initiate random
/terminate random
If you have the card mounted vertically and have adequate airflow over both sides, as in an iTx set up, or possibly with a Pci-e riser, the back plate would not be needed.
568 (0.20/day)
Thank you both and apologies for the belated reply, forgot to browse logged in the last time, lol
(Good point regarding the cooling, next time i blow the PC, i'll take the card apart again, see what/how my backplate attaches itself to. Just a few months past and i've already forgotten, lol..)
6,730 (1.39/day)
Case NZXT PHANTOM410-BK
Power Supply Corsair 850W
Mouse Logitech Hero G502 SE
