My CPU reaches 81 degrees Celsius after playing GTA V for 3 minutes!Please help me!
313 (0.11/day)
Hi to all,
I am a bit concerned about my CPU,it reached 81 degrees Celsius after playing GTA V for 3 minutes!
I use ThrottleStop and I have undervolted my CPU.
My laptop's model is Lenovo Ideapad Y-700-15ISK ,and the CPU is i7-6700 HQ @ 2.60 GHz up to 3.50 GHz.
Please help me!
Thanks to all in advance!
Here are screenshots from the ThottleStop configuration for the Game profile and the CPU undervolting:
43,545 (6.77/day)
1. You are on a laptop, a business 1,they have garbage cooling and cramped space
2. Your room temperatures determine how cool any computer runs.
You have 6 choices.
Read a Book on how to build, troubleshoot and repair pcs and laptops.
Safest bet would be to take to a shop.
Get a laptop cooler.
Get a Gaming Laptop.
Build a Gaming PC.
Did I mention, Take to shop.
Quit screwing with computers and get a Console.
313 (0.11/day)
1.My laptop is a gaming laptop
2.I already use a cooling pad
And I have never had problems with CPU overheating!
Please tell me how to configure ThrottleStop,to use the SpeedShift feature not the Speedstep feature!
2,357 (0.45/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
Are you hitting 81 with or without Throttlestop running? Assuming throttlestop isn't running. Go down the list. Make sure airflow isn't the issue: check that the the vents are clean and unobstructed; fan is running properly and aren't broken.
43,545 (6.77/day)
Deselect speedstep
313 (0.11/day)
I got 81 degrees Celsius with ThrottleStop running.
The airflow isn't the issue,the vents are clean and the fans are fine too.
10,984 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 1:1 CL30-36-36-96 FCLK 2000
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply RIP Corsair SF750... Waiting for SF1000
Keyboard 65% HE Keyboard
dude just build the crappiest gaming rig possible and it will be miles better than that laptop.
consoles are for wussies.
dorsetknob
9,106 (1.25/day)
CPU and GPU should not be on the same heat pipe as the CPU has to deal with a 960m's heat out put as well as its own.
Cranking software settings to lower temps will just have you posting complaining of lost performance
Man up and get a desktop as this laptop is always causing you to post problems here
2,357 (0.45/day)
System Name Miami
They're on the same pipes.
@OP, the throttling is what is keeping your CPU from cooking itself, since you've removed that limitation it's going to proceed to go ahead and cook itself. Not sure what you want us to do for you.
43,545 (6.77/day)
He is trying to fix a performance problem and keep temps down, not possible in todays laptops.
He constantly is posting problems with this laptop and he needs to cut it out. He needs to just swallow his pride and build a desktop that is not limited by cooling.
313 (0.11/day)
I would like to configure the SpeedShift properly as my CPU is Skylake!
43,545 (6.77/day)
Do it in the bios. If there is no setting, that means it is not supported.
23,228 (6.11/day)
STAHP! Please.
This laptop is simply at its limits and won't perform better or run cooler. Accept it and move on...
FireFox
The Power Of Intel
7,507 (1.87/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
2018 and still using Laptops?:shadedshu:
12,333 (2.24/day)
Oregon
Keyboard EVGA / Logitech K400
Lower your ambient temps.
23,228 (6.11/day)
Fan-tastic but a laptop CPU at 81 C is not an issue in the first place.
396 (0.12/day)
System Name 06/2023
Processor R7 7800X3D
Motherboard ROG STRIX B650E-I GAMING WIFI
Cooling Custom 240mm cooling (for CPU) with noctua nfa12x25 and Phantek T30
Memory 32gb Gskill 6000 CL30
Video Card(s) RTX 4070 dual asus deshrouded with 120mm NF-A12x25
Storage 2tb samsung 990 pro + 4tb samsung 870 evo
Display(s) Asus 27" Oled PG27AQDM + Asus 27" IPS PG279QM
Case Ncase M1 v6.1
Audio Device(s) Steelseries arctis pro wireless + Shure SM7b with Steinberg UR
Mouse Corsair scimitar pro (this mouse need an overall guys pls) + Logitech G Pro wireless with powerplay
Keyboard Sharkoon purewriter
Software windows 11
Benchmark Scores Over 9000 !
That's not a gaming laptop
THIS is a gaming laptop :
A gaming laptop is THICK and HEAVY because it need COOLING for high performance hardware.
266 (0.10/day)
Processor Intel core i5 4590s
Motherboard Asus Z97 Pro Gamer
Cooling Evercool EC115A 915SP Cpu cooler,Coolermaster [200mm (front and top)+140mm rear]
Memory Corsair 16GB(4x4) ddr3 CMZ16GX3M4X1600C9(Ver8.16)(XMP)
Video Card(s) MSI GTX 970 GAMING 4G
Storage Western Digital WDC WD2001FAS 2TB Black, Toshiba DT01ACA100 1TB
Display(s) LG Flatron L177WSB
Case Coolermaster CM Storm Enforcer
Audio Device(s) Creative A550 Speakers 5.1 channel
Power Supply SuperFlower Leadex 2 Gold 650W SF-650F14EG
Mouse PLNK M-740 Optical Mouse
Keyboard ibuypower GKB100 Gaming Keyboard
Software Windows 7 Sp1 64 bit
I used to and sometimes still game on my Samsung np550pc it has a i7 3610hq and 630m on it. I have played modded skyrim on high and crysis 3 (on medium except for the first rainy section that was on low) to mention a few...before that I had a dell xps with a 435m that I used to overclock to play with. my point is that gaming on a laptop is not impossible I did it well on media pcs before I built a desktop...but you must be realistic about your machine performance and how best to maximise it. in my case I would limit cpu power in windows on my Samsung to max at 2ghz and temps would top at 80c without a laptop cooler for the duration of the gaming session so ur temps are not abnormal tbh that's how gaming on some games will be with you ....just thought my experience would reassure you of what to expect, in general if you have a problem with a pc fix it but if the problem is the pc replace it. u lie in the latter of that situation and also being on a desktop does not eliminate thermal issues...the numbers just get smaller
rtwjunkie
PC Gaming Enthusiast
14,027 (2.32/day)
Louisiana
Processor Core i9-9900k
I disabled Speedstep, and set Speedshift and now the CPU doesn't go above 70 degrees Celsius!
Maybe that is not the solution,but it works now.
That’s pretty good for temperatures. I know some answers may have sounded harsh, but they are also mostly true. Things are going to heat up quickly in a laptop, and even with a laptop cooler the biggest factor will be ambient temperatures. Ambient is the temperature of the room your laptop is run in.
80 and 71 may seem alarming, but it is normal in your situation. Intel does know what they are doing. The thermal limit designed into your i7-6700hq is 100. It will throttle itself to keep from getting that hot if allowed to.
FireFox
The Power Of Intel
7,507 (1.87/day)
Germany
Of course it's not but sometimes is more headaches than the fun you have when playing.
23,228 (6.11/day)
Well said @rtwjunkie
Frame of reference: my 8700K @ 4.8 can peak into the 85-87 C regions - on a desktop with a *massive* dual stack tower cooler on it. Similarly GPU max load temps can hit as high as 82-84 C.
5,459 (0.88/day)
Australia
I have the exact same laptop but with the i5 in it and it never over heats but I think 81c is a good temp flat out really compared to more modern gaming laptops with 7700 or 8XXX that hit 90+ all the time!.
313 (0.11/day)
I have the exact same laptop but with the i5 in it and it never over heats but I think 81c is a good temp flat out really compared to more modern gaming laptops with 7700 or 8700 that hit 90+ all the time!.
And it is declared as a true gaming laptop as I said,right?
6,270 (0.90/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
I have a similar laptop to yours and it's the one in my "system specs " and what i have done to keep the temps down is one I have a laptop cooling pad and I used XTU https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU- to under volt my i5 6300hq by .150 volts and I run ,my laptops system fans at 100% while gaming and i can normally keep it under 78 cels as long as it under 26.66 cels ambient temperatures and NO vsync......when it is over 26.66 cels Ambient temperatures then i also activate Vsync with in the game and then it runs whisper cool! Also worth noting if you see your CPU dropping down to like .800GHZ under load and the temps are under 82 cels then the system probably kicked in the C state because the mobo VRM's got too hot and this normally happens when the system fans where NOT turned upto 100% before gaming...good luck with the gaming and temps!
