my 5ghz cpu works 4.7 at max why?
mertduver
1 (0.00/day)
hi! i have monster tulpar t7 v20.3 laptop.
its atcually a tongfang gm7mg0r.
it has i7-10750H (5ghz single core boost)
but i cant even see 4.8ghz when i am doing tests of single core benchmarks.
i dont have any thermal throttleing.
i use hwinfo and xtu while doing this tests.
it says its power throttleing though...
i also have this settings (picture) from my computers control center.
my question is its at default wattage and powered with ac and doesnt have thermal throttleing so it should work at 5ghz or 4.9ghz as intel said right? why its working at 4.6 on single core bench? is there anything that will achieve me to 4.9ghz? is there anyone uses the same cpu? what are your clocks?
i actually dont care about single core 0.2ghz performans difference but i just wonder why. its like intel is lying u know...
newtekie1
Semi-Retired Folder
28,473 (4.06/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
It amazes me how people don't understand how incredibly rare it is for a computer to have just a single loaded core these days. Windows is always doing other crap in the background.
8,226 (2.13/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
install ThrottleStop and try to read the log from it.
14,229 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Bump your PL2 up, 75W is most likely holding it back.
Try 90W or slightly higher.
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
the high frequency is only reached if you have custom OC settings, or there is little work load on the CPU, causing it to use few cores.
when the cpu is under load, it will drop frequency as it uses more cores
if you want it to run at 5GHz always on all cores under load, you'll need to set that in bios & you'll need the cooling to handle it, or it will drop performance or shut down
