My CPU is fine? I get lower points in cinebench r23
169 (0.13/day)
1.5 years ago i had multi 15200 points and 1950 single
and i see my ponts in cinebench after 1.5 years get lower to 14300 multi and 1880 single after clean my fans and replace Thermal cream i get now a lillte bettter
up to 14650 multi and 1940 single I add a picture see see the current
Do you think i have a problem with my pc? or cpu?
because its a big gap after clean and if yes What could be a problem do I need to complain to store? please help thx
note :I have been undervolting all cores by 35 in the past and continue to do so today.
2,769 (1.51/day)
System Name Not a thread ripper but pretty good.
Processor Ryzen 9 5950x
Motherboard ASRock X570 Taichi (revision 1.06, BIOS/UEFI version P5.50)
Cooling EK-Quantum Velocity, EK-Quantum Reflection PC-O11, EK-CoolStream PE 360, XSPC TX360
Memory Micron DDR4-3200 ECC Unbuffered Memory (4 sticks, 128GB, 18ASF4G72AZ-3G2F1)
Storage Samsung 2TB 980 PRO 2TB Gen4x4 NVMe, 2 x Samsung 2TB 970 EVO Plus Gen3x4 NVMe, AMD Radeon RAMDisk
Power Supply Corsair RM750x
Mouse Logitech M575
Benchmark Scores Typical for non-overclocked CPU.
What thermal cream are you using?
1,985 (0.36/day)
Heart of Eutopia!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
is the hardware clean or dusty and what cream - love that
113 (0.12/day)
Processor Intel i5 9400f
Motherboard MSI Z390 Gaming Plus
Cooling SilentiumPC Fera 3
Memory 2x 8GB Corsair Vengeance LPX 3200 16-18-18-36
Video Card(s) MSI GTX 1660 Super Ventus XS OC
Storage 500 GB Kingston A2000; 1 TB Kingston A2000; 1 TB HGST Travelstar
Display(s) AOC 24G2U
Case SilentiumPC Signum SG1
Audio Device(s) Creative Pebble Plus; Logitech G533
Power Supply beQuiet Systempower 9 500W
Mouse Logitech G403 Hero
Keyboard HyperX Alloy Origins (Red)
What cooler are you using and what temps do you get? Since it is summer now (assuming you are from the northern hemisphere) means increased room temperature which can result in lower clocks if your cooling solution is already struggling. Alternatively more background apps can interfere with the benchmark as well, so try shutting down everything that isn't vital and see how high the scores can get.
4,766 (3.87/day)
Colorado, U.S.A.
Power Supply EVGA 500W1
Software Windows 11 Home
Down by just 4%, could easily be background tasks
I'd not worry at all, and certainly not complain to the store.
169 (0.13/day)
the same one i used 1.5 years ago mx4
the same cooler pa 120 se
6,689 (1.46/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW | Sapphire PULSE RX 590
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
cinebench changes versions over the years... and everytime you run it you will get a varying result everytime
A few points less means you need to toss your cpu in the garbage with that reasoning
2,769 (1.51/day)
Mouse Logitech M575
Oh, actually that's a paste. You might want to try a fresh batch of mx4 and/or double check your mounting pressure of your cooler.
Also 1.5 years is a lot of time for UEFI/BIOS and Windows updates to nerf performance a little as they try to fix bugs and security patches.
I don't recognize a "pa 120 se" cooler. Is that an AIO? AIO's may loose some effectiveness over time from liquid loss.
5,552 (4.21/day)
SĂŁo Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Galax Stealth STL-03
5,200 (0.89/day)
System Name [Daily Driver]
Processor [Ryzen 7 5800X3D]
Motherboard [Asus TUF GAMING X570-PLUS]
Cooling [be quiet! Dark Rock Slim]
Memory [64GB Corsair Vengeance LPX 3600MHz (16GBx4)]
Video Card(s) [PNY RTX 3070Ti XLR8]
Storage [1TB SN850 NVMe, 4TB 990 Pro NVMe, 2TB 870 EVO SSD, 2TB SA510 SSD]
Display(s) [2x 27" HP X27q at 1440p]
Case [Fractal Meshify-C]
Audio Device(s) [Steelseries Arctis Pro]
Power Supply [CORSAIR RMx 1000]
Mouse [Logitech G Pro Wireless]
Keyboard [Logitech G512 Carbon (GX-Brown)]
Software [Windows 11 64-Bit]
I swear benchmarks only exist to confuse the uninformed and to sell new products.
Stop worrying about your benchmark results.
1,257 (2.27/day)
System Name KLM
Motherboard B-650E-E Strix
Video Card(s) 4070-ti PNY
Storage 512+512+1+2+2+2+2+6+500+256+4+4+4
Case 4000D Airflow
Power Supply Shift 1000
Mouse 502 Hero
Keyboard K68
Software EMDB
Benchmark Scores 0>1000
Yes, the only bench that'll be usefull is the one launched from ingame menu of some games, it outputs FPS info so you can find options prefs that match.
746 (2.85/day)
Woodstock IL
Processor 13700K
Motherboard MSI Z690 D4
Cooling Air/water/DryIce
Memory Corsair 3600mhz something die cl18 at 4000mhz
Video Card(s) RX 6700 XT
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Power Supply Antec 850w Continous Power Series (since 2009)
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Benchmark Scores Max Freq 13700K 6.7ghz DryIce. Max all time Freq FX-8300 7685mhz LN2
Only true for certain BS benchmarks. Many benchmarks are actually extremely accurate and sensitive to changes. Such as Cinebench. Anything using background tasks could skew the score. And cinebench is considered accurate and consistent. So it's a viable way to measure performance.
It would be more helpful to inform the user some facts about benchmarking and how to achieve better results.
Toothless
Tech, Games, and TPU!
9,457 (2.50/day)
Washington, USA
System Name Veral
Processor 5950x
Motherboard Asus Crosshair VIII Hero Wi-Fi
Memory 2x16GB G.Skill TridentZ
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
6,689 (1.46/day)
Florida
Storage Various
169 (0.13/day)
but in past it was like benchmarks
and i compare to my past it was a lot more
Salve,ointment,lotion, etc
Pick your topical
and again i replace lotion and clean cooler
210 (0.61/day)
System Name Favourite toy(s)
Processor Ryzen 5 7600X lapped @ Custom PBO boost & Ryzen 7 7700 @ stock
Motherboard Asrock X670E Steel Legend / Gigabyte B650 Aorus Elite
Cooling Deep Cool AK620 / Stock cooler
Memory G.Skill F5-5600J3036D16GX2-FX5 / Corsair Vengeance CMH32GX5M2B5600C36
Video Card(s) Asus TUF gaming RX 7900 XTX OC edition / iGPU
Storage 1 + 2TB T-Force Cardea A440 pro / 2 x Kingston KC3000 1TB
Display(s) Asus TUF Gaming VG34VQL3A / Samsung C32G55TQWE
Case MSI MPG Sekira 100R / Silverstone Redline mATX
Audio Device(s) Asus Xonar AE 7.1 + Audio Technica -AD500X / Onboard + Creative 2.1 soundbar
Power Supply Corsair RM1000x V2 / Corsair RM750x V2
Mouse MSI Clutch GM20 Elite / CM Reaper
Keyboard Logitech G512 Carbon / MSI G30 Vigor
OP, do a fresh install of windows (vanilla) & latest drivers for your hardware, test again.
746 (2.85/day)
Woodstock IL
Processor 13700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
Well, you probably have made changes to the software during the past 1.5 years that would use resources, or at the time of running the benchmark again more recently, something was going on in the background.
So to help, I'll give a starting pointer or two..
Double check the system settings are the same as 1.5 years ago and confirm. (for this case)
Disable windows update or "pause" it.
Secondly I turn off wifi
Then third open task manager and close user installed background tasks. (Like AMD noise suppression as an example.)
Closing all other programs on the task bar.
Disable system notifications
Disable system alerts
You can also use some windows based utilities to aid in benchmarking performance.
Such as Quick Cpu. This one will clean stacked memory and control core parking.
You can adjust performance and power settings pretty much on the fly, but all 3 individually.
Much of this should help with your scores. Probably cover the 1000 points you're missing maybe more.
169 (0.13/day)
i have the latest windows and drivers
But 6 mothns ago i did format to windows its not so old
923 (0.56/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Altec Lansing
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
You can not verify a CPU with a windows based software. Only via specific hardware level tools (which you cant access) can detect abnormalities.
Toothless
9,457 (2.50/day)
Washington, USA
System Name Veral
Processor 5950x
VR HMD HP Reverb G2
Is your PBO enabled/auto in bios? Memory profile (XMP/EXPO) enabled? Fan curve change anywhere?
627 (1.21/day)
System Name BarnacleMan
Processor 14700KF
Motherboard Gigabyte B760 Aorus Elite Ax DDR5
Cooling ARCTIC Liquid Freezer II 240 + P12 Max Fans
Memory 32GB Kingston Fury Beast 5600 cl36
Video Card(s) Asus Tuf 4090 24GB
Storage 4TB sn850x, 2TB sn850x, 2TB Netac Nv7000 + 2TB p5 plus, 4TB MX500 * 2 = 18TB. Plus dvd burner.
Display(s) Dell 23.5" 1440P IPS panel
Case Lian Li LANCOOL II MESH Performance Mid-Tower
Audio Device(s) Logitech Z623
Power Supply Gigabyte 850w
Mouse Some piece of shit from China
Keyboard Some piece of shit from China
Software Yes Please?
Is it possible you disabled anti-virus the first time and not this time?
2,769 (1.51/day)
Mouse Logitech M575
21,046 (3.40/day)
System Name Pioneer
Processor Ryzen R9 7950X
Case Thermaltake Core X31
Honestly this is well within margin of error and microcode changes over time.
Nothing to worry about.
