My First PC Build – Intel vs AMD for Work and Gaming
hmn888
1 (1.00/day)
Hello everyone,
I’m planning to build my first PC and have put together two parts lists while waiting for good deals.
The PC will be primarily used for work with Adobe programs (especially After Effects) and some 3D work.
I also enjoy gaming, so I want to build a system that can handle both tasks efficiently.
I’m undecided between an AMD or Intel CPU. I’m leaning towards Intel since I’ve always used Intel processors.
However, I’ve heard a lot about issues with the latest 13th and 14th generation Intel CPUs. Are these issues resolved now?
Can I confidently build a stable system with Intel after applying BIOS updates and undervolting?
I haven’t found much solid information on this, and most discussions are either “Intel is bad” or “AMD is the better choice.”
I would love to hear from experienced people about their thoughts on this. Also, I’d appreciate any feedback on the rest of
the components in my build. Below are the two parts lists I’ve put together. My budget is around 2,000 Euros.
Intel System:​
https://de.pcpartpicker.com/list/rq26sp
  • CPU: Intel Core i7-14700K 3.4 GHz 20-Core Processor
  • CPU Cooler: be quiet! Pure Loop 2 Liquid CPU Cooler
  • Motherboard: MSI PRO Z790-P WIFI ATX LGA1700
  • Memory: Corsair Vengeance 64 GB (2 x 32 GB) DDR5-6000 CL30
  • Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 NVMe
  • Video Card: Gigabyte WINDFORCE OC GeForce RTX 4070 Ti SUPER 16 GB
  • Case: be quiet! Silent Base 802 ATX Mid Tower
  • Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Fully Modular
AMD System:​
https://de.pcpartpicker.com/list/R4LdXR
  • CPU: AMD Ryzen 9 7900X 4.7 GHz 12-Core Processor
  • Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5
Which system would you recommend based on a balance of gaming and productivity?
Also, if you have any insights on the CPU choice or potential issues with either, I would love to hear them.
Thanks in advance for your help!
dgianstefani
TPU Proofreader
5,032 (1.99/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front, LINKUP Ultra PCIe 4.0 x16 white
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Benchmark Scores Legendary
Both of these are outdated.
If you can, wait for RTX 50xx release, if you can't, then this is a better option, or wait for 9800X3D to come down in price.
PCPartPicker Part List: https://de.pcpartpicker.com/list/WXvsZc
CPU: AMD Ryzen 7 9700X 3.8 GHz 8-Core Processor (€332.96 @ Caseking)
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler (€34.90 @ Amazon Deutschland)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard (€152.89 @ Mindfactory)
Memory: Corsair Vengeance 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory (€213.66 @ Amazon Deutschland)
Storage: Samsung 990 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€141.89 @ Alternate)
Video Card: Gigabyte WINDFORCE OC GeForce RTX 4070 Ti SUPER 16 GB Video Card (€846.99 @ notebooksbilliger.de)
Case: be quiet! Silent Base 802 ATX Mid Tower Case (€160.90 @ Galaxus)
Power Supply: be quiet! Dark Power 13 750 W 80+ Titanium Certified Fully Modular ATX Power Supply (€187.98 @ Mindfactory)
Total: €2072.17
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2024-11-27 00:16 CET+0100
30 (0.20/day)
The thing with Intel is it needs a lot of power, especially with all cores active, and you absolutely must update your BIOS immediately when you get your motherboard or else the chip will self destruct. From a performance standpoint I think the Intel CPU edges out the 7900x, but you need to double check that with reviews and you also need to find reviews with your productivity applications. It is probably best to look at reviews for recent CPUs for the performance of the CPUs you are looking at rather than the reviews dedicated to them.
384 (0.86/day)
USA
System Name Dark Palimpsest
Processor Intel i9 13900k with Optimus Foundation Block
Motherboard EVGA z690 Classified
Cooling MO-RA3 420mm Custom Loop
Memory G.Skill 6000CL30, 64GB
Video Card(s) Nvidia 4090 FE with Heatkiller Block
Storage 3 NVMe SSDs, 2TB-each, plus a SATA SSD
Display(s) Gigabyte FO32U2P (32" QD-OLED) , Asus ProArt PA248QV (24")
Case Be quiet! Dark Base Pro 900
Audio Device(s) Logitech G Pro X
Power Supply Be quiet! Straight Power 12 1200W
Mouse Logitech G502 X
Keyboard GMMK Pro + Numpad
For productivity, the 9700x only keeps up with 7900x if you run PBO to the max. That said, you can run the 7900x with PBO and CO and get in front again. The 9700x will be a little faster in games though (but depending on the game and resolution, they may perform exactly the same).
You'll notice that the 14700k wins in after-effects and trades blows elsewhere. Depending on how you clock things, you should be happy with any of these options, honestly. As for the Intel issues...it'll draw more power in workloads, but if you update the bios there shouldn't be any risks or issues with it. Not really a concern anymore.
562 (1.70/day)
Seattle
System Name DevKit
Processor AMD Ryzen 5 3600 ↗4.0GHz
Motherboard Asus TUF Gaming X570-Plus WiFi
Cooling Koolance CPU-300-H06, Koolance GPU-180-L06, SC800 Pump
Memory 4x16GB Ballistix 3200MT/s ↗3800
Video Card(s) PowerColor RX 580 Red Devil 8GB ↗1380MHz ↘1105mV, PowerColor RX 7900 XT Hellhound 20GB
Storage 240GB Corsair MP510, 120GB KingDian S280
Display(s) Nixeus VUE-24 (1080p144)
Case Koolance PC2-601BLW + Koolance EHX1020CUV Radiator Kit
Audio Device(s) Oculus CV-1
Power Supply Antec Earthwatts EA-750 Semi-Modular
Mouse Easterntimes Tech X-08, Zelotes C-12
Keyboard Logitech 106-key, Romoral 15-Key Macro, Royal Kludge RK84
VR HMD Oculus CV-1
Software Windows 10 Pro Workstation, VMware Workstation 16 Pro, MS SQL Server 2016, Fan Control v120, Blender
Benchmark Scores Cinebench R15: 1590cb Cinebench R20: 3530cb (7.83x451cb) CPU-Z 17.01.64: 481.2/3896.8 VRMark: 8009
Uh the parts aren't what I call outdated but that list certainly is. To start, good luck picking up either of those chips.
If your thing is going to mainly focus on gaming, pick up an entry level X3D that offers the best possible performance and you're solid.
If you're doing basic streaming it's also good but overclock or load up on more cores.
If you're doing gaming and game development or some kind of rendering that is sometimes high compute workload, load up on non-X3D cores and high core clock.
The rest is cake.
1,646 (1.08/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
If you mostly use After Effects with Multi-Frame Rendering, you will benefit from having 12 or more cores. 3D rendering on the CPU will also gain from increased core count.
With gaming as your other priority, I'd recommend a Ryzen 9 9900X or 9950X over the Core Ultra series. While the latest gen from Intel does admirably in many apps, the Ryzen tends to perform much better in games.
Here's a benchmark comparing the two architectures in After Effects:
