my computer isn't work always beep memory problem!
169 (0.11/day)
I have
Asus Prime H410M-K mATX
as mainboard I am trying to connect
G.Skill Aegis 2x8GB 3000Mhz DDR4 CL16 Kit
and it doesn't work how can I fix this?
23,102 (6.10/day)
Beep memory problem?
You can find what a beep code means in your motherboard manual. Might want to check that out first.
Also try running the system with a single stick of RAM, try different slots as well.
120 (0.08/day)
System Name Howling_Fjord
Processor Intel Xeon E5 2640 v3 @ 3398.39 MHz
Motherboard Huananzhi X99-F8
Cooling Cooler Master MasterAir MA410P, Fans Corsair AF120
Memory 16Gb (2x8) Micron Technology + 32Gb (2x16Gb) P/N: atermiter
Video Card(s) AMD Sapphire TOXIC R9 280X OC, EVGA GTX 1070 SC ACX 3.0
Storage SSD NVMe 250Gb +NVMe 1Tb + 2x 2Tb HDD+ SSD 1TB KingDian +SSD 240Gb
Display(s) Samsung 7.2 inches (18.3 cm) / 1280 x 720 pixels @ 23-60 Hz
Case Mymax Full Tower Horus black
Audio Device(s) -
Power Supply Cougar Gx 800W 80Plus Gold
Mouse -
Keyboard -
Software Microsoft Windows 10 (10.0) Enterprise LTSB 64-bit
Benchmark Scores https://valid.x86.fr/h7nzby https://gpuscore.top/furmark/show.php?id=328097
Well, there is two possibilities i can think of:
1. Either your RAM or your Mobo is not working (Highly unlikely since i presume that they're new)
2. Your Mobo is not compatible with the RAM you bought, from a quick search I found this:
You can even check the QVL of the motherboard to see if your RAM is supported
this is his motherboard users manual, the beep codes was supposed to be here right?
23,102 (6.10/day)
That's what I would expect but skimming through the thing, I don't see it!
I think its generic for all Asus products:
120 (0.08/day)
Audio Device(s) -
Mouse -
Keyboard -
if this is correct now the OP needs to tell us what the beep code was, i did not found his memories on the QVL of his motherboard.
The memory being 3000Mhz shouldn't be a problem since it'd just run at 2933Mhz, and there is lots of memories that are not in the QVL but work anyways, that list only matters to see what would absolutely work 100% sure.
467 (0.14/day)
South Africa ,Lions Everywhere..
System Name Ground Control
Processor Intel i5 2500k 4 Ghz
Motherboard MSI P67A-GD80 B3
Cooling Cooler Master Hyper 212x
Memory 2 x 4GB DDR3 1600mhz Apacer Black Panther
Video Card(s) Msi GTX 1060 OC 3Gb
Storage 2 x 250Gb WD Blue raid 0 + 1Tb Wd Green
Display(s) Samsung BX2450 24" Led
Case GMC X7 X-Station
Power Supply HEC Raptor 500watt
Mouse Logitech G9
Software Windows 8.1
Benchmark Scores Power Level over 9000
Judging by first post this isn't going to go anywhere
120 (0.08/day)
Audio Device(s) -
Mouse -
Keyboard -
169 (0.11/day)
if this is correct now the OP needs to tell us what the beep code was, i did not found his memories on the QVL of his motherboard. it shoudn'
I bought two cards 8X2 3000mhz
9,340 (5.17/day)
Louisiana
Keyboard G710+x3
120 (0.08/day)
Audio Device(s) -
Mouse -
Keyboard -
3000 is not on the supposed speed list.
yeah, but it should work fine at 2933Mhz, normally these memories work at the fastest speed they can.
the strange thing here is that they don't work at all, i'd call the manufacturer and explain the error, probably this ram is just not compatible with the mobo, otherwise something is very wrong here
169 (0.11/day)
I fix it thank anyway
it work ok 2666mhz cpu limit 10400f
120 (0.08/day)
Audio Device(s) -
Mouse -
Keyboard -
