My Gtx 1050 ti is not working/ not detected in bios or device manger. Pci-e slots say there empty but my fan runs. Plz fast fix ASAP
ineedsomehelpasap
4 (0.00/day)
Recenty i setup my pc everying turned on and got power but my graphics card didnt give video so i used my onbored gpu. My graphics card dosent show up anywhere such as bios device manger or anywhere. My fans runs and works fine.
Specs
i7-9700k
rog strix Ze90-e motherbored
GTX 1050 ti
Plz give tips or fix ASAP
SRY FOR SPELLING ERRORS
11,878 (2.26/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Specs
i7-9700k
GTX 1050 ti
Well initially try reseating it, check if it's fan spins.
2,661 (0.69/day)
Alabama
Processor Ryzen 2700X
Cooling Scythe Big Shuriken 3
Memory C.R.S.
Video Card(s) Radeon VII
Software Win 7
Hate to say it but ATM it sounds like a dead card.
FreedomEclipse
~Technological Technocrat~
23,597 (3.74/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
Unplug your PC and flip the button battery out of your mobo for a minute before putting it back in and trying again.
Sometimes some boards can become 'bugged' and will prefer to use only the iGPU as default even if you have a dedicated graphics plugged in.
The fact that you initiated use of the iGPU means that it gets 'stuck' so a bios reset is needed.
Unplug the PC and flip the battery.
:EDIT:
Ooooorrrrr the card could be completely dead as mentioned above.
2,661 (0.69/day)
Alabama
Memory C.R.S.
Software Win 7
Let's hope not.
The fact the card isn't even detected in the BIOS or OS/system is why I said that.
If you have another system I'd test the card in that to either confirm or rule it out.
ineedsomehelpasap
4 (0.00/day)
before i switched my motherbored it worked on my other motherbored so ..
i did the battery thing didnt work
but my card worked on my other motherored
and also thers a white light- vga light on my pc its on
2,661 (0.69/day)
Alabama
Memory C.R.S.
Software Win 7
I take it you tested the card AFTER the problem occured.
If so then the card itself would be OK.
Also, according to the info you gave it happens no matter what slot you have it in.
Although you can't rule out the board right now as the cause, could still be an issue with the card itself.
I have one myself that acts dead in some boards, in others it works normally and the problem is board-specific but not based on any given board model. Between the DFI Ultra D's I have for example it works in at least three of them but doesn't work in the other one I have.
Any other cards I set in that board works normally so in my case, it is the card but the card itself isn't "Bad", just picky about what board it wants to run in.
In any case I'd try another card in the board if possible and see if that works to be sure it's not a problem with the board itself.
21,558 (6.00/day)
Case Fractal Design Define R5
Mouse XTRFY M42
Software W10 x64
Blow out your top (or the x16) PCIe slot rigorously - and not with your own saliva but with compressed air or a leaf blower. This can be as simple as a dust problem. If you reseated the card and if the board was without a card on that slot for a while in open air, this is a real possibility.
You can also inspect the contact area of the card for any scratches/damage/junk, though that rarely is a cause.
And yes, confirm that you tested OK on the card on the other board AFTER it didn't work on the new one for us :)
66 (0.01/day)
System Name Ragnars Rig
Processor AMD Ryzen 7 5800X 3D
Motherboard ASUS Pro WS X570-ACE
Cooling 3x140 Copper Rad, Koolance CPU-380I Waterblock, XSPC X20 750 Pump/Reservoir, EKWB GPU Waterblock
Memory G.SKILL TridentZ RGB Series 16GB (2 x 8GB) DDR4 3600MHz
Video Card(s) EVGA RTX 2080 Ti FTW3 ULTRA GAMING
Storage Samsung OEM 500GB PCIe NVME, Samsung EVO 500GB SATA SSD, 2TB WD Black, 4TB WD Black
Display(s) DELL S2716DG 27" 144hz, Vizio D50U-D1 4K 50" 60hz,
Case Fractal Design R5 Black w/Window
Audio Device(s) Logitech G533 7.1 Wireless Headphones
Power Supply Seasonic SSR-1200PD 1200W PLATINUM
Keyboard Corsair Strafe w/ Cherry MX Reds
Software Windows 10 Education x64
You can try cleaning the pins by inserting a piece of paper folded over on itself a few times. Do not slide it! Just insert and remove over the length of the slot.
This saved me some pain when I removed the GPU and some unseen grime was stuck to the pins.
40,739 (6.54/day)
Get some electronic grade contact cleaner disconnect power supply from the wall and remove the CMOS battery then spray the pcie slot and then clean the edge pins on the video card using contact cleaner you may want to use a clean rubber eraser as well. Have you also updated the Motherboard BIOS?
And where did you buy this 1050ti from?
2,960 (0.87/day)
Long Island
Did you wipe the HD and reinstall the OS after switching Motherboards ?
The fact that it worked on your old motherboard and doesn't on the new one tells me the card is fine and the system is confused. Unless that was a "like kind" replacement ... the system can be "confused" from detecting various on board newer chipsets and trying to install driver for older chipsets that it can no longer detect because they are associated with your old MoBo. While such a "switch' can be done, somewhat successfully, it also often results in the problem you describe.
Some folks will uninstall all hardware drivers before removing the old board ,,, and then install the new ones after the swap. But this makes future troubleshooting difficult as you never know if in fact Windows didn't reinstall the buggers right after you uninstalled them or as soon as you booted to the new MoBo. Many a system has sat on my workbench whereby a fresh install cured many ills after a recent user upgrade.
1,901 (0.33/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
Also do an over night Cmos clear. Use an Eraser to clean the PCI-E of the GPU (gold fingers) as Ive seen hand grease cause this issue.
1,720 (0.33/day)
Steel City, UK
As your title says. (ASAP) You need more patience to fix and there is no short cut/way before you even fixed your problem.
Take those words.
Just noticed. Nice username and new member. I smell something fishy... Lol
Thecrashingwave
2 (0.00/day)
Hey im having a similar issue. I have a b360 m ds3h motherboard and a gtx 1050 ti. intel site lists the mobo and gpu as compatible. When i put the gpu in the mobo it gets power and fan is spinning, but when you check the bios the pcie 16 slot says empty. What can i do to make the mobo recognize the gpu?
40,739 (6.54/day)
Pull the mobo and build the rig out of case and fully insert the gpu
Thecrashingwave
2 (0.00/day)
you are right i was being a pussy. I was pushing so hard i was scared. just assembled mobo out of case and it went in. ill check if its working
Working great got the drivers installed. thank you for the help.
