MX500 Drive Health?
juanyp90
2 (0.00/day)
I got an mx500 directly from amazon not third party about 2 years and a half ago and I noticed that my drive health is 72% even though I have only 15TBW which makes up 85% of the drive's total 100TBW. I am running firmware version M3CR043 which to my knowledge is the 2nd newest firmware and the newest has very little fixes. Crystaldiskinfo, hwinfo all show the same details. My paging size is 3.5gb. Average temps are 26 degrees celsius. Finally,my question is should I RMA this drive?
I bou
30 (0.07/day)
NBG
Processor Ryzen 5800X3D
Motherboard ASUS C8E
Cooling TechN x570 Nickel
Memory G.Skill RipJaws Black 64GB @3600MHz CL-14-14-14-28-42-272T
Video Card(s) Zotac 4090 AMP Extreme AIRO 24G @ Bykski
Storage P5800X+905P+Micron9400Pro+FireCuda530 2TB+Aorus7000S 2TB+990Pro 4TB+5х870 4TB+4xMX500 2T+U3D 2T
Display(s) LG UltraGear OLED 45GR95QE-B @240Hz
Case LianLi PC-V2120B Black BigTower
Audio Device(s) Creative BlasterX G6
Power Supply Corsair AX1600i
Mouse Logitech G900 + Logitech G502 Lightspeed
Keyboard Corsair K70 MAX
VR HMD Occulus Rift
Software Win11 Pro
But why? On what grounds?:confused:
M3CR043/M3CR044 -> M3CR045 -> M3CR046
Your drive is in good condition for 2,5 y.o. one. You have a 5-year guarantee, so it will probably still have about 50% left at the end.
Current attributes "01", "05", "AB", "AC", "BB", "C4" -> all @ ZERO -> there is no reason for RMA.
You have 14 TiB Host Writes and 368 ABEC (Micron B47R madia-grade NAND in this SSD is specified @ 1300 P/E-cycles, so you used 368 of 1300 = 28,3% of cycles),
WA (write amplification) is about 3,73x = quite high, but nothing unusual if space utilisation is >80-90% and many small files are written (typical OS-drive usecase).
890 (1.13/day)
Belgium
System Name Prometheus
Processor AMD Ryzen 7 9800X3D
Motherboard ASUS ROG Crosshair X870E Extreme Gaming Wifi
Cooling AIO Cooler Master MasterLiquid 360
Memory 32GB DDR5 6000Mhz CL30
Video Card(s) Gigabyte GeForce RTX 3060 OC Edition 12GB
Storage Samsung 970PRO 2TB, Samsung 990PRO 4TB, WD SN850X 2TB, Samsung 980PRO 2TB. WD GOLD HDD 8TB
Display(s) Corsair XENEON 32UHD144 32" 4K UHD gaming monitor
Case Cooler Master HAF
Audio Device(s) Creative Sound Blaster AE7 + Logitech Z-5500 500W 5.1.
Power Supply Corsair AX850 Titanium, RM850X (2024)
Mouse Logitech MX Master 3
Keyboard Corsair K95 RGB Platinum Cherry MX
Software W10-11 Enterprise- Linux Mint 22.1 Cinnamon Edition.
Moreover they will just send you back this drive, because there's nothing wrong with it. They will never accept it even to RMA it.
3,914 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Looks like same issue my MX 500s have, rapid erase cycles.
That wont get a RMA swap, they not going to replace just from high wear.
juanyp90
2 (0.00/day)
I'm confused on why my mx500 has high rapid erase cycles if I max my drive out at 25% free
Even at 25% free is this normal? It is my main boot drive for windows 10.
475 (0.14/day)
System Name Specs Last Update: 8/April/2024
Processor Intel Core i5 9400f 2.9GHz/4.0 Turbo (NoOC)
Motherboard Gigabyte Z370M D3H rev. 1.0
Cooling be quite! Dark Rock Slim 180W TDP (The Silent Wings 3 120mm Fan)
Memory Corsair Red Line 8x2 16GB 3000MHz (NoOC) DDR4-3000 15-17-17-35 (CMK16GX4M2B3000C15R) V1.35 ver 4.24
Video Card(s) NVIDIA GeForce MSI 980 Ti Golden Edition (NoOC)| Spare: GTX 650 Ti 1 GB
Storage Samsung 870 EVO 4 TB | Samsung 860 EVO 1 TB | Cold Backup: WDC Black 930 GiB WD1003FZEX
Display(s) Asus VG248QZ 1920x1080 144hz 24" (Current: 60hz)
Case Corsair Air 540
Power Supply Corsair 850W RMi
Mouse Logitech M187 wireless (First day of use 30-9-2021)
Keyboard Logitech K270 wireless
Software Windows 10 21H2 LTSC 2021 / Linux: Candidates: Bazzite - Linux MX - Tuxedo - Kubuntu
Go to: Function > Advanced Feature > Raw Values > 10 [DEC]
This will show you actual values in decimal.
890 (1.13/day)
Belgium
Well don't forget you have the lowest grade SSD installed from these popular and cheap SSD. It should work for some years more without problem. You can take a look with HDSentinel program to see what it says about the life. It's better then CrystalDiskInfo. You can download a free sample copy from their website.
2,240 (0.43/day)
You can slow the rate down by partitioning a bit less then the actual size of the drive.
I think by default i always snoop 20% off for durability.
2,619 (0.53/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Memory 64 GB G.Skill RipJaws V F4-3200C16D-64GVK
Case Corsair 275R
Mouse Logitech G Pro (Hero)
A couple of entries suggest a SATA communication issue. Have you tried another SATA cable?
Attributes B7 and C7 in Crystal Disk Info.
AsRock
TPU addict
19,234 (2.96/day)
UK\USA
Cooling D15
High wear ?, 15TB is hardly high. Umm i should check the other PC as it has a MX500 in it too.
EDIT:
Had 4 SSD's fail and none of them were below 80% which was only one of them.
3,914 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
EDIT:
The wear is measured in erase cycles, 250 gig drive 170 cycles. 15tb writes. For a 250 gig drive operating normally I would expect somewhere around 60 cycles for that level of writes, he has 170, some mx 500's due to a bad revision have inflated erase cycles,, I had a thread on it some time ago.
With that said its likely well within the design spec, and is no errors on the drive, thats why I said an RMA would not be approved for that.
30 (0.07/day)
NBG
VR HMD Occulus Rift
Software Win11 Pro
The wear is measured in erase cycles, 250 gig drive 170 cycles. 15tb writes. For a drive operating normally I would expect somewhere around 6-12 cycles, he has 170,...
170, huh? What r u talking about? Have you read my first post (#2) carefully? And No, it is impossible for 250GB-SSD to have "6-12 cycles" after 15TB writes. Perhaps for 2-4 TB one...
Just divide 15TB by 0,25TB = 60 P/E-cycles in an absolutely unrealistic ideal case if it had WAF=1,0. I would rather say: "for a drive operating normally I would expect somewhere around 120-240 cycles". Summing up: ~180 P/E-cycles would be OK, he has 368, so about twice the cycles one would normally expect.
AsRock
TPU addict
19,234 (2.96/day)
UK\USA
Cooling D15
I's still contact them, expecting to be told it's not a good reason for RMA but still.
Some times you can be surprised.
Will have to get around to checking the other system with the MX500 as that's never had a firmware update.
5,434 (3.67/day)
Colorado, U.S.A.
Software Windows 11 Home
AsRock
TPU addict
19,234 (2.96/day)
UK\USA
Cooling D15
Out of how many?
Just saying is all, been buying them since intel started to release them for $230 80GB drives. I am not some one who buys them all the time just what we need for personal use and use them until they die.
Two Team Group Dark drives died which of one of them would quit working time to time one intel one which cuts off very briefly and a Corsair Force GT which is not seen by the system any more.
