My computer has a issue
Real name here
5 (5.00/day)
My computer yesterday started to have a fan spinning at max speed any time I load up a game I checked all the case fans and the power supply what should I do?
My computers specs are
Ryzen 5 7600x
Ag620 wh
Msi b650 gaming motherboard
Corsair ddr5 6000mhz ram 2-16gb
Gigabyte 3080 ti
Kingston 2tb none
3.5inch 4tb wd hdd
2.5inch 1tb hdd don’t know the brand
1tb nvme in raid with 1tb hdd
Rm1000x power supply
6 ez diy pc fan
1 nzxt case fan
Lego brick gpu sag bracket
42,299 (6.65/day)
How old is the system, and does your screen go blank for any reason and remain blank?
Ryzen 5 7600x
Ag620 wh
Gigabyte 3080 ti
Kingston 2tb none
3.5inch 4tb wd hdd
6 ez diy pc fan
1 nzxt case fan
Real name here
5 (5.00/day)
The system is less than a year old and I did not check for my screen going blank I shut my computer as soon as that happened
6,806 (4.74/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Generic PS/2
Ryzen 5 7600x
Ag620 wh
Gigabyte 3080 ti
Kingston 2tb none
3.5inch 4tb wd hdd
6 ez diy pc fan
1 nzxt case fan
Fans going super high speed usually means that your CPU is getting hot. Double check the CPU cooler installation, see if you didn't forget to remove the plastic film - happens to the best of us. Also double check if fan orientation is correct - top and back fans should exhaust, bottom and front fans should be intake
If after doing this and temperatures are confirmed to be within acceptable range (as is, below 95C load) - go into BIOS and increase fan hysteresis or make a smoother curve manually
Real name here
5 (5.00/day)
This is my pc I already got told to check my cpu cooler and the curve the cpu is fine same with the power supply as I mentioned the case fans from what I know should be at a stuck 800rpm
6,806 (4.74/day)
São Paulo, Brazil
Fan orientation looks right. Try downloading HWiNFO64 and observe the CPU Diode temps when the fans spin up a lot. If this is above 90C, there's your problem. 800 rpm in most cases should be the "low speed" when temps are under control. You can lower this as low as 0 to 200 rpm on some motherboards
42,299 (6.65/day)
Make sure it's clean, refresh your thermal paste on cpu, reseat parts into motherboard, clear cmos and make sure your motherboard bios is latest, also any fan software in the os make sure it is set to factory defaults
Real name here
5 (5.00/day)
I don’t really feel comfortable turning my pc on when the fan goes 100% and I don’t know the problem I also don’t think it it the cpu
97 (0.33/day)
Canucksland
System Name Main / HTPC / Server
Processor i5 14600K / Ryzen 5 2400G / i7 7700K
Motherboard Z790 PRO RS / B450M Mortar / Z270 IX Code
Cooling AS500 PLUS WH / Wraith Stealth / NH-D15
Memory 32GB 6000 C30 / 8GB 2666 C16 / 32GB 3000 C15
Video Card(s) GTX 780 (temporary) / iGPU / iGPU
Storage (OS) 1600X 118GB / V200 120GB / 850 EVO 250GB
Display(s) Predator XB271HU / KDL-55W950B / VH238H
Case Eclipse P400S / LC13-BU / Define R5
Audio Device(s) Xonar U7 (HD 598) / Xfi Titanium (Azur 851A)
Power Supply Prime Titanium 750W / M12II EVO 620W / AXi 860W
You said A fan starts spinning up… have you isolated that fan?
2,964 (0.52/day)
MN
System Name Personal / HTPC
I've had a GPU where the fans would just spin up to 100% for no rhyme or reason. If the case fans were full speed they didn't even come close to matching the sound the GPU fans made when full speed.
Ruru
S.T.A.R.S.
12,818 (2.93/day)
Jyväskylä, Finland
System Name 4K-gaming / media-PC
Processor AMD Ryzen 7 5800X / Intel Core i7-6700K
Motherboard Asus ROG Crosshair VII Hero / Asus Z170-A
Cooling Arctic Freezer 50 / Thermaltake Contac 21
Video Card(s) RTX 3080 10GB / RX 6700 XT
Storage 3.3TB of SSDs / several small SSDs
Audio Device(s) Creative Omni BT speaker
VR HMD Oculus Rift CV1
My fans also ramp up when playing something demanding, nothing special there. Like mentioned above, how are the temps? Nothing's gonna break since CPUs/GPUs throttle down if things are going too sweaty.
Frick
Fishfaced Nincompoop
19,593 (2.86/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
You have to. Could be something is mounted poorly. Download HWinfo or HWmonitor (personally I prefer HWMonitor), run something that makes the fans ramp up, alt tab out and look at max temps. And as Ruru said, you can't really damage anything because the system will slow itself down if it gets too hot. It could just be that the GPU fan is loud.
