[Case Gallery] My Gold
Tiltentei
18 (0.00/day)
Norway
Specs:
Intel I7 3770k, Gigabyte GA-Z77-UD5H Z77 S-1155 ATX, Corsair AX1200w, 2x XFX 5870 865/1300, 16Gb Corsair vengeance (4x4) 1600mhz 9-9-9-24, HDD's Two OCZ Vertex 3 120GB Raid0, 2x WD Green 1,5TB 7200rpm 64mb Raid0, 2x Samsung Spinpoint F3 1TB Raid0. Asus Xonar Essence STX souncard, Fans: 18x SilenX 120mm & 4x Xigmatek 140mm, Fan controller: Sunbeam Rheobus-Extreme 6-channel 30w pr.channel,LG BE12 BLU-RAY,LG 27" 1920x1080 Flatron W2753V, NZXT led cables 4x 2m white and blue + custom made leds white/blue/orange/uv
Mods:
Scratch build desk, performed by me. Painted fans, hdd rack, mb tray, all screwes used are painted aswell. Lots of mdpc sleeving and replaced all the fan housing from white to black. Made my own leds from scratch and also many fan extensions. the housing got hidden led cable lightning around the whole casing. The mb is taken from a Antec 1200 so i hade to cut that out from the steel casing. Fan controller and led controller modded. Lots of wood cutting, sanding and painting and also worked some with smoked acrylic for the fan intake grills and the led controll bracket. It also have a massive watercooling.
Watercooling: Radiator: xspc RX480 + RX480 v2, Swiftech D5 pumps x2, Xspc Raystorm + xspc acrylic reservoirs. Bitspower black compression fittings 1/2ID-5/8OD, Black Bitspower 45/90 degrees. Bitspower T-type connectors, Bitspower single rotary adapters 45 and 90 degree, Bitspower G1/4 2,5cm extenders, Bitspower plug & stop fittings.Black and blue O-rings, Tubing: Masterkleer 1/2 ID 5/8 OD + Clearflex, 2x EK(en)Acetal + nickel fullcover waterblocks for 5870. Big thanks to performance-pc's.com
LetsDoDamage
9 (0.00/day)
This is absolutely stunning. I need this.
Or the skill, time and money for it. 10/10
12,304 (2.32/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
Not only a nice build but a detailed description as well, and nice pics.
169 (0.04/day)
Alta Loma CA
System Name Workstations
Processor I7 5930k / I7 4820K / I7 4770K
Motherboard ASUS RVE X99 / Sabertooth X79 / ASUS MVIIF
Cooling Thermaltake Water 3.0 Triple / Corsair H110 / Custom watercooling
Memory HyperX 32GB 3000MHz / Corsair Vengenance 32GB 1866MHz / HyperX Fury 16GB 1866MHz
Video Card(s) EVGA SLI GTX780 Classified / EVGA SLI GTX780 ASX / AMD R9 290 Xfire
Storage Crucial M500 500GB SSD / Kingston HyperX 240GB / Kingston HyperX 240GB
Display(s) 2x Qnix 27" 1440p / 3x Dell U2410 IPS 5760x1200 / 3x Dell U2311 IPS 5760x1080
Case Corsair 750D / Corsair A540 / NZXT Phantom P630
Audio Device(s) OB
Power Supply Seasonic X1050 Platnum / Corsair AX1200 / Corsaor AX1200
Software Win 7 on all PC's
Wow... This is a super nice build...
titienzo18
53 (0.01/day)
bourges, région Centre, FRANCE
it's to working or to playing?
superb, incredible, 10/10!!!
Tiltentei
18 (0.00/day)
Norway
I use it for almost anything. Atm im playing a lot since there are so many games i havent been able to play while building this :)
Thanks for your great feadback people.
titienzo18
53 (0.01/day)
one more time: superb build, and perfect pics.
574 (0.13/day)
Australia
Processor Intel® Core i5 6600
Cooling Hyper 212 Evo
Memory G.Skill Ripjaws V Series 16GB DDR4 2400mhz
Video Card(s) Gigabyte Geforce GTX 960 G1 4GB Gaming
Storage 256GB Intel SSD 525 Series
Display(s) 24" LG LED Monitor
Case Corsair Carbide 200R
Power Supply Seasonic MK12II 620W
Mouse Logitech G5
Keyboard Logitech G110
this is a sick rig tiltentei... =) I like it alot!Inspiring! =)
1,555 (0.26/day)
Shepparton, Victoria, Australia
System Name Toaster!
Processor Intel Core i7 10700KF @ 3.8/5.1GHZ
Motherboard ASUS Prime Z490-P Motherboard
Cooling Noctua NH-D15 CPU cooler.
Memory G.Skill Trident Z RGB 64GB (4x16GB) 3600MHz CL16 DDR4
Video Card(s) ASUS ROG Strix GeForce RTX 3090 OC 24GB
Storage Samsung 970 PRO M.2 NVMe SSD 1TB
Display(s) Asus ROG PG43UQ 4K UHD 144Hz G-Sync HDR 43in + 2 x ASUS VG258Q FHD 144Hz Freesync 25in Monitor
Case Corsair Obsidian 900D
Audio Device(s) EPOS Sennheiser GSX 1000 V2 amplifier + EPOS Gaming GSP 601 Headset
Power Supply Corsair AX1000 Titanium Modular
Mouse Razer Deathadder
Keyboard Corsair K70.
Software ALL HAIL WINDOWS 10.
Benchmark Scores Old system: http://www.3dmark.com/fs/6805248
10/10, if I had the motivation, I'd do something similar
Those 6 SSD's are nicely organised
I have 6 HDD's crammed into my 2nd PC for storage. And they are a complete mess, I can't put the side on without jamming cables up against the side, (it makes the side bulge). You've got room to move however and made it look amazing
9,862 (1.89/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
standard case? some cases have small room on the back of it so thats pretty hard to manage many cables if you wanna run it clean
some cases have small hole on the back of motherboard tray so you can tie the cable and make it tight as possible so it wont bulge
23 (0.00/day)
Power up !
This is very nice rig, i like the Tron style, and that thing that its
white and all the inside is black.. so it looks great and clean !
I can appreciate that its simply different rig, not just moded case !
in fact, i found some minor mistakes, the desk is too thick,
usually when the board is thicker than 15cm -then is sitting uncomfortable.
and you have it about 28cm thick. and the sitting space is also a little bit too narrow.
Now you can change your LCD somewhat, its so ordinary and boring there, in past
besign. better would be position on wall without stand or -like in Tron..
do you agree_?
But: the whole is really outstanding and i like it very much!
Tiltentei
18 (0.00/day)
Norway
Power up !
do you agree_?
It is not to thick, not to narrow,and absololutely not 28cm. I sit very comfortable when i use the desk and the lcd was placed there only when i took the pictures. The theme has nothing to do with Tron so i have no idea what your talking about. The desk is specially desgned for me and my use, and not for everyone out there.
Zhian
1 (0.00/day)
this is quite a nice setup - I would like to ask if you still got the drawings you made for this table ? :) im about to "copy" this build but gonna add some more for it - it could be really awesome to c what you took into it and so on :)
