My AM3 Build (Future Planned)
2,887 (0.65/day)
Fort Worth, TX
System Name LGA775 | BoX-Server
Processor Xeon E5450 OC3.6GHZ from 3GHZ | i3 3.4GHZ
Motherboard ASUS PQ5-EM | ASRock
Cooling 120MM Heatsink (2-FANs) | Custom HSK 90mm
Memory DDR2 2GB-x4=8GB | 8GB 2x4GB=8GB
Video Card(s) NVIDIA Quadro K2200 4GB | Intel
Storage 500\500/240/240GB SSDs 120GB Laptop IDE
Display(s) Asus 24"
Case DIYPC N1e-SPORT | CoolerMaster 110
Power Supply EVGA 550WATT | Rosewill 530WATT
Mouse Rosewill RGB
Keyboard Rosewill RGB
Software WiN10ET/WiN11ET
Hi guys,
So my 775 Build is Almost Finished and would like my AMD Build back. Those days I had the Athlon X4 CPU @2.5 to 3.1GHZ which at the time was great.
The following MB I plan to use ASUS M4A88T-M
The RAM is some my friend has @4GB (The brand/type coming soon)
I'll have a mSata SSD in mind (more on that later)
The GPU is going to be onboard or a cheap low cost one
ALL this shall be updated later
dorsetknob
9,107 (1.25/day)
Board does not support M2 Sata
Your need a PCIx4 Adapter and motherboard has only 1 PCIx16 so using a M2 adapter means no discrete Graphics card
2,887 (0.65/day)
Fort Worth, TX
Display(s) Asus 24"
Mouse Rosewill RGB
No No the mSata pci-e type (meaning the old type or first Gen) as I don't really find the speeds All that important really. As on my 775 Build a 5 sec boot is fine where the read/writes to 250MB is beyond fine with me
43,439 (6.76/day)
Hi guys,
This board does not support AM3+ CPUs, not physically or with a bios update, the biggest you can get is a Phenom 2 X6 1100T.
https://www.asus.com/Motherboards/M4A88TM/HelpDesk_CPU/
If anything get a sabertooth or Crosshair 4.
2,887 (0.65/day)
Fort Worth, TX
Display(s) Asus 24"
Mouse Rosewill RGB
That board does support the Athlon X4 series CPUs so that's All I want
2,748 (0.68/day)
Alabama
Processor Ryzen 2600
Memory C.R.S.
Video Card(s) GTX 970
Software Linux Peppermint 10
2,887 (0.65/day)
Fort Worth, TX
Display(s) Asus 24"
Mouse Rosewill RGB
Thanks I'll keep that in mind
2,748 (0.68/day)
Alabama
Memory C.R.S.
No prob, just let me know if and when. ;)
847 (0.35/day)
Haswell, USA
System Name Bruh
Processor 10700K 5.3Ghz 1.35v| i7 7920HQ 3.6Ghz -180Mv |
Motherboard Z490 TUF Wifi | Apple QMS180 |
Cooling EVGA 360MM | Laptop HS |
Memory DDR4 32GB 3600Mhz CL16 | LPDDR3 16GB 2133Mhz CL20 |
Video Card(s) Asus ROG Strix 3080 (2100Mhz/18Ghz)|Radeon Pro 560 (1150Mhz/1655Mhz)|
Storage Many SSDs, ~24TB HDD/8TB SSD
Display(s) S2719DGF, HP Z27i, Z24n| 1800P 15.4" + ZR30W + iPad Pro 10.5 2017
Case NR600 | MBP 2017 15" Silver | MSI GE62VR | Elite 120 Advanced
Audio Device(s) Lol imagine caring about audio
Power Supply 850GQ | Apple 87W USB-C |
Mouse Whatever I have on hand + trackpads (Lanchead TE)
Keyboard HyperX Origins Alloy idk
Software W10 20H2|W10 1903 LTSC/MacOS 11
Benchmark Scores No.
