- Oct 9, 2007
- 47,523 (7.48/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Without question, MSI is not only the market leader in the gaming hardware industry but also the pioneer in the Content Creation & Business market with a range of innovative technologies. As the world tends to be unpredictable, MSI keeps on developing products with stylish, stable, and have the best performance for all kinds of users. Today, MSI launched the brand new Content Creation Products: the Creator P50 with another new flagship monitor Summit MS321UP, both designed for creators, business professionals, and multi-taskers.
Creator P50 is sleek, slim, but packs a ton of power and is the dream desktop for creators, multi-taskers, and business professionals. MSI Creator P50 was inspired by the wireframe modeling and construction lines made by creators. The polygonal cutting pattern on this small 4.72 liters chassis not only symbolizes the unlimited imagination and extension of creativity, but also reflects a creator's growth, transformation, and refinement. It won't steal away the brilliance of the environment but blends in quietly with a low-key and elegant design. The P50 is a professional, clean, and stylish creativity center.
Compact Dimension with Great Ideas
Creator P50 brings you unparalleled power and flexibility. With acceleration, precision, and detail orientation, the Creator P50 puts you at the helm without getting in your way. Although its diminutive 4.72L volume chassis might not immediately give it away, this compact desktop comes equipped with the latest 11th Generation Intel Core i7 processor for a blazing-fast computing experience. It can handle all sorts of professional applications with ease. The MSI Creator P50 also comes with a host of connectivity options to cater to almost any kind of equipment. It features a front-panel Thunderbolt 4 (USB 4.0) USB-C port with up to 40 Gbps speeds.
From professional Thunderbolt displays to lightning-fast network devices, this front panel port allows you to work without giving up compatibility or any performance. Network connectivity won't be an issue with the Creator P50, thanks to the high-speed wired and Wi-Fi options built into the system. While the 2.5 Gigabit LAN takes care of wired connectivity at blazing speeds, Wi-Fi 6 offers 2.4 Gigabit speeds with improved reliability without wires! This unique geometric design will complement any modern setting, instantly blending into any kind of workspace.
Smartly Manage and Create Your Content with MSI Center
More than just a traditional high-end PC, the MSI Creator P50 Series comes with the most powerful hardware and MSI's exclusive software - MSI Center - a total solution to handle heavy workloads. The MSI Center takes optimization to the next level with A.I., it helps to prioritize & allocate the resource on your hand to accelerate the performance of that software which you work with every day. It also helps you to find the photos or materials with a tag and brings the most efficient experience for your daily works. This is what the creators were after.
Summit MS321 Series Helps You Stand Above the Clouds
When you have the powerful Creator P50, you must have our Summit MS321 Series flagship monitor. The MSI Summit MS321 Series Monitor brings you eye-care, ergonomics, and MSI's exclusive Productivity Intelligence (P.I.) App, to enhance the efficiency for users. The Summit MS321 Series is designed with an imperfect circle and curved line on its back cover. It shows a perfect symmetry on the front but an asymmetry on the back. The circle on its back represents the halo of the sun, the curved line represents the cloud and an upward slope or path that one may walk or climb. The Summit MS321 will not only help you stand upon the summit but also above the clouds.
We bring you the best panel specifications with a 4K (3840x2160) resolution, 136% of sRGB, and 95% of DCI-P3 & the most accurate color. We also introduce to you other ergonomic & convenient hardware and smart software features such as a hardware magnetic monitor hood & card reader. The exclusive MSI P.I. App which includes the True Color feature, KVM, Smart Brightness & Color Temperature, and Active Noise Cancellation helps users stand on the top and beyond the peak because it is always sunny and bright above the clouds. This is the MSI Summit MS321 Series.
Take Care of Your Eyes with Ergonomic Hardware and The Exclusive MSI Productivity Intelligence (P.I.) App
Eye care & ergonomic design are the most important factors when we are talking about a professional monitor that you will use for 10~14 hours a day. With the TÜV certificated anti-flicker & less blue light technologies, you can learn or check any data with our ergonomic stand that can be adjusted with tilt, height, and swivel for the most comfortable viewing position
The exclusive MSI P.I. App brings you a lot of smart and intuitive features. You can set every detail like color mode, brightness, and contrast just with your keyboard and mouse instead of traditional OSD buttons which are typically hard to use. With a MSI P.I. processor designed in Summit MS321, you can save all of your color-parameter profiles in the monitor instead of a computer, so you don't have to recalibrate the Summit MS321 while connecting to different devices. With a smart sensor, Summit MS321 will automatically detect the ambient light levels to adjust its on-screen brightness and color temperature for your viewing comfort, and it comes with Active Noise Cancellation for you to improve your conference call or online chatting experience.
The MSI P.I. App brings you the KVM function. When you work with your laptop and a MSI desktop PC at home, you just need one keyboard and one mouse to control your two devices through Summit MS321 which functions as a KVM switch. Just move and click your mouse and you can switch between these two devices. It helps improve the efficiency when you work with two PCs, no matter where you are. The Summit MS321 will not only help you stand on the summit but also be your window to the world.
