MSI Nvidia GTX 750 ti twin frozr 2GB issue
Harrysdante143
2 (0.00/day)
Hi everyone, i am new here
Hey guyz I've msi gtx 750 ti twin frozr 2gb, i used to play gta v and some other high end graphics games with good performance, i didn't know that these gtx cards need good power supply too for the good performance and the power it needs. I fried my mobo with a normal frontech power supply, now i am using my pc without my gtx 750 ti, i just wanted help about it's pcie 6pin, there's no 6pin slot to plug and also I've normal power supply 500w and can i make myself a power connector for 6pin pcie with this normal power supply for gtx 750 ti
129 (0.05/day)
Don't use normal PSU, get 550W or 600W Gaming PSU. Don't try that you mentioned, it will burn out everything if you do it wrong if you do know what you doing.
Try at your own risk.
But best and safe solution is the get 550W or 600W Gaming PSU +12 = 50A is better.
1,882 (0.40/day)
Romania
What brand, is it a cheap one ?
For a normal system with 750Ti an i5(no overclocks) two HDD and 3*120mm fans even a good 350W is all you need.
What is your budget ?
259 (0.06/day)
System Name maipc
Processor 4790k @ 4.4Ghz / 1.16v
Motherboard Asus vii hero
Cooling Noctua NH-D14
Memory 16GB (2x8GB) Hyperx fury 1866 / CL10
Video Card(s) MSI RTX 3060 Ti Gaming X 8GB
Storage 1TB 860EVO + 1TB 860EVO + 4TB WD Red + 4TB WD Red
Display(s) Asus VG259QM (1080p IPS 240Hz)
Case Cooler Master Centurion 6
Power Supply Seasonic Prime GX-650
Mouse Logitech G Pro X Superlight
Keyboard Wooting 60HE
Software Win 10 64bit
This card does not come with a PCIe power connector and it's meant to be used without it.
It takes all the power it needs from the PCIe slot.
silentbogo
5,613 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
GTX750Ti does not need a power connector, even if it's factory-overclocked.
I used to have the exact same card few years ago (MSI GTX750 Ti Gaming), and at most it pulls around ~60W during heavy GPU stress tests.
Regarding PSU: all you need is a decent 300W unit, like Seasonic SSP-300SSG. It's not really expensive, but it is reliable and fully compliant w/ 80+ GOLD standard. I've replaced all of shitty PSUs at work with this or 350W model to power our workstations (many similar configurations in a range of Core i5 4th through 7th gen / 16GB RAM / SSD+HDD / GTX750Ti through GTX1050Ti).
Harrysdante143
2 (0.00/day)
Thank you so much for the reply everyone, i am going to buy 1050 ti what about it? How much watts it needs? And is it better than 750 ti and 960?
43,494 (6.76/day)
You can find that info on nvidias website
8,100 (1.34/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
