My computer will not shut down, it reboots instead.
15 (0.03/day)
System Name Mine
Processor Ryzen 3700x
Motherboard Gigabyte Aorus Elite
Cooling Watercooled, Alphacool and EKWB
Memory 32 Gb G.skill Flare X
Video Card(s) XFX RX 6700XT
Storage 2 Samsung 980 Pro 1Tb nvme, 1 Samsung 860 evo 1 Tb
Case Be Quiet! Silent Base 601
Like the titel says, my computer reboots instead of shutting down, but I can turn it off by pressing the startbutton 4 secs. (I usually turn it off with the PSUbutton)
Hardware:
X570 Auros Elite motherboard with bios version F40d, and newest AMD chipset drivers.
RX 5800X
Seasonic Focus GX-850
XFX SWFT 309 RX 6700 XT, newest driver.
G.Skill TridentZ neo DDR4 4000 (F4-4000C18D-32GTZN) 2x16GB
2XSamsung 980 PRO 1TB NVME
1XSamsung 960 EVO 1TB SSD
Windows 11 Pro, 24H2
It has been like this for 6 months now...
I have reinstalled w11 three times.
I have turned off fast startup, hibernation.
I have also tried without anything connected, except keyboard, 4 different ones, and nothing else connected than a screen, tried 3 different ones there also, both DP and HDMI,
I have unplugged everything inside, and cleaned connectors everywhere, so I have unplugged the gfxcard and tried with another, the disks, and tried with another, the USBconnecctors inside, the frontpanelwires, tried different memorysticks, you name it, I have done it....
Pls point me in the right direction?
42,602 (6.67/day)
Replaced power switch? Make sure windows is set to shut down when shutdown is pressed whether in windows or case itself (power properties)
140 (1.04/day)
Michigan, United States
Processor Intel i7-13700K
Motherboard Asus ROG Strix Z690-E Gaming
Cooling NZXT Kraken Elite 360
Memory G.Skill Trident Z DDR5-6400
Video Card(s) MSI RTX 4090 Suprim X Liquid
Storage Western Digital SN850X 4Tb x 4
Case Corsair 5000D Airflow
Audio Device(s) Creative AE-5 Plus
Power Supply Corsair HX-1200
Software Windows 11 Pro 23H2
Clear CMOS / update BIOS? Faulty motherboard? 100% certain you've got the case cables (power / reset switch, power LED etc.) connected to the motherboard header correctly?
777 (0.11/day)
GA, USA
System Name Gamer
Cooling Apogee XL, MCR360, MCP655, Micro-rez
Video Card(s) Red Dragon RX 6800 XT
Case Rocketfish (Lian Li) e-ATX
Audio Device(s) Harman Kardon HK695 2.1
Power Supply Seasonic Focus GM-750
Mouse HP Gaming wired
Keyboard Logitech G110 wired
VR HMD HP WMR 1440^2
Software Win10 Pro 64bit
Do you have an HP printer on the network? Jays2cents did a video about his HP printer sending constant wake-on-lan requests to one of his PCs.
15 (0.03/day)
System Name Mine
I replaced the powerswitch, ordered it from Be Quiet.
I have cleared cmos, reflashed bios, in case of corruption, and removed the battery for 24h, and, yes, I have disconnected every contact on the mobo, and reconnected them, several times....
OMG!
This I have to check!
777 (0.11/day)
GA, USA
System Name Gamer
3,578 (1.85/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 200W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3667MT/s 1.42V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2605), upgraded from Win10 to Win11 on Jan 2024
OMG!
What happens if you press Alt+F4 (while on desktop) and select "Shut down" from the drop down menu (and then click "Ok" or press "Enter")...?
I always turn off my PC this way, many years now.
