- Jan 5, 2006
- 18,584 (2.66/day)
System Name | AlderLake |
Processor | Intel i7 12700K P-Cores @ 5Ghz |
Motherboard | Gigabyte Z690 Aorus Master |
Cooling | Noctua NH-U12A 2 fans + Thermal Grizzly Kryonaut Extreme + 5 case fans |
Memory | 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 |
Video Card(s) | MSI RTX 2070 Super Gaming X Trio |
Storage | Samsung 980 Pro 1TB + 970 Evo 500GB + 850 Pro 512GB + 860 Evo 1TB x2 |
Display(s) | 23.8" Dell S2417DG 165Hz G-Sync 1440p |
Case | Be quiet! Silent Base 600 - Window |
Audio Device(s) | Panasonic SA-PMX94 / Realtek onboard + B&O speaker system / Harman Kardon Go + Play / Logitech G533 |
Power Supply | Seasonic Focus Plus Gold 750W |
Mouse | Logitech MX Anywhere 2 Laser wireless |
Keyboard | RAPOO E9270P Black 5GHz wireless |
Software | Windows 11 |
Benchmark Scores | Cinebench R23 (Single Core) 1936 @ stock Cinebench R23 (Multi Core) 23006 @ stock |
MSI is releasing its MAG FORGE 100M middle tower PC case equipped with two RGB fans and an RGB hub. The MSI “MAG” series is a new gaming mid-tower case.
At the front side you will notice two 120mm diameter RGB fans. It also has RGB control hubs for six devices, and a LED switch on the "Dragon Center", the front panel allows you to easily change the illumination.
The left side panel is a 4mm thick tempered glass suitable for dressing up inside. The cooling fan is 120mmx3 or 140mmx2 at the front, 120 / 140mmx2 at the top, and 120mmx1 at the rear (with standard fan). The water-cooling radiator supports front and top up to 240mm and rear 120mm. The drive bay is 2.5/3.5 inch, expansion slots are 7 levels, effective space at 330mm for graphics card, 160mm for CPU cooler and 200mm for power supply unit.
The body size is 210mm wide, 421mm deep, 499mm high, and weighs 5.64kg. Supported form factors are ATX, MicroATX, and Mini-ITX. I / O port is USB3.2 Gen.1 Type-Ax2, HD audio x1, microphone x1, LED switch button x1.
www.guru3d.com
![www.guru3d.com](/forums/proxy.php?image=https%3A%2F%2Fwww.guru3d.com%2Fdata%2Fpublish%2F205%2Fc69eebc1bf28857efa54e29e33aef55fdf006b%2Ffile-97eda37c5212c69192.jpg&hash=322510240d5519d5a8e22f8d56d41f8b&return_error=1)
MSI To Release MAG FORGE 100M Chassis
MSI is releasing its MAG FORGE 100M middle tower PC case equipped with two RGB fans and an RGB hub. The MSI “MAG” series is a new gaming mid-tower case....
![www.guru3d.com](/forums/proxy.php?image=https%3A%2F%2Fwww.guru3d.com%2Fdata%2Fthemes%2Ffrontend%2FGuru3D%2Fimages%2Ffavicon_64x64.png&hash=becc061da8387ff7f6d458752fc51019&return_error=1)
