MSI Typos Hint at 24GB Variant of RTX 5080
47,587 (7.45/day)
MSI made at least two typos and corrections spaced apart from each other that hint at the possibility of a 24 GB variant of the NVIDIA GeForce RTX 5080. The first instance was on the side of the retail box of an RTX 5080 Vanguard OC Launch Edition, which had "24 GB GDDR7" printed on top of the RTX 5080 label. The second instance was in the VGA Support list in the product page of the MAG X870 Tomahawk motherboard, where the memory size is displayed as 24,576 MB (24 GB). There are two possible interpretations of this.
One possibility is that NVIDIA originally planned the RTX 5080 to feature 24 GB of memory, using 3 GB (24 Gbit) GDDR7 memory chips across the 256-bit wide memory bus of the "GB203" silicon, and initially communicated this to its board partners, but revised the specs in the months leading up to the launch, with the card ending up with 16 GB (8x 16 Gbit). The other possibility is that there is actually a 24 GB variant in the works, which NVIDIA could end up calling the "RTX 5080 24 GB." The RTX 5080 in the market already maxes out the "GB203" silicon it's based on, so the variant could just offer a 50% increase in memory size at the same or similar memory bandwidth. The additional memory could come in handy with 4K Ultra HD + ray tracing + DLSS 4 MFG scenarios where a gamer is looking to turn their roughly 60 FPS framerates to match the 120 Hz refresh rates of their displays.
Then there's SUPER. NVIDIA possibly decided against 24 GB so it could launch such a card as the "RTX 5080 SUPER" without having to tap into the larger "GB202" chip. Since it already maxed out the "GB202," the RTX 5080 SUPER could come with 24 GB, possibly higher memory speeds, such as 32 Gbps, and higher GPU clock speeds. NVIDIA could offer up the SKU at a price-point similar to that of the current RTX 5080—$999. This would probably prove difficult to do with the coaster-sized "GB202."
250 (0.04/day)
Processor AMD R5 7600X
Motherboard Asrock X670E Pro RS
Cooling Noctua NH-15S
Memory 2*16 GB 5600 CL34
Video Card(s) XFX 6800XT 319 Merc
Storage Samsung 970 Evo
Power Supply Super Flower 850 Gold
Mouse Steelseries 310
The 3GB dies run at 36 and 42 GT, so regardless of vendor they should also come with a bandwidth bump
133 (0.20/day)
System Name EnvyPC
Processor Ryzen 7 7800X3D
Motherboard Asus ROG Strix B650E-I Gaming WiFi
Cooling Thermalright Peerless Assassin 120 White / be quiet! Silent Wings Pro 4 120mm (x2), 140mm (x3)
Memory 64GB Klevv Cras V RGB White DDR5-6000 (Hynix A) 30-36-36-76 1.35v
Video Card(s) MSI GeForce RTX 4080 16GB Gaming X Trio White Edition
Storage SK Hynix Platinum P41 2TB NVME
Display(s) HP Omen 4K 144Hz
Case Lian Li Dan Case A3 White
Audio Device(s) Creative Sound BlasterX G6
Mouse Logitech G600 White
If this really is the 5080 "Super" it would HAVE to hit the $999 price point to move the needle at all. At current 5080 prices, this would be almost a 4090 for almost the same price over 3 years later. :shadedshu:
680 (0.41/day)
Greece
System Name Office / HP Prodesk 490 G3 MT (ex-office)
Processor Intel 13700 (90° limit) / Intel i7-6700
Motherboard Asus TUF Gaming H770 Pro / HP 805F H170
Cooling Noctua NH-U14S / Stock
Memory G. Skill Trident XMP 2x16gb DDR5 6400MHz cl32 / Samsung 2x8gb 2133MHz DDR4
Video Card(s) Asus RTX 3060 Ti Dual OC GDDR6X / Zotac GTX 1650 GDDR6 OC
Storage Samsung 2tb 980 PRO MZ / Samsung SSD 1TB 860 EVO + WD blue HDD 1TB (WD10EZEX)
Display(s) Eizo FlexScan EV2455 - 1920x1200 / Panasonic TX-32LS490E 32'' LED 1920x1080
Case Nanoxia Deep Silence 8 Pro / HP microtower
Audio Device(s) On board
Power Supply Seasonic Prime PX750 / OEM 300W bronze
Mouse MS cheap wired / Logitech cheap wired m90
Keyboard MS cheap wired / HP cheap wired
Software W11 / W7 Pro ->10 Pro
MSI insist on this, could be a hint instead of a typo. But a 5080 super with the same chip and only memory quantity and bandwidth increase won't be a big upgrade (again).
6,978 (1.41/day)
Case NZXT PHANTOM410-BK
Power Supply Corsair 850W
Mouse Logitech Hero G502 SE
If there is another Super and Ti in the works, then there is absolutely no reason at all buying the current overscalped RTX 5080. NONE!
2,397 (1.16/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
Then when the 5080 super releases it will be faster by 5fps and achieves 200+fps with frame gen and price will be the same
1,669 (1.04/day)
Tel Fyr
System Name 1️Purple Haze 2️Vacuum Box
Processor 1️AMD Ryzen 7 5800X3D (-30 CO) 2️Intel Xeon E3-1241 v3
Motherboard 1️MSI B450 Tomahawk Max 2️Gigabyte GA-Z87X-UD5H
Cooling 1️Dark Rock 4 Pro, P14, P12, T30 case fans 2️212 Evo & P12 PWM PST x2, Arctic P14 & P12 case fans
Memory 1️32GB Ballistix (Micron E 19nm) CL16 @3733MHz 2️32GB HyperX Beast 2400MHz (XMP)
Video Card(s) 1️6900XTXH ASRock OC Formula LM'd & Phanteks T30x3 2️5700XT Sapphire Nitro+ LM'd & Arctic P12x2
Storage 1️ADATA SX8200 Pro 1TB, Toshiba P300 3TB x2 2️Kingston A400 120GB, Fanxiang S500 Pro 256GB
Case 1️Modded MS Industrial Titan II Pro RGB 2️Heavily Modded Cooler Master Q500L
Power Supply 1️Rosewill Capstone 1000M 2️Enermax Revolution X't 730W (both with P14 fans)
This is for the LLM sake, nothing else.
167 (0.30/day)
Finland
System Name RayneOSX
Processor Ryzen 9 5900x 185w
Motherboard Asus Strix x570-E
Cooling EKWB AIO 360 RGB (9 ekwb vardar RGB fans)
Memory Gskill Trident Z neo CL18 3600mhz 64GB
Video Card(s) MSI RTX 3080 Gaming Z Trio 10G LHR
Storage Wayy too many to list here
Display(s) Samsung Odyssey G5 1440p 144hz 27 x2 / Samsung Odyssey CRG5 1080p 144hz 24
Case LianLi 011D white w/ Vertical GPU
Audio Device(s) Sound Blaster Z / Swisssonic Audio 2
Power Supply Corsair RM1000x (2021)
Mouse Logitech G502 Hyperion Fury
Keyboard Ducky One 2 mini Cherry MX silent Nordic
VR HMD Quest 2
Software Win10 Pro / Ubuntu 20.04
Benchmark Scores Timespy 17 219 https://www.3dmark.com/spy/49036100 PERKELE!
Well well well a worthy rumour of myself. Now we shall see it's simply a rumour or not.
234 (0.15/day)
This could work out quite well for nvidia, give it a price bump and have dies that are more profitable to sell than the larger die needed for 5090's. While offering the ml crowd a less bad deal in the process.
bug
14,273 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
I imagine multiple versions of any SKU are evaluated (some of them even built) to figure out ROI, bottlenecks and such.
994 (0.62/day)
System Name 1. Glasshouse 2. Odin OneEye
Processor 1. Ryzen 9 5900X (manual PBO) 2. Ryzen 9 7900X
Motherboard 1. MSI x570 Tomahawk wifi 2. Gigabyte Aorus Extreme 670E
Cooling 1. Noctua NH D15 Chromax Black 2. Custom Loop 3x360mm (60mm) rads & T30 fans/Aquacomputer NEXT w/b
Memory 1. G Skill Neo 16GBx4 (3600MHz 16/16/16/36) 2. Kingston Fury 16GBx2 DDR5 CL36
Video Card(s) 1. Asus Strix Vega 64 2. Powercolor Liquid Devil 7900XTX
Storage 1. Corsair Force MP600 (1TB) & Sabrent Rocket 4 (2TB) 2. Kingston 3000 (1TB) and Hynix p41 (2TB)
Display(s) 1. Samsung U28E590 10bit 4K@60Hz 2. LG C2 42 inch 10bit 4K@120Hz
Case 1. Corsair Crystal 570X White 2. Cooler Master HAF 700 EVO
Audio Device(s) 1. Creative Speakers 2. Built in LG monitor speakers
Power Supply 1. Corsair RM850x 2. Superflower Titanium 1600W
Mouse 1. Microsoft IntelliMouse Pro (grey) 2. Microsoft IntelliMouse Pro (black)
Keyboard Leopold High End Mechanical
Another overpriced, unavailable card. Yippee.
475 (0.18/day)
Motherboard MSI B550 Tomahawk
Cooling Noctua U12S
Memory 32GB @ 3600 CL18
Video Card(s) AMD 6800XT
Storage WD Black SN850(1TB), WD Black NVMe 2018(500GB), WD Blue SATA(2TB)
Display(s) Samsung Odyssey G9
Case Be Quiet! Silent Base 802
Power Supply Seasonic PRIME-GX-1000
A 24GB 5080 Super/Ti makes sense if there are enough 5090's that can't be a 5090. Might as well do something useful with those dies, though I see it more likely that they'll be turned into workstation cards rather than retail cards, unless they have an absolutely huge amount of bad 5090's.
There's no real need for a 5080 Super similar to the previous generation 4080 Super(~1% better performance), lower MSRP, as they have no competition at that performance level this time around.
32 (0.30/day)
Finally! :respect: They finally showed the true version of the RTX 5070. Because the results of the RTX 5080 correspond to what the RTX 5070 should present. 10% increase is rather a joke on gamers and consumers -
Nobody can take the results of the 5080 seriously:kookoo:. The RTX 5080 should catch up or overtake the RTX 4090 - especially if such a tiny card cost 1000$ MSRP and in reality it is 1200$ and more.
4,389 (1.10/day)
Texas
Mouse Logitech G5
Keyboard Logitech G19S
I would more bet this is going to be the RTX 5080ti (unless they rename it, but still same premise). I doubt they are just going to release an RTX 5080 with more memory.
801 (1.15/day)
Brazil
Processor 5950x
Motherboard B550 ProArt
Cooling Fuma 2
Memory 4x32GB 3200MHz Corsair LPX
Video Card(s) 2x RTX 3090
Display(s) LG 42" C2 4k OLED
Power Supply XPG Core Reactor 850W
Software I use Arch btw
You seem to be assuming they would make a 5080Super/Ti based on the GB202 from the 5090, but the talks from the OP are more about using the existing GB203 with the exact core counts of the current 5080, but with bigger and faster memory modules.
300 (0.51/day)
5080 24GB was the initial plan most likely, but they couldn't get the 3GB dies ready because they rushed to get it out before tariffs
92 (0.04/day)
Larvik, Norway
RTX 5080 24GB is very real AFAIK. Nvidia calls it RTX 5090 Mobile. Granted, the 5090 Mobile has 2% less SU´/SM´s.
Taking flawed 5080 dies, massive down clock voila, RTX 5090 Mobile.. The 4070 performance is irrelevant. If they say its a 5090, its a 5090.
5080 Super is probably going to be the 24GB version with 10% higher clocks and 15-20% higher TDP.
Ruru
S.T.A.R.S.
13,627 (3.03/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
I doubt that there will be a Super or Ti since the 5080 has already the full chip. Could be just called as 5080 24GB.
108 (0.17/day)
Processor 7800X3D @ Curve Optimizer: All Core: -25
Motherboard TUF Gaming B650-Plus
Memory 2xKSM48E40BD8KM-32HM ECC RAM (ECC enabled in BIOS)
Video Card(s) 4070 @ 110W
Display(s) SAMSUNG S95B 55" QD-OLED TV
Power Supply RM850x
This denser/higher VRAM consumer GPU for local AI LLM self-hosting indeed is nice, but I wish the 3GB chips were on the much cheaper 5070 Ti. The 5080 is only 13% (1440p) to 15% (4K) faster than the 5070 Ti, but costs 33% more (MSRP).
RTX 5070 Ti750 $256-bit8 GDDR7 2GB chips (32bit per chip)16 GB896 GB/s47 $ per GB
RTX 50801000 $256-bit8 GDDR7 2GB chips (32bit per chip)16 GB960 GB/s63 $ per GB
Obviously, using the 5080 instead of the cheaper 5070 Ti as a base, is a way for companies to up-sell the cheap silicon. The 5070 Ti may follow later..gota rip off the customers and maximize the profits first.
bug
14,273 (3.96/day)
Useless for gaming for the next few years at least, but neat I guess.
All we know is somebody toyed with the idea. We don't know if it was deemed worthy. That said, I can see increased VRAM demand from those that would run LLMs locally. At the same time, I see AMD and Nvidia pushing those users towards their professional line of cards, rather than messing with their consumer products lineup.
801 (1.15/day)
Brazil
Processor 5950x
Cooling Fuma 2
There are datacenters in china offering those 4090 48GBs already haha
There are even some of those 4090 48GB on vast.ai already:
