MSI Twin Frozr 7 - replacing thermal paste/pads?
78 (0.02/day)
Ukraine
Processor Ryzen 7 7700X
Motherboard Asus ROG Strix X670E-F Gaming WiFi
Memory F5-6000J3038F16GX2-FX5
Hello everyone, I've got a problem - my GTX 1660 Ti is running really hot when playing CS:GO ( ! ), just look at the "GPU Hot Spot Temperature" sensor readings:
And since its warranty is almost expired, I'm scared of the GPU going to hell too soon and me being forced to hugely overpay for another GPU of the same performance (or worse!) but costing like 200+% of what I spent on this one almost 3 years ago, it would be a huge waste!
Sending it to the local shop that sold it to me would mean having no PC to use for a month and it's pointless anyway - they will most likely just blow the dust off the radiator and apply some garbage thermal paste which will fix pretty much nothing.
I mean, I'm planning to wait for the warrantly expiration and just take off the cooler and clean it and replace thermal paste and if there's any thermal pads there - replace them all too. Don't know if there's any though.
But how to do that right?
Will Arctic MX-4 (2019) do its job well enough or should I buy some other paste (don't want liquid metal)?
What thermal pads to buy and how many of them? There's only these sold in here that got 12W/mK (GP-Extreme) and 15W/mK (GP-Ultimate) thermal conductivity:
GELID Solutions GP-Extreme 80x40x0.5 mm (TP-GP01-A)
GELID Solutions GP-Extreme 80x40x1.0 mm (TP-GP01-B)
GELID Solutions GP-Extreme 80x40x1.5 mm (TP-GP01-C)
GELID Solutions GP-Extreme 80x40x2.0 mm (TP-GP01-D)
GELID Solutions GP-Extreme 80x40x3.0 mm (TP-GP01-E)
GELID Solutions GP-Extreme 120x20x0.5 mm (TP-GP05-A)
GELID Solutions GP-Extreme 120x20x1.0 mm (TP-GP05-B)
GELID Solutions GP-Extreme 120x20x1.5 mm (TP-GP05-C)
GELID Solutions GP-Ultimate 90x50x0.5mm (TP-GP04-A)
GELID Solutions GP-Ultimate 90x50x0.5mm (TP-VP04-A)
GELID Solutions GP-Ultimate 90x50x1.0mm (TP-GP04-B)
GELID Solutions GP-Ultimate 90x50x1.5mm (TP-GP04-C)
GELID Solutions GP-Ultimate 90x50x2.0mm (TP-GP04-D)
GELID Solutions GP-Ultimate 90x50x3.0mm (TP-GP04-E)
GELID Solutions GP-Ultimate 120x20x0.5mm (TP-GP04-R-A)
GELID Solutions GP-Ultimate 120x20x0.5mm (TP-VP04-R-A)
GELID Solutions GP-Ultimate 120x20x1.0mm (TP-GP04-R-B)
GELID Solutions GP-Ultimate 120x20x1.5mm (TP-GP04-R-C)
GELID Solutions GP-Ultimate 120x20x2.0mm (TP-GP04-R-D)
GELID Solutions GP-Ultimate 120x20x3.0mm (TP-GP04-R-E)
569 (0.37/day)
Florida
Processor 5800x3d
Motherboard MSI Tomahawk x570
Cooling Thermalright
Memory 32 gb 3200mhz E die
Video Card(s) 3080
Storage 2tb nvme
Display(s) 165hz 1440p
Case Fractal Define R5
Power Supply Toughpower 850 platium
Mouse HyperX Hyperfire Pulse
Keyboard EVGA Z15
That's hotspot temp and completely normal. You don't have to open it up and change the thermal pads. Just clean out the dust with some compressed air.
2,225 (1.06/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. i7 7700k @5. 3. i7 7700hq
Motherboard 1.aorus x570 ultra 2. z270 Maximus IX Hero,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.hyperxfury 32gb @3000 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 500gb , 2 3tb HDs 2. 256gb ssd, 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. some cheapo case that should not be named.
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847 2. 1106 cb 3.cb 970
agreed, id worry if it was over 110-15, i think the max temp is 120c for the hotspot and you still have some headroom bud.
1,509 (1.79/day)
G-City, UK
System Name My 2nd new build
Processor Ryzen 7 7800X3D
Cooling Thermalright Peerless Assassin 120 ARGB
Memory G-Skill Trident Z Neo RGB 6000 CL30 32GB
Video Card(s) Powercolor 7900 GRE Red Devil
Storage Samsung 870 QVO 1TB x 2, Lexar 256 GB, TeamGroup MP44L 2TB, Crucial T700 1TB
Display(s) 32" LG GN600-B
Case Montech 903 MAX AIR
Audio Device(s) Corsair void wireless/Razer Kraken
Mouse Glorious Model D l Pad GameSir G7 SE
Keyboard Redragon Vara K551P
Benchmark Scores Lets get my GPU working first...
MX4 works fine mate.
4,495 (0.83/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
No need to do anything. Temps are fine. No need to replay to all posts. You have aired your lack off knowledge plenty of times. Blocked.
1,509 (1.79/day)
G-City, UK
Well, I was simply saying MX4 was fine. Bye lol!
Low quality post by mstenholm
4,495 (0.83/day)
Denmark
And that some memory didn’t work with AMD. Your are clever, you proved that already.
95Viper
Super Moderator
12,826 (2.21/day)
Stay on topic.
Take your petty bickering to PMs and stop trashing threads.
41,095 (6.56/day)
With the way mx4 is made, its meant for IHS application (not direct touch dies) mX 5 was supposed to be for direct touch dies.
I know AS5/Ceramique, and I believe Kryonaut work on dies, in close tolerance (.0001-.0020") outside of that Id suggest a Thermalpad from ThermalRight, Akasa.
1,509 (1.79/day)
G-City, UK
Wasn't aware of that. Think I'll stop answering questions.
78 (0.02/day)
Ukraine
I guess I'll try that one when the time comes.
Not sold here so I'll probably end up with some GELID Solutions GP-Ultimate, looks like the size I need must be 120x20mm, but:
1) What thickness? 0.5, 1, 1.5, 2, 3mm?
2) How many of them?
1,869 (1.53/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
Hello
In order to change those thermal pads you need to open the card.
Since you will do it anyway, it is the best moment to measure the thickness of those pads.
Use a tool to do that.
After that you will choose the exact match for your card.(For your info it could be more than one thickness on a video card)
Gelid is a good choice, so yeah go for it.
1,509 (1.79/day)
G-City, UK
I used MX4 on my GPU when repasting and it's doing alright. Not doubting you or anything but it is safe isn't it? Or I'll get some Kryonaut and re-do it.
41 (0.02/day)
I had same garbage, I repasted and temps dropped from 100C to 70C. Just repaste and don't listen to peasants who say it's "normal"
Also don't touch Thermal Pads, Just use the same ones
569 (0.37/day)
Florida
Processor 5800x3d
Video Card(s) 3080
Storage 2tb nvme
Keyboard EVGA Z15
lol ok, he's talking about switching thermal pads for hotspot temp that's why we're saying its normal. repasting is totally different. 95 hotspot is normal though, especially with low fan speed which gaming x is known for.
1,869 (1.53/day)
Romania
I used on my cards MX4. Trust me it worth the money.
78 (0.02/day)
Ukraine
No, I also said about repasting it:
And who said the hot spot sensor is somewhere within the part covered with thermal paste? I mean, it's just one of the sensors that reports the highest temperature, it can be anywhere, so reapplying thermal paste may not help, may be it's a part covered by a thermal pad that gets hottest?
2,225 (1.06/day)
south wales uk
hotspot is measured from a network of thermal sensors across the GPU die, its about 10c to 15c higher than the die sensor so if the gpu is saying the card is at 80c the hotspot will read between 90c to 95c which is well within the range of normal, I'm not saying don't repaste i do mine once a year when i change the water in my loops if its need it or not I'm just saying its normal.
569 (0.37/day)
Florida
Processor 5800x3d
Video Card(s) 3080
Storage 2tb nvme
Keyboard EVGA Z15
95 for hotspot is not terrible and pads are for memory or vrm not part of the chip. I stand by what i said theres no need to change pads for hotspot temp but if you want to repaste it could help the hotspot temp i dont deny that. But have you tried anything like fan tuning or undervolting or cleaning with air? Things that are alot cheaper than replacing all the thermal pads for some expensive pads that may or may not shave afew deg off. And we are talking a 1660 ti so not some power hungry 3090 or something. I wouldnt change pads on that but its up to you.
78 (0.02/day)
Ukraine
Cleaned off its factory thermal paste and applied MX-5. Hotspot temps (while playing CS:GO) dropped from 95-96°C to 78-79°C.
I'm glad I did it, to lose a GPU now when the prices are like 200-300% higher than they should've been would be a huge huge bummer.
Thermal pads were additionally covered with some metal plate or whatever with like more than 10 screws and I was too lazy to unscrew them all so I just left them alone.
P.S. MX-5 might be better for "direct touch" but MX-4 seems to be better for CPU. The "CPU CCD1 (Tdie)" sensor reported 65.5°C max with MX-4 and 68.3°C max with MX-5 while performing 3DMark CPU test.
931 (0.56/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Altec Lansing
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
I have the MSI gaming x 1660 GPU. While temps were not very high during gaming (70 c), the fans used to spin like crazy. So I did re-apply the paste using mx4, and it has been working silent ever since.
