- Dec 28, 2019
- 80 (0.05/day)
System Name | The Ryzenator |
Processor | AMD Ryzen 9 3950X |
Motherboard | Asus ROG Crosshair VIII Hero wi-fi |
Cooling | NZXT Kraken Z73 360mm. AIO |
Memory | 64GB (4 X 16) G.Skill TridenZ Neo 3600MHz CL16-16-16-36 |
Video Card(s) | Asus ROG Strix RTX 2080 Ti 11OC |
Storage | 2 X 1TB Samsung Evo Plus |
Display(s) | ASUS ROG Swift PG279Q 27" |
Case | Lian Li O11 Dynamic |
Audio Device(s) | Razer Nommo Chroma |
Power Supply | Corsair AX850 (Seasonic Prime Ultra) |
Mouse | Sandstrøm Premium SS133 |
Keyboard | Razer Cynosa Chroma |
Software | Windows 10 64-bit |
Benchmark Scores | T.B.A. |
Hi guys.
I'm having a hard time finding out how i go about connecting 3 addressable rgb units into 1 addressable rgb header on my new mobo. Maybe someone can shine some light on this issue - which is oddly hard to find any info on by searching the internet!
Mobo: Asus ROG Crosshair VIII Hero Wifi x570
Device 1: Argb cable from AIO/pump head of the Deepcool Castle 360ex (Aura compatible)
Device 2: argb strip (Aura compatible)
Device 3: argb strip (Aura compatible)
First off i know about not overloading headers in order to avoid frying things,but the thing is i can't really find out how much ampere a AIO's header rgb (or this one's in particular) uses. The argb headers on the Asus ROG Crosshair VIII Hero are 3A (5V) each, as per the instructions manual coming with the board. The AIO on the other hand, has these specs:
I don't see any mention about "A" in regards of the addressable lighting, only that it is 5 VDC voltage, which is standard for argb. A little further down i see "2.25W" mentioned - but nothing about ampere. The same goes for LED strips, i can't find any specs about their usage of a.
So my question is: How do i know how many ampere the aio's argb + the 2 argb strips use, in order to not go over the limit of the 3A supported by the argb header on the board?
Also another thing: Would a 4 pin splitter cable (3 way) be ok to use between A) an 3 pin argb header on the mobo and B) one, two or three 3 pin argb devices - as longs as the total ampere of the devices is not higher than what mobo supports? I mean it's basically the same cable, just with one less pin no? Will it work, or does it have to be a dedicated 3 pin splitter cable?
Thanks.
Radiator Dimensions | 402×120×27 mm |
Radiator Material | Aluminum |
Net Weight | 1705 g |
Tube length | 465 mm |
Pump Dimensions | 86×75×71 mm |
Pump Speed | 2550 RPM±10% |
Pump Noise | 17.8 dB(A) |
Pump Connector | 3-pin |
Pump Rated Voltage | 12 VDC |
Pump Rated Current | 0.2 A |
Pump Power Consumption | 2.4 W |
Fan Dimensions | 120×120×25 mm |
Fan Speed | 500~1800 RPM±10% |
Fan Airflow | 64.4 CFM |
Fan Air Pressure | 2.33 mmAq |
Fan Noise | ≤32.1 dB(A) |
Fan Connector | 4-pin PWM |
Bearing Type | Hydro Bearing |
Fan Rated Voltage | 12 VDC |
Fan Rated Current | 0.15 A |
Fan Power Consumption | 1.8 W |
LED Type | Addressable RGB LED |
LED Connector | 3-pin(+5V-D-G) |
LED Rated Voltage | 5 VDC |
LED Power Consumption | 2.25 W(PUMP) |
EAN | 6933412726760 |
P/N | DP-GS-H12-CSL360EX |
Thanks.
