[Case Gallery] My beast
t_ski
Former Staff
11,960 (1.76/day)
System Name My i7 Beast
Processor Intel Core i7 6800K
Motherboard Asus X99-A II
Cooling Nickel-plated EK Supremacy EVO, D5 with XSPC Bayres & BIX Quad Radiator
Memory 4 x 8GB EVGA SuperSC DDR4-3200
Video Card(s) EVGA 1080 SuperClocked
Storage Samsung 950 Pro 256GB m.2 SSD + 480GB Sandisk storage SSD
Display(s) Three Asus 24" VW246H LCD's
Case Silverstone TJ07
Power Supply Corsair AX1200
Keyboard Corsair K95
Software Windows 10 x64 Pro
Specs:
Intel E6850
Asus P5W DH Deluxe
G.Skill F2-6400PHU1-2GBHZ
Sapphire Radeon HD 2900XT
4 x 250 GB Seagate 7200.10 (Raid 0/5)
Lite-On LightScribe DL DVD-RW
Thermaltake ToughPower 750W Power Supply
Lian Li PC-A10B
Swiftech Storm Rev. 2
Swiftech MCR320-QP-K
Danger Den D5 Variable Speed Pump
Mods:
Added sound dampening throughout, Cut open top for 3 x 120mm radiator,
Wire management
Fuse-Wire
855 (0.13/day)
Scotland, Far away from normality as possible
System Name The Box
Processor DualCore AMD Athlon 64 X2 2300MHz (11.5x200) 4400+
Motherboard AsRock N 68-S
Cooling Basic 90mm fans
Memory OCZ XTC Platinum 2GB DDR-2 800 SDRAM
Video Card(s) ATI Saphire x1650 Pro Series
Storage Maxtor 6L300R0 (300GB) Maxtors S (250GB)
Display(s) 19" LCD CTX
Case EYE-T
Audio Device(s) Realtek ALC650 @ Intel 82801DB ICH4 - AC'97 Audio Controller [B-0]
Power Supply 600W colors-IT super quiet
Software Microsoft 7 Ultimate
oooh, i have a thing for black cases, they just look so sleek n sexy!! 10/10 i really do like this case alot
234 (0.04/day)
Brasil - São Paulo - São Caetano do Sul
System Name NOS
Processor Core Extreme QX6850
Motherboard Maximus Formula
Cooling VANTEC STING RAY CPU Block, 3x120mm fan's with Radiator, Seltz 1200lt/h
Memory 4GB Crucial Ballistix 1066MHz 5-5-5-15
Video Card(s) PCI-express ATI Radeon HD2900XT 1GB DDR4 512bits
Storage 5 HD's 160GB SATAII Seagate ST3860815AS 7200.10
Display(s) LG 22'' model 22LS4R
Case 3Rsystem's R810 with mod's for watercooler system
Audio Device(s) Supreme FX II
Power Supply ULTRA X3 1000W modular PSU
Software WINXP PRO SP3 x86
t_ski
Former Staff
11,960 (1.76/day)
Thanks. As for the reservoir, it was recommended to me to just use a T-line when I first started watercooling, as that reservoirs typically slow down the flow rate (more 90 degree bends).
Don't forget to vote guys :toast:
234 (0.04/day)
System Name NOS
Wait. U sad as reservoier slow down the flow? can u write the flow of water?
For me u install pump > rad > cpu > pump right? and the reservoier is in the middle of pump and rad
ask please
bye
t_ski
Former Staff
11,960 (1.76/day)
The flow goes from the pump > CPU > Rad > pump. That's all there is in the loop ATM. I have a Swiftech chipset block and an Alphacool MOSFEt block, but they aren't installed yet. Not sure if I'm going too yet...
234 (0.04/day)
System Name NOS
hummm now i see the problem u make a mistake when u install it
First u need refrigerate water for the cpu and not the inverse
when u sad that the reservoier slow down im think that u install wrong and now im right about my perception.
t_ski
Former Staff
11,960 (1.76/day)
Most reservoirs are a series of 90 degree bends. Any 90 degree bend will slow down the flow of water. I don't have a reservoir because of this, and do not intend on buying one. Thanks for your offer, though...
KennyT772
3,572 (0.52/day)
System Name Raptor
Processor Intel E8400 Wolfdale @3600
Motherboard Asus P5Q-Pro LGA775
Cooling Zalman CNPS9700
Memory 1024mbx2 Crucial Ballistix DDR800
Video Card(s) XFX 9600GT
Storage Seagate 7200.11 500GB
Display(s) Acer AL2216Wbd and Acer AL1717
Case Gigabyte 3DAurora Black
Audio Device(s) Creative X-Fi Extreme Gamer Faitality
Power Supply OCZ GameXStream 500w
T-Lines by design have more turbulence. As long as a reservoir is directly before the pump there is no impact on flow rate whatsoever. Completely closed systems are nearly impossible to create. Resivoirs however do make monitoring flow rate easier, by the water turbulence in the res. They also allow you to store more coolant, therby slowing the rate of heatup-cooldown of your pc. Say you had your pc outside overnight, down to 10c. With no res it may take 20 minutes for your coolant temp to level off. With a small res such as the swiftech unit, you can add a couple minutes to that. With the larger ones you can double or triple the amount of time your unit takes to heat up.
The number of blocks and radiators will have a much, much larger affect on flow rate. From there the design of your blocks and radiators have the most affect.
What you are missing though is all important overclocking results!!!
234 (0.04/day)
System Name NOS
KennyT772 is right! a T-line create a big turbulance if u can saw watercooling kits instaled look in case gallery u will see that reservoier makes much diference in a W.C kit and did u saw some oxigem bubles in the tubes? if u dont know T_lines are great for space economic but a disgrace to eliminate oxigem bubles and in u case u need to change u flow system becuse its wrong and many people here will agree with me and u wana insert more block´s and those block will slow down the flow as KennyT772 sad.
bye
KennyT772
3,572 (0.52/day)
System Name Raptor
bye
Attacking his setup based on what I said is uncalled for. I posted fact, not opinion. I suggest you do the same from now on. T-Line vs Reservoir vs enclosed is a statistically insignificant difference. You cannot base every single persons system on the whole population, as everyone likes something different.
This thread is for constructive criticism and comments, not bashing someone’s case due to personal preference.
234 (0.04/day)
System Name NOS
Its not "attacking" is a opnion and if u dont saw i mention here "T_lines are great for space economic but a disgrace to eliminate oxigem bubles and if u put more fluid the flow become more slow because the densyti of it
Much manufacturer of water cooling system says and show in theyers manuals first u need to pump water for radiator and not for CPU, reservoier is only use to mix and acumulate water and to make the pump work more easy.
bye ;)
11,119 (1.64/day)
System Name Apple Bite
Processor Intel I5
Motherboard Apple
Memory 40gb of DDR 4 2700
Video Card(s) ATI Radeon 500
Storage Fusion Drive 1 TB
Display(s) 27 Inch IMac late 2017
It looks fantasic and I would love to own it.
t_ski
Former Staff
11,960 (1.76/day)
316 (0.05/day)
Canuckistan
System Name Slave
Processor Core i7 920 @4.2 Lapped
Motherboard Biostar Tpower x58
Cooling Ek Supreme + Backplate, Thermochill 120.3, mcp655
Memory 6Gb Gskill Black Pi ddr3 1600 8-7-7-19 1t
Video Card(s) XFX R9 290 (flashed to 290x) + DTek Fuzion block @1100
Storage Samsung 840 evo, WD Black
Display(s) Asus PB278Q 1440p
Case p180b
Audio Device(s) Creative X-Fi Extreme P.O.S.
Power Supply Enermax Revolution 85+ 950watt
Benchmark Scores i7 920 c0 @ 4.6ghz
Really awesome work. It got a clean look, lot of airflow and is silent.
I can't ask for more... 10/10
cdawall
where the hell are my stars
27,680 (4.14/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
great job 10/10 :D
1,372 (0.21/day)
Chicago, IL
System Name Stealth 2 Duo Turbine
Processor Intel e6850 @ 3.8ghz
Motherboard Asus Striker Extreme
Cooling CoolerMaster V8 Modded With 2 white LED's & 100CFM fan
Memory OCZ DDR2 1066_ SLI Black-4GB
Video Card(s) 2xMSI 8800GT"s SLI
Storage <<HDD For OS>> 2x150GB_Western Digital Raptor_Raid 0. <<HDD For Storage>> 3 x 1TB
Display(s) ACER B273HU 27" LCD 2048x1152
Case Apex SuperCase_Custom 7 month Build
Audio Device(s) Striker Extreme Add-In Card HD-Audio
Power Supply EnerMax INFINITI 720watt
Software SE7VEN ULTIMATE 64bit
Benchmark Scores 3DMark01=NTTA, 3Dmark06=NTTA 3Dmark_Vantage=NTTA, Core Temp v0.99.5=28C
First, Awesome job on cutting the top, your system has a nice look to it with the rad on top, But I was wondering if the 3 fans on top are blowing cool or hot air into your case with the way you have it setup. what temps are you getting, I enjoyed looking thanks.
t_ski
Former Staff
11,960 (1.76/day)
According to Core Temp:
Stock (3.0 GHz) 24 idle, 37 load
OC'ed (3.6 GHz) 25 idle, 44 load
According to SpeedFan, the cores are @ 11C idle & CPU at 21C, but that's with the room at 22C, so it's obviously wrong. Motherboard temp is around 34 C.
With the loop, I have the fans pulling in cold air from the room through the radiator and into the case. When it's at idle, everything in the case is cool to the touch. If I had the fans pulling hot air out of the case I don't think temps would be as low, especially with how hot the 2900XT gets.
1,372 (0.21/day)
Chicago, IL
I would think if the water in the rad is warm it would blow hot,, like for a car with heat
t_ski
Former Staff
11,960 (1.76/day)
Only when the system is under load, which isn't very often, would the rad be warm and thus pushing warm air into the system. My comment above was about it being idle. Having a rad mounted like that leaves you with only two choices: pulling cool air into the case (making the case temps go up), or pulling warm/hot air from the case through the rad (making the CPU temps go up). Like I said, most of the time the CPU isn't under load, so for maximum cooling of the CPU I chose to pull air into the case.
3,288 (0.49/day)
Halifax, Canada
Processor Q6600 G0 @ 3.2Ghz
Motherboard Asus p5k-Premium/Black Pearl
Cooling Luna Block, 240mm rad
Memory Patriot Extreme PC2-6400 2x2GB
Video Card(s) Saphire 5850 1GB
Storage 60GB SSD + 2x500GB/1TB/2TB
Display(s) Samsung 226BW and 50" Panasonic S2
Case Silverstone TJ-09
Audio Device(s) X-fi Prelude
Power Supply Enermax Galaxy Dxx 850watt
Software Windows7 32Bit
Benchmark Scores Super Pi 1M 14.333
I like it alot, looks like you put quite a bit of work into it :p
I think you should try having the rear fan blow air in feeding cool air to the rad, Im not sure if the heat off the psu would get sucked in though.. some of it prob would. well when you add your gpu to the loop maybe try that out.
SMACK900
62 (0.01/day)
Melbourne, Australia
Processor Intel C2D E4300 @ 1.8Ghz, OC to 3.0Ghz
Motherboard Gigabyte 965P-DS3P
Cooling Thermaltake Big Typhoon VX, 6 x 120mm & 1 x 200mm Fans
Memory 4 x 512MB Corsair Twin2X 5400C4
Video Card(s) Gigabyte HD4850
Storage Seagate Barracuda 320GB 7,200
Display(s) Samsung 226BW & Optima DLP Projector
Case Antec900
Power Supply Hyper Type-R 580W
Software Windows XP SP2
Great water cooling setup, nice radiator mod, 9/10 from me
1,925 (0.30/day)
Processor Intel C2D E8500 @ 4.25GHz (1.36V)
Motherboard Gigabyte GA-X38-DQ6
Cooling (Temporary) Tuniq Tower 120
Memory 2GB Transcend aXeram 1200+
Video Card(s) HIS HD3870 CF Volt modded
Storage 3 Seagate 320Gb Barracuda in an Intel Matrix Raid array
Display(s) Sony GDM-FW900 24" Widescreen CRT (a.k.a "The Shiznotch")
Case Ultra Aluminus Full Tower
Audio Device(s) onboard Intel HD audio
Power Supply PC Power & Cooling Silencer 750
Software XP MCE + Vista (HP) dual-boot
Very clean! A build after my own heart!
Great job! 9/10
Bryan
t_ski
Former Staff
11,960 (1.76/day)
Hey Chewy - I have the fans pulling the air into the case through the rad, so all three fans are pulling in cool air. I have quite a bit of positive pressure inside the case, only having the PSU, the rear case fan and vents for exhaust.
285 (0.04/day)
System Name Dark Aurora
Processor Intel e6600 @ 4.09ghz
Motherboard ASUS Maximus Formula x38
Cooling Custom Water Cooling on Cpu and Gpu
Memory 4gb Corsair DDR-2 800mhz/ 2gb Patriot DDR-2 1066mhz
Video Card(s) XFX 8800gt 512mb
Storage 160gb Maxtor, 250gb Western Digital, 320gb Maxtor
Display(s) Dell 22" LCD
Case Gigabyte Aurora 570 (Black)
Audio Device(s) Audigy SE
Power Supply PC Power and Cooling 750W
Software Dual boot Windows XP/Fedora 8
Benchmark Scores AM3 201,045 Super Pi 12.453s @ 4.09ghz
Neohazard, I'm not sure where you get off saying that a t-line has more turbulence than a reservoir. By design a reservoir has water being forced into it and water being sucked out.
While I will agree that getting the air bubbles out of a loop with a t-line is a pain, by design a t-line works by allowing the free flow of water without any kind of restriction.
When you talk about how long it takes the water to heat up, it really doesn't matter. Most people don't run their systems for 10 minutes at a time and the let them sit for an hour to cool off.
Finally, the order in which you put components in the loop is of little consequence, after it has been run for a short period of time, the temperatures will stabilize for the most extent and temperature difference from any one point to the next are negligible. The flow of water is simply too fast for any given amount of water to absorb a statistically significant amount of heat. As a result having a "perfect order" in the loop MIGHT give you a degree or two of benefit.
/End rant/
In regards to the setup, props on the acoustic foam, never had the patience to do that clean a job with it.
Aside from that, maybe try cleaning up the wires a tad bit more and maybe some colored coolant.
8.5/10 = 9/10
