MSI x570 Tomahawk - 8+4pin CPU Power Requirement
17 (0.00/day)
System Name Armor+_9fan_warrior
Processor q6600@3.40ghz
Motherboard P5-E(X38)
Cooling OCZ Vendetta 2
Memory Corsair Dominator 2X2gb 1066mhz 5-5-5-15 2.1V
Video Card(s) HIS Radeon 4870
Storage 750GB SATA 2 & WD passport 250gbs :)
Display(s) hp 17" LCD
Case Thermal Armor + Silver aluminium
Audio Device(s) Supreme FX-II
Power Supply Corsair HX-620
Software Vista Sp1 x64
Benchmark Scores 3DMArk06: 15418
Hi Gurus,
My planned build will have a MSI x570 Tomahawk motherboard which requires a 8 + 4 pin power for the CPU. I am looking at an antec HCG 750W PSU which comes with 2 x 8 pin plugs for the CPU.
I have read that I can have half of the 8 pin connected to the 4 pin but does it matter which way its oriented ? Reason i ask is that there a component next to the 4 pin plug so i don't have the space for the "extra 4 pins" to overhang. It will have to have to be plugged in 90 degrees flipped.
If not, how else can I proceed to get a 4 pin plug from my PSU to the additional 4 pin required on the board.
2,012 (0.36/day)
Heart of Eutopia!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
no no and no
there are latches on one side and there is only one way to push this in.
this is built to plug it in one way and ya have the space-if not you are doing something wrong
if ya plug the 4pin latch in the direction of the "component" its wrong-latch should point to above =end of motherboard.
both are the same direction 8pin + 4 pin
if ya are not overclocking like crazy ya don't need that 4pin to start the motherboard
plz be careful dont ruin your new pc!
if ya have questions(can be dumb too) ask us-we are happy to help
Tatty_Two
Gone Fishing
25,901 (3.79/day)
Worcestershire, UK
Processor Intel Core i9 11900KF @ -075mV PL max @225w
Software Win 11 Home x64
I have an 8 + 4 on my board but I only use the 8 pin and it works fine, I think it delivers up to 375 Watts, unless in x570 guise it is powering more than just a CPU.
241 (0.15/day)
System Name Yin/Yang
Processor Ryzen 7 3700x
Motherboard msi mag x570 tomahawk
Cooling CoolerMaster ML240V2 / asiahorse fs9002 120mm fans
Memory 2 x 16gb g.skill trident z neo 3600
Video Card(s) msi gaming X 2070 super 8gb
Storage 1tb sabrent rocket nvme / 1tb samsung evo 860 sata ssd / 3tb Toshiba hdd
Display(s) lg ultragear 2560x1440 144hz 1ms 27"ips
Case nzxt h510i
Audio Device(s) logitech g635 / creative sound blaster
Power Supply evga supernova 750ga 80 plus gold
Mouse logitech g402 hyperion fury
Keyboard corsair k55
yeah, no need for the extra 4 pin. One 8 pin is fine
752 (0.47/day)
System Name Main PC
Processor AMD Ryzen 9 5950X
Motherboard ASUS X570 Crosshair VIII Hero (Wi-Fi)
Cooling EKWB X570 VIII Hero Monoblock, 2x XD5, Heatkiller IV SB block for chipset,Alphacool 3090 Strix block
Memory 4x16GB 3200-14-14-14-34 G.Skill Trident RGB (OC: 3600-14-14-14-28)
Video Card(s) ASUS RTX 3090 Strix OC
Storage 500GB+500GB SSD RAID0, Fusion IoDrive2 1.2TB, Huawei HSSD 2TB, 11TB on server used for steam
Display(s) Dell LG CX48 (custom res: 3840x1620@120Hz) + Acer XB271HU 2560x1440@144Hz
Case Corsair 1000D
Audio Device(s) Sennheiser HD599, Blue Yeti
Power Supply Corsair RM1000i
Keyboard Corsair Strafe RGB MK2
Software Windows 10 Pro 20H2
It makes no difference. A single 8pin is more than enough. The extra plug is for extreme overclocking.
6,738 (3.03/day)
California
System Name His & Hers
Storage lots of SSD.
The only current consumer level CPU that requires more than an 8 pin with really good cooling on a high overclock is a 10900k
Nothing currently that slots into x570 requires more than an 8 pin on ambient cooling.
5,701 (0.79/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Razer Pro Type Ultra
4-pin extra power on AMD boards is a completely unnecessary "feature" that motherboard manufacturers add to make their boards seem better (and also to charge you more money).
As others have said, you don't need it, you won't ever need it, do not worry about it.
17 (0.00/day)
legend thank you so much guys ! As you can see from my build specs - i have been out of the scene for close to 10 years.
With just the 8 pin - can i push my ryzen 5 3600 base clock upto 4Ghz ? I'm not looking at any crazy overclocking
6,738 (3.03/day)
California
It should sit around that with just boost and probably higher 4.2 ish in games. With decent cooling
I'd personally just let boost take care of the clocks it's what I do on my 3900X
752 (0.47/day)
System Name Main PC
Case Corsair 1000D
Don't bother overclocking the Ryzen chips. They're already good out of the factory, and setting an all core overclock hurts the single core performance. Just enable PBO and the chip will do its thing, much better than any manual overclocking could.
And the 3600 isn't even close to drawing enough power to warrant more than an 8pin. 8pin can supply upto 350W (IIRC), and the 3600 is lucky to go above 90W. The only time you'll ever see a use out of the extra 8pin is with LN2 or with overclocking the 3950X or the 10900K or above.
259 (0.07/day)
System Name maipc
Processor 4790k @ 4.4Ghz / 1.16v
Motherboard Asus vii hero
Cooling Noctua NH-D14
Memory 16GB (2x8GB) Hyperx fury 1866 / CL10
Video Card(s) MSI RTX 3060 Ti Gaming X 8GB
Storage 1TB 860EVO + 1TB 860EVO + 4TB WD Red + 4TB WD Red
Display(s) Asus VG259QM (1080p IPS 240Hz)
Case Cooler Master Centurion 6
Power Supply Seasonic Prime GX-650
Mouse Logitech G Pro X Superlight
Keyboard Wooting 60HE
Software Win 10 64bit
Half of the 8pin CPU power connector on many power supplies can be split off turning that connector into a 4pin CPU power connector.
The HCG 750W power supply you have is probably like that too.
8pin and 4pin CPU power connectors are keyed and can only be plugged in one way.
5,958 (2.90/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
As someone mentioned before, 8-pin can handle up to 375W. More than this is required only for extreme OC, think liquid nitrogen. My board has only 8-pin and it runs 3700x just fine, hell it would run 3950x if you threw it at it.
