- Oct 9, 2007
- 47,024 (7.60/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
At a press event held in Japan, MSI showed off its second non-reference design Radeon R9 290X graphics card besides the R9 290X Lightning, the R9 290X TwinFrozr 4S Gaming OC. The card features MSI's top-grade TwinFrozr IV cooling solution with the red+black color scheme; and a non-reference design PCB by MSI. Its PCB will feature a strong VRM, a voltage controller that's fully accessible using Afterburner, factory-overclocked speeds, and a back-plate decking up the rear portion of the card, even though there's nothing on the rear side of the PCB that requires active cooling. Since the card features a BIOS-toggle switch, you can expect one of the two BIOS ROMs to feature a failsafe BIOS with reference clock speeds. MSI is expected to launch the card a little later this month. The R9 290X Lightning, however, can't be expected before 2014. One could expect a similar-looking card (perhaps minus the back-plate) based on the R9 290 (non-X).
