My Latest MSI review.
945 (0.54/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Altec Lansing
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
As a fierce dragon lover, I decided to try MSI latest state of art: the MSI "Spatium". The Pcie-4 compatible nvme drive comes with a small packaging with user manual. (Note that my version does not include the heatsink.)
And here is the net result:
8,987 (3.31/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
945 (0.54/day)
Turkey
System Name MSI-MEG
Memory 32 GB
Tatty_Two
Gone Fishing
25,919 (3.77/day)
Worcestershire, UK
Processor Intel Core i9 11900KF @ -080mV PL max @225w
Software Win 11 Home x64
Moving this to the storage sub forum, General Hardware threads tend to submerge pretty quick as it's so big.
945 (0.54/day)
Turkey
System Name MSI-MEG
Memory 32 GB
12,285 (5.79/day)
Midlands, UK
System Name Nebulon B
Cooling be quiet! Dark Rock 4
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
Not bad. The only thing I don't understand is why MSi chose a blue PCB when all of their motherboards are either black or white.
945 (0.54/day)
Turkey
System Name MSI-MEG
Memory 32 GB
Yeah their GPU's pcbs are also in black.
945 (0.54/day)
Turkey
System Name MSI-MEG
Memory 32 GB
I'm returning back to amazon since it caused my chipset temperature 10C deg higher than normal. I will not be using another nvme.
12,285 (5.79/day)
Midlands, UK
Did that affect normal usage of the PC, though? Chipset temp isn't something that one usually worries about.
945 (0.54/day)
Turkey
System Name MSI-MEG
Memory 32 GB
Besides the increase the temperature of my x570s chipset, it works amazingly fast.
My idle temperature was like 46-47, however, after installing second nvme it increases up to 55C degree.
12,285 (5.79/day)
Midlands, UK
My idle temperature was like 46-47, however, after installing second nvme it increases up tu 55C degree.
Is that for the chipset? I know X570 isn't famous for running cool, so I suppose that's okay.
945 (0.54/day)
Turkey
System Name MSI-MEG
Memory 32 GB
12,285 (5.79/day)
Midlands, UK
18,584 (2.70/day)
System Name AlderLake
My M.2 drives idle:
C: = Samsung 980 Pro 1TB
H: = Samsung 970 Evo 500GB
945 (0.54/day)
Turkey
System Name MSI-MEG
Memory 32 GB
18,584 (2.70/day)
Dude that's more than perfect!. How is your fan setup and what is your case?
2 140mm front intake
1 140mm bottom intake
2 120mm CPU cooler
1 120mm rear exhaust
1 120mm top exhaust
My case is a be quiet! Silent base 600 Window.
Took out the drive cages and took out the DVD drive to make room for a 140mm fan.
945 (0.54/day)
Turkey
System Name MSI-MEG
Memory 32 GB
I personally never had an X570 motherboard
And I will never suggest you to have one. Unless you really need it is surely redundant.
12,285 (5.79/day)
Midlands, UK
To be honest, I never go for AMD X-series or Intel Z-series anyway. What I need is an x16 slot for a GPU, two nvme slots and plenty of USB ports. This need is catered for by B-series boards from both companies.
