MSI RX 5700 Mech OC vBIOS Flash Help "mismatched subsystem ID's
TheBrokenBeast
9 (0.00/day)
Is there a matching 5700xt BIOS? When I attempt to flash the "matching" MSI RX 5700 MECH OC BIOS(i.e. MSI RX 5700XT MECH OC BIOS) to my card, I get an error saying that the "subsystemID's mismatched." Can force flash it or is there simply no compatable BIOS for this card variant and I should stick to soft power-play tables to adjust the software limitations of the non XT 5700?
Graphics Card Manufacturer - Powered by AMD
Graphics Chipset - AMD Radeon RX 5700
Device ID - 731F
Vendor ID - 1002
SubSystem ID - 3811
SubSystem Vendor ID - 1462
Revision ID - C4
Bus Type - PCI Express 4.0
Current Bus Settings - PCI Express 3.0 x16
BIOS Version - 017.001.000.049
BIOS Part Number - Not Available
BIOS Date - 2019/08/05 07:30
Memory Size - 8176 MB
Memory Type - GDDR6
Memory Clock - 875 MHz
Core Clock - 1675 MHz
Total Memory Bandwidth - 448 GByte/s
Memory Bit Rate - 14.00 Gbps
2D Driver File Path - /REGISTRY/MACHINE/SYSTEM/CurrentControlSet/Control/Class/{4d36e968-e325-11ce-bfc1-08002be10318}/0000
OpenGL® API Version - 4.6
OpenCL™ API Version - 2.0
43,797 (6.79/day)
What are you trying to do exactly?
Give me a GPU-Z screenshot and a card back white sticker picture please
Device ID - 731F
Vendor ID - 1002
SubSystem ID - 3811
Revision ID - C4
Memory Type - GDDR6
TheBrokenBeast
9 (0.00/day)
I am attempting to flash my MSI RX 5700 MECH OC to the MSI RX 5700XT MECH OC BIOS. The non-XT models have software limitations imposed onto them even though the two cards are very similar in regards to hardware specs. The problem I am running into is that my SSID is 3811 and I cannot find a bios that matches. The XT model of my card has a SSID of 3810. So, when I try to flash the bios using atiflash I receive an error saying that the SSID's don't match and the flash is aborted/fails.
GPU-Z: http://gpuz.techpowerup.com/19/11/25/4q3.png
Trying to use this BIOS: https://www.techpowerup.com/vgabios/213797/msi-rx5700xt-8192-190805
43,797 (6.79/day)
Give me a bit to research that card
43,797 (6.79/day)
TheBrokenBeast
9 (0.00/day)
I doubt that card has a dual bios switch.
What are your complete system specs?
I don't believe it does. I went looking for one to no avail
Ryzen 5 2600 @ 4.1 GHz
H100i V2
Corsair LPX DDR4 @ 2933 MHz
MSI B450M Gaming Plus Micro ATX
Samsung 850 Evo 250 GB SSD
Corsair CX600M PSU
MSI RX 5700 MECH OC
WIN 10 PRO
Tatty_Two
Gone Fishing
25,975 (3.72/day)
Worcestershire, UK
Software Win 11 Home x64
Maybe try the recommended MSI XT Bios listed and linked in our guide here...….
TheBrokenBeast
9 (0.00/day)
None have the correct SubSystem ID - 3811. I can match the SubSystem Vendor ID - 1462 being that that relates to MSI it appears. So, when I try to flash the bios using atiflash in GUI I receive an error saying that the SSID's don't match and the flash is aborted/fails. I can, it seems, force the flash using the command system to bypass the SSID check but I am not sure that won't effectively brick my GPU. When I use your tool, VGA BIOS Collection, it shows only my card when I search for compatibility.
43,797 (6.79/day)
H100i V2
Corsair CX600M PSU
MSI RX 5700 MECH OC
WIN 10 PRO
Do you have an old back up card available?
I hope you do because even switching subsystem ids can cause trouble
Tatty_Two
Gone Fishing
25,975 (3.72/day)
Worcestershire, UK
I can only find one other MSI XT Bios even in the unverified uploads which is for the Evoke here...…………….
I agree with @eidairaman1, with only a single Bios a forced flash with non matching ID's is risky.
TheBrokenBeast
9 (0.00/day)
Thank you everyone for your help. I'll stick to playing with the soft power play tables for now then. But one question before I go, what is the subsystem ID referencing exactly?
2,012 (0.35/day)
Heart of Eutopia!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
43,797 (6.79/day)
The specific card and its config along with company info.
I would only flash a non dual bios card if i had an igp or spare working gpu.
And know how to enter the correct syntax for bios flashing in a command prompt
TheBrokenBeast
9 (0.00/day)
43,797 (6.79/day)
Ironically, that is where I was going next.
This card is non dual BIOS. Out of curiosity how does a spare card help? Simply to go back to while I try to RMA a card that has a bricked BIOS lol
Also, IGP?
The spare card allows you to reflash a bricked card when they are both installed.
IGP is integrated graphics processor. Your R5 2600 doesnt have one only the 2400G does etc.
All solutions are to recover a card you bricked.
TheBrokenBeast
9 (0.00/day)
LOL fair. Alright, no BIOS flash for this card then. I'll stick the SPPT's. THANK YOU!
Hacktacular
7 (0.00/day)
Have there been any updates on this? I have the same card and would like to flash it.
TheBrokenBeast
9 (0.00/day)
I did not manage to get any further with flashing the card. Playing in the SPPT's worked well enough. However, my card developed a problem in which after the fan would ramp up, it would only decrease speed at about 2-3% every few seconds. Quite annoying after closing a taxing game. Ended up returning the card. Good luck
Hacktacular
7 (0.00/day)
Thanks. I am trying that now but it seems to be crashing the card.
Ok I was able to flash the card using the command line. I tool a chance and it worked. So far though I don't seem to be able to push the card much without it crashing.
What is the preferred tool to overclock these 5700's? It seems the AMD Radeon software keeps crashing. I am getting 1999 @1200mv but if I try to push it much further it crashes.
Any tips or advice?
43,797 (6.79/day)
Thats MSI for you. If anything I would of Gone Asus, Sapphire, AsRock, Powercolor, XFX, maybe Gigabyte...
Any tips or advice?
You hit the top. Be content you got anything for free from it.
6 (0.00/day)
Hi there,
I have the 5700 non XT version, I would like to try the bios flash so what would the command for admin prompt be?
i have a spare gpu + onboard to flash stock
Hacktacular
7 (0.00/day)
Run CMD as admin from the amd flash folder. Be sure your bios is backed up first. Then I just ran the following commands.
amdvbflashWin.exe - unlockrom 0
Wait for prompt. You should see a pop-up confirming unlock.
amdvbflashWin.exe - f - p 0 examplebios.rom
You will see a progress box and get confirmation as well.
Credits:
SerpentSFX YouTube
Also the folks in this link.
43,797 (6.79/day)
Hi there,
You need a specific bios, get a gpu-z screenshot and white sticker pic from card back
