MSI Unleashes R6870 HAWK Graphics Card with Propeller Blade Technology
46,777 (7.64/day)
After having swept through the global market with the dominating N460GTX Hawk, world-renowned graphics card and mainboard manufacturer MSI announces the next-generation Hawk series, the R6870 Hawk graphics card. Equipped with the advanced Twin Frozr III thermal design, the all new R6870 Hawk is the world's first graphics card to use propeller blade technology. When compared to traditional fans, the air flow is increased by 20%, allowing the GPU temperature to be up to 21 degrees lower. Furthermore, it uses the 8+2 phase PWM design to provide the GPU with 2 times the power supply, along with triple overvoltage functions that allow further evolution of R6870 Hawk's overclocking capability. The R6870 Hawk has the most perfect performance blend of cooling, power components, stability, and high performance found on a graphics card today.
MSI exclusive propeller blade technology: Air flow increased by 20%
The R6870 Hawk is equipped with the advanced version of Twin Frozr III cooling design with the MSI-exclusive propeller blade technology. When compared with traditional fan blade design, it not only increases the air flow by 20%, but the grooved surface on the fan blade further extends the range of air flow, removing more heat generated by the graphics card's materials and parts. Additionally, dual 8cm PWM fans, SuperPipe technology and a nickel-plated copper base allow the heat to be removed quickly and effectively. When compared to the reference design, the GPU temperature is decreased by up to 21 degrees, completely validating the excellent cooling effects of the next-generation Twin Frozr III thermal design.
Considering the diversity of graphic card users, MSI has developed the exclusive P/S Switch function for users to adjust fan speed between the Performance Mode and Silent Mode. The former emphasizes an enhanced cooling power that can significantly reduce GPU temperature to keep the graphic card at the optimal working condition, while the latter stresses on quiet operations for users to keep noise minimal while playing games or watching a movie. As both modes deliver excellent cooling performance, even the pickiest power users can always keep the environment under control according to their needs.
PWM enhancement and triple overvoltage support Over-clocking potential outbreak
In order to provide users with the optimal display performance, the R6870 Hawk uses the 8+2 phase PWM design. Compared to the 4+1 design for the reference design, it provides twice the power support, increasing overclocking stability. Together with MSI's exclusive Afterburner overclocking software, the R6870 Hawk supports GPU/Memory/VDDCI triple voltage adjustment, increasing the overclocking potential.
Besides the unique power and voltage design, through V-Check Points users can easily use a multi-meter and monitor the GPU/Memory/VDDCI voltage status. Overclocking is also made easy and simple on the R6870 Hawk by using the Afterburner overclocking software to monitor all aspects of graphics card performance, as well as save up to 5 user-defined overclocking profiles.
Carefully selected top-class materials
MSI's R6870 Hawk graphics card uses the newest Military Class Components such as Hi-C CAP, Super Ferrite Choke (SFC), and all-solid capacitors to enhance the overclocking headroom under high-load conditions. Hi-C CAPs have a lifespan 8 times that of traditional solid capacitors, increasing GPU stability and lifespan of the graphics card, while SFCs improves efficiency by 10% while increasing the maximum current output by 30%.
46,777 (7.64/day)
"...with Propeller Blade Technology"
That's kind of like saying "Ford announces new 3.0L engine with internal combustion technology".
2,863 (0.48/day)
Brasil
System Name Sovereign // HTPC
Processor i7 3770k 4.2 // i7 3770k 4.2
Motherboard Maximus V Gene // Sabertooth Z77
Cooling Noctua D14 // Intel HSF
Memory 16GB Samsung // 16GB VengeanceLP
Video Card(s) Deciding // 660 DC2
Storage OS (X25-M), Data (Seagate 1TB) // Samsung 840 120GB & bunch of drives
Display(s) Samsung T240HD // LG TV
Case TJ08e // Grandia GD08
Audio Device(s) DT880 Pro 250 ohm // TV speakers
Power Supply Seasonic Plat 1000 // Seasonic Gold 760
Software Windows 8 Pro x64 // Windows 7 Pro x64
LMAO! You are right, the should have said blade design or turbine blade, chopper blade, chopper propeller, something to make it different.
But a TWIN frozer 3 for that card? I would expect for a 6970 and 580
4,686 (0.79/day)
System Name Obelisc
Processor i7 3770k @ 4.8 GHz
Motherboard Asus P8Z77-V
Cooling H110
Video Card(s) GTX 780 Ti
Case T81
Software Win10 64bit
I think this is their trial run of yet another twin frozr III design, on a main stream card this time, to see if the masses will deem it as an adequate twin frozr II successor. Given the generic piece of crap appearance, I'd wager not.
2,863 (0.48/day)
Brasil
I like it better than the 2, at least if temps are lower.
wolf
Better Than Native
7,993 (1.27/day)
System Name MightyX
Processor Ryzen 5800X3D
Motherboard Gigabyte X570 I Aorus Pro WiFi
Cooling Scythe Fuma 2
Memory 32GB DDR4 3600 CL16
Video Card(s) Asus TUF RTX3080 Deshrouded
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
I like the Performance mode/Silent mode switch function, it should be easy enough to store two fan profiles and just have either a simple software control for it or even a phsyical switch if you really wanted to.
Over_Lord
764 (0.15/day)
Hyderabad
System Name BAH! - - tHE ECo FReAK
Processor Athlon II X4 620 @ 1.15V
Motherboard ASUS 785G EVO
Cooling Stock
Memory Corsair Titanium 4GB DDR3 1600MHz C9
Video Card(s) Sapphire HD5850 @ 1.049v
Storage Seagate 7200.12 500GB
Display(s) BenQ G2220HD
Case Cooler Master Elite 334
Power Supply Corsair VX550W
Sensi Karate
381 (0.07/day)
Brisbane, Australia
System Name l The '1 pvvn j00 ^oobeh?!? l
Processor l Intel Core 2 Duo E8400 3.0GHz @ 4.2GHZ l
Motherboard l Gigabyte GA-EP45-UD3P Rev 1.1 l
Cooling Corsair H20 Watercooling l 6 Fans l Thermaltake DualOrb VGA Cooler
Memory l Kingston Hyper X 1066MHZ DDR2 6GB l
Video Card(s) MSI R6870 1GB Twin Frozr II
Storage l OCZ Vertex 60GB SSD l 2x1TB WD Caviar Green 7,200RPM Raid 0 l My Book WD 500G External l
Display(s) l BenQ E2200HD 21.5" HD l
Case l HAF 922 l
Audio Device(s) l Realtek ALC889A l Logitech G35 7.1 Surround Sound Headset
Power Supply Corsair 750W HX
Software l Windows 7 Ultimate 64-bit l
Benchmark Scores I ownz tehmz n00bez! >:D
I like my Twin Frozr II more.
nINJAkECIL
233 (0.04/day)
Processor i7 3770K@4.7ghz
Motherboard MSI Z77A-GD65
Cooling Thermalright Venomous X black
Memory V-GEN 4x4GB DDR3
Video Card(s) Zotac GTX-560Ti
Storage Crucial M4 64GB | WD Green 1TB | Seagate 1TB | Seagate 500GB
Display(s) Viewsonic VA2013WM
Case Corsair Carbide 400R
Audio Device(s) Audigy 2ZS Platinum
Power Supply Corsair AX750W
Software Win7 x64
Benchmark Scores http://valid.x86-secret.com/show_oc.php?id=371985
Resemblance of the original TwinFrozr, but with better fans.
nice job MSI.
I hope TF III would be such a performer to squeeze an extra performance of the card.
Can't wait to see it fitted on higher card.
9,861 (1.89/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
propeller? Come on its not a helicopter, it just a double fans. But it has nice design LOL
332 (0.06/day)
Processor Intel® Core™ i5-2500K (4.6GHz @ 1.28-1.33v)
Motherboard ASRock Z68 Pro3 Gen3
Cooling Prolimatech Megahalems Rev.C + Blue Vortex 140mm
Memory Kingston HyperX Fury White (2x8GB, DDR3-1866, 10-11-10-30, 1.5v)
Video Card(s) MSI GTX 970 Gaming
Storage Crucial C300 128GB, WD Green 2TB
Display(s) BenQ XL2420T
Case Antec Twelve Hundred
Audio Device(s) Onboard Realtek audio
Power Supply Corsair HX 650W
Software Win7 Ultimate (64-bit)
This is about time I'd like to see a solid 8+ 6870 card round-up.
2,318 (0.40/day)
Texas
System Name Mr. Reliable
Processor Ryzen R9 5950x
Motherboard MSI Meg X570s Ace Max
Cooling D5 Pump, Singularity Top/Res, 2x360mm EK P rads, EK Magnitude/Alphacool Blocks
Memory 32Gb (4x8Gb) Corsair Dominator Platinum 3600Mhz @ 16/19/20/36 1.35v
Video Card(s) MSI 3080ti with Alphacool Block
Storage 2 x Corsair Force MP400 1TB Nvme; 2 x T-Force Cardea Z340; 2 x Mushkin Reactor 1TB
Display(s) Acer 32" Z321QU 2560x1440; LG 34GP83A-B 34" 3440x1440
Case Lian Li PC-011 Dynamic XL; Synology DS218j w/ 2 x 2TB WD Red
Audio Device(s) SteelSeries Arctis Pro+
Power Supply EVGA SuperNova 850G3
Mouse Razer Basilisk V2
Keyboard Das Keyboard 6; Razer Orbweaver Chroma
Me too. I have a pair or 6870 TwinFrozr IIs and they keep the card nice and cold with a good acoustic level. I really don't see the need for this when the TFIIs are still readily available.
2,331 (0.45/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
AGREE
I'm breathing some oxygen technology now, when do I get an upgrade?
wolf
Better Than Native
7,993 (1.27/day)
System Name MightyX
VR HMD Meta Quest 3
I'm somewhat displeased with the pre overclocked 6800/6900 series cards at the moment, due to the speed increases that they are getting. were seeing ~900mhz stock clocked cards getting an overclock anywhere up to 950mhz, but rarely (perhaps not even) more.
Hec the 4890 had pre overclocked cards at 1ghz, and since then it's been less and less... I mean it's no sweat for me becuase I'll clock it myself but it hardly speaks for value when these kind of cards end up costing quite a bit more than a stock clocker.
nINJAkECIL
233 (0.04/day)
Software Win7 x64
I'd prefer little bump on the OC, and leaves plenty of OC headroom.
Higher OCed cards costs more. I'd OCed myself.
And seeing this card equipped with more VRM and with voltage tweak, it should pretty easy to bump the core clock a little higher than what mfg. offer.
Completely Bonkers
2,576 (0.40/day)
Processor Mysterious Engineering Prototype
Motherboard Intel 865
Cooling Custom block made in workshop
Memory Corsair XMS 2GB
Video Card(s) FireGL X3-256
Display(s) 1600x1200 SyncMaster x 2 = 3200x1200
Software Windows 2003
It's nice to see you are taking the time to read and comment on the PR nonsense you have to quote in these press releases.
I really would like copy+paste from PR sheets to be in a quote box. Even a more subtle, restyled one specifically for news, not as boxy or harsh as the one used for quoting members posts. It's easy to set up bbcode to do this. :pimp:
2,863 (0.48/day)
Brasil
The component cooling is AMAZING
1,491 (0.21/day)
66 feet from the ground
System Name 2nd AMD puppy
Processor FX-8350 vishera
Motherboard Gigabyte GA-970A-UD3
Cooling Cooler Master Hyper TX2
Memory 16 Gb DDR3:8GB Kingston HyperX Beast + 8Gb G.Skill Sniper(by courtesy of tabascosauz &TPU)
Video Card(s) Sapphire RX 580 Nitro+;1450/2000 Mhz
Storage SSD :840 pro 128 Gb;Iridium pro 240Gb ; HDD 2xWD-1Tb
Display(s) Benq XL2730Z 144 Hz freesync
Case NZXT 820 PHANTOM
Audio Device(s) Audigy SE with Logitech Z-5500
Power Supply Riotoro Enigma G2 850W
Mouse Razer copperhead / Gamdias zeus (by courtesy of sneekypeet & TPU)
Keyboard MS Sidewinder x4
Software win10 64bit ltsc
Benchmark Scores irrelevant for me
anyway this is the best cooled 6870 on market
