- Feb 15, 2009
- 645 (0.11/day)
- Norway, which means Amazon is not available...
System Name | Winter v3.2024 |
Processor | Intel i7 12700K (since november 2021) |
Motherboard | Gigabyte Z690 Gaming X (since november 2021) |
Cooling | Air Liquid Freezer II 360 with LGA1700 kit (since november 2021) |
Memory | Crucial Ballistix 2x16gb 3600mhz C16 (since november 2021) |
Video Card(s) | Gigabyte RTX 3060 Ti Gaming OC Pro LHR - Rev3.0 (since july 2022) |
Storage | 1x 1TB WD Blue SN570 SSD, 1x Seagate 4TB SATA |
Display(s) | 1x 55" LG C1 4k OLED, 1x Gigabyte 32" M32Q and 2x AOC 27" CG1 |
Case | Fractal Design Define R6 (since 2018 and still working like a charm!) |
Power Supply | Corsair RM850x black (since august 2022) |
Mouse | Razor Deathadder v2 (since december 2021) |
Keyboard | Varmilo VEA109 v2 MX Silent Red (since august 2022) |
Software | Windows 11 Pro |
I recently discovered an A-M-A-Z-I-N-G program named "FanControl" that gives me total control on my cpu, case and gpu fans! I've been playing around with it for a little now, and it seems like my pc is running as quietly as a silent movie!
However, since im a newbie at this, i thought i'd ask you lot what you reckon about my fancontrol setup and configurations? Anything i should modify/change/add, or? Are some of the fans running at a too low/high speed/percentage, or?
I use my pc (check my specs list) for multi-browsing, streaming, some video rendering, video editing and slight/easy gaming (Assetto Corsa, FIFA etc.), if that's relevant to all this.
Here i have included screenshots of my setup + graph setups for my cpu and gpu temps:
CPU temp:
GPU temp:
CPU temp:
GPU temp:
