MSI or Asus onboard Sound better?
984 (0.53/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Altec Lansing
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
Hello,
I'm not professional but always consider myself as an audiophile. Therefore when I buy a laptop or desktop, the onboard audio quality and software support is always taken into consideration. So if we look at the two big rivals, Asus and MSI, which one sounds better? Has anyone here experienced and try one of these?
MSI
Nahimic 3 + Audio Boost 5
Realtek ALC4082 + ESS Sabre9018 DAC
Asus
DTS X Ultra + Asus Supreme FX
Asus exclusive S1220A +ESS Sabre9018 DAC
13,664 (2.02/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
The one with the better speakers.
That said, if you consider yourself an audiophile (as I do) does it really matter? I mean no computer speaker will ever come close to my living room system where just one of the front speakers costs way more than an entire laptop or PC computer's surround sound system. And of course, my living room speaker still needs an entire amplifier system not included in the price of the speaker.
2,373 (0.57/day)
Audio Device(s) A LOT
An external DAC is the only answer
2,318 (0.39/day)
Texas
System Name Mr. Reliable
Processor Ryzen R7 7800X3D
Motherboard MSI X670E Carbon Wifi
Cooling D5 Pump, Singularity Top/Res, 2x360mm EK P rads, EK Magnitude/Bitspower Blocks
Memory 32Gb (2x16Gb) GSkill Trident Z5 DDR5 6000 Cl30
Video Card(s) Asus Tuf 4080 Super
Storage 4 x Crucial P5 1TB; 2 x Samsung 870 2TB
Display(s) Acer 32" Z321QU 2560x1440; LG 34GP83A-B 34" 3440x1440
Case Lian Li PC-011 Dynamic XL; Synology DS218j w/ 2 x 2TB WD Red
Audio Device(s) SteelSeries Arctis Pro+
Power Supply EVGA SuperNova 850G3
Mouse Razer Basilisk V2
Keyboard Das Keyboard 6; Razer Orbweaver Chroma
I just switched from an Asus X570 Crosshair VIII Hero Wifi to an MSI X570S MEG Ace Max and the onboard sound is head and shoulders above the Asus. Granted, I do my gaming on headphones with a DAC, so can't really speak to that, but the media experience is substantially better on my speakers with the MSI.
I must also admit I thought the Nahimic thing was pretty gimmicky, but it has impressed me upon hearing it.
Just my two cents for what it's worth.
JAT
2,998 (2.04/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
43,546 (6.77/day)
984 (0.53/day)
Turkey
System Name MSI-MEG
Memory 32 GB
JAT
We use the exact same motherboard! I love the audio quality for sure, but the basses seems weak to me. What do you think for bass and is there any preset to overcome the bass problem?
Thank you for your explanation. That means everything comes down to money
There's no end in the audio world like many other things..
456 (0.41/day)
every onboard audio solution is crap.
buy a cheap USB DAC (the sharkoon Gaming DAC Pro S costs ~30 bucks and is insanely good)
Sharkoon Gaming DAC Pro S review: Surprisingly cheap USB sound solution with real headphone amplifier as an insider tip for connoisseurs | igor'sLAB (igorslab.de)
Hey, are there any drivers for this or is it just plug and play with my Realtek drivers?
Also, any headphone extension cables you recommend? My headphone's cable is a bit too short to reach the back of the PC and I don't wanna plug in the DAC to the front panel. Preferrably one that supports a mic + audio combo, no splitters.
Deleted member 202104
It's plug and play - it actually will act as a second sound device so Realtek won't be a part of it.
As for the cable:
456 (0.41/day)
456 (0.41/day)
Here's hoping I don't regret it like I did with Creative.
2,998 (2.04/day)
Germany
Yes Plug and Play and i recommend to just disabled onboard audio like weekendgeek just said.
i used to have a soundblaster XG6 and it broke after a year. replaced it with the Gaming DAC and it sounds basically identical.
still using it for every audio device i have (Bose companion speakers, Sennheiser/HyperX and Sony Headphones)
especially in teamspeak where my Sennheiser GSP600 sounds over onboard like a walkie talkie and superb with this thing.
456 (0.41/day)
I have HyperX Cloud Alphas, I hope it'll make some sort of difference and that I don't need expensive audiophile grade headphones to notice a difference
Deleted member 24505
I'm using a Cambridge audio Dacmagic 100 from my rear USB C lovely.
My board has onboard USB ALC4080
456 (0.41/day)
Update: got it today. Disabled Onboard audio in the BIOS, rebooted, plugged it in, and it just worked. And it sounds amazing. Both for my microphone and for my sound quality be it music or games. I'm in love.
Thanks for the recommendations, this thing is already much better than Creative's sound card. Set it to 96 KHz and detected properly.
Like I legitimately just plugged it in and boom:
Goodbye Realtek!
Thank you @GerKNG and @weekendgeek for your recommendations, both the cable and DAC are working perfectly and the audio is crispy clean even on my microphone, no more crackling.
Would definitely recommend this to anyone with onboard audio.
9,733 (3.46/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
That is actually no longer true the 1220 codec is really good. I tried a Asus Xonar AE card vs the 1220 adn the 1220 was louder and crisper than that. I must say I was truly impressed. Knock on Wood but the on board audio chip dying prematurely also seems to be resolved.
I have that board too and I also find the bass aw little bit weak but the mids are stellar
9,733 (3.46/day)
Cooling In Win SR36
My board has the 1220 yet the Sharkoon delivers better quality sound and much better microphone quality
Interesting. I have one of those external DACs I might try it and see what happens. Thanks
an external dac is better than onboard, my board has alc4080 but using the DAC
9,340 (5.13/day)
Louisiana
Keyboard G710+x3
I don't mind supremeFX as long as realtek equalizer works which on win-11 is dead, ms removed it during upgrade from 10
Not sure if it went store only app or what, 11 driver dictator at work.
Might add asus drops bios support after three years
Msi is 5 years I believe so this might make a difference in mobo choice.
984 (0.53/day)
Turkey
System Name MSI-MEG
Memory 32 GB
JAT
That is the exact answer I was looking for. I was not sure if I did correct decision by choosing MSI. Thank you!
9,340 (5.13/day)
Louisiana
Keyboard G710+x3
One issue with msi is they were caugh red handed scalping their own gpu's during the mining craze.
Think asrock is rated better.
2,998 (2.04/day)
Germany
i am glad that you like it :)
196 (0.03/day)
Mexico
System Name HTPC
Processor AMD Ryzen 7 5800X
Cooling BeQuiet Dark Rock Pro 4
Memory Kingston Fury Renegade RGB 32GB Kit (2x16GB) 3600Mhz DDR4 CL16
Video Card(s) Sapphire NITRO+ RX 5700 XT
Storage Acer Predator GM7000 4TB / WD Blue SN570 1TB / TOSHIBA HDWD130 3TB
Display(s) LG Oled 42C3
Case Lian Li O11 Air Mini
Audio Device(s) Creative Labs Sound BlasterX G6
Power Supply EVGA SuperNOVA 850 P2
Mouse Logitech G900
Keyboard SteelSeries Apex Pro
Software Microsoft Windows 11 Pro
Just gonna leave this here so all of u know
