System Name | micropage7 |
Processor | Intel Xeon X3470 |
Motherboard | Gigabyte Technology Co. Ltd. P55A-UD3R (Socket 1156) |
Cooling | Enermax ETS-T40F |
Memory | Samsung 8.00GB Dual-Channel DDR3 |
Video Card(s) | NVIDIA Quadro FX 1800 |
Storage | V-GEN03AS18EU120GB, Seagate 2 x 1TB and Seagate 4TB |
Display(s) | Samsung 21 inch LCD Wide Screen |
Case | Icute Super 18 |
Audio Device(s) | Auzentech X-Fi Forte |
Power Supply | Silverstone 600 Watt |
Mouse | Logitech G502 |
Keyboard | Sades Excalibur + Taihao keycaps |
Software | Win 7 64-bit |
Benchmark Scores | Classified |
System Name | Smooth-Operator |
Processor | AMD Ryzen 7 3800x |
Motherboard | Asrock x570 Taichi |
Cooling | AMD Wraith Prism |
Memory | 2x16GB 3200MHz CL16@CL14 DDR4 |
Video Card(s) | Sapphire Radeon RX 580 8GB NITRO+ |
Storage | 2x4TB WD HGST 7K6 7200RPM 256MB |
Display(s) | Samsung S24E370DL 24" IPS Freesync 75Hz |
Case | Fractal Design Focus G Window Blue |
Audio Device(s) | Creative X-Fi Titanium PCIe x1 |
Power Supply | Corsair HX850 80+ Platinum |
Mouse | Gigabyte Aorus M3 |
Keyboard | Zalman ZM-K300M |
Software | Windows 10 x64 Enterprise/Ubuntu Budgie amd64 |
Most likely if ram would be dead it wouldn't be recognized at all and pc wouldn't boot up giving post codes by sound or display, accordingly.check your ram/ram slot try clean the contact area then plug it back
if it not read could be from your ram slot or you have dead ram there
yeah, but some cases the pc runs, the only way to check it through cpuz or plug it one by oneMost likely if ram would be dead it wouldn't be recognized at all and pc wouldn't boot up giving post codes by sound or display, accordingly.
@OP, unplug one stick and check if pc boots, then replace stick with other one and check again.
System Name | Main/DC |
Processor | i7-3770K/i7-2600K |
Motherboard | MSI Z77A-GD55/GA-P67A-UD4-B3 |
Cooling | Phanteks PH-TC14CS/H80 |
Memory | Crucial Ballistix Sport 16GB (2 x 8GB) LP /4GB Kingston DDR3 1600 |
Video Card(s) | Asus GTX 660 Ti/MSI HD7770 |
Storage | Crucial MX100 256GB/120GB Samsung 830 & Seagate 2TB(died) |
Display(s) | Asus 24' LED/Samsung SyncMaster B1940 |
Case | P100/Antec P280 It's huge! |
Audio Device(s) | on board |
Power Supply | SeaSonic SS-660XP2/Seasonic SS-760XP2 |
Software | Win 7 Home Premiun 64 Bit |
Processor | Ryzen 7 5800X3D |
Motherboard | Gigabyte X570 Aorus Elite |
Cooling | Thermalright Phantom Spirit 120 SE |
Memory | 2x16 GB Crucial Ballistix 3600 CL16 Rev E @ 3600 CL14 |
Video Card(s) | RTX3080 Ti FE |
Storage | SX8200 Pro 1 TB, Plextor M6Pro 256 GB, WD Blue 2TB |
Display(s) | LG 34GN850P-B |
Case | SilverStone Primera PM01 RGB |
Audio Device(s) | SoundBlaster G6 | Fidelio X2 | Sennheiser 6XX |
Power Supply | SeaSonic Focus Plus Gold 750W |
Mouse | Endgame Gear XM1R |
Keyboard | Wooting Two HE |
There's no iGPU on 2600.It appears that half of the RAM is not available. Has it been assigned to the iGPU?
System Name | Thermaltake |
Processor | AMD Ryzen 5 5800X3D @ 4.60 GHz |
Motherboard | Gigabyte B550 Aorus Elite V2 |
Cooling | Thermalright Peerless Assassin |
Memory | 32 GB Crucial Ballistix @ 3600 MHz CL16 |
Video Card(s) | XFX 319 Merc 6800 XT |
Storage | Kingston 256GB SSD | Kingston 240GB NVMe | Samsung 1TB NVMe | Samsung F3 1TB HDD | Barracuda 2TB HDD |
Display(s) | 34" ultrawide LG 34GL750B 144hz 1ms | 55" LG UR91 4k@60Hz |
Case | Phanteks Eclipse P400 |
Audio Device(s) | ALC 1220 120dB SNR HD Audio |
Power Supply | Thermaltake GF1 850 W - 80 Plus Gold |
Mouse | Logitech G502 HERO Lightspeed |
Keyboard | Asus TUF Gaming K3 |
Software | Windows 11 Pro x64 |
Processor | AMD Ryzen 5 2600 (Covered with Cooler Master MasterGel Pro) |
Motherboard | ASRock B450 Steel Legend, BIOS Version: 10.31 [Beta] |
Cooling | Cooler Master MasterLiquid ML120L V2 RGB, 5x Galax Vortex Wind-02 (3x Front Intake + 2x Top exhaust) |
Memory | Kingston FURY Beast RGB 3600 MT/s 32 GB (4x 8GB), (KF436C17BBA/8) |
Video Card(s) | Palit GeForce GTX 1660 Ti Dual OC |
Storage | Kingston NV2 1 TB |
Display(s) | MSI PRO M251 (HDMI), Running @104 Hz |
Case | Cooler Master MasterBox MB520 |
Audio Device(s) | HP H360G USB |
Power Supply | Cooler Master MWE 550 80+ White |
Mouse | HP G200 Black |
Keyboard | Redragon MITRA K551-1 RGB |
Software | Windows 11 Home |
Yes that's it idk why everyone pointed the gun on hardware immediately , i know it might be the RAM slots or something but why not starting from the easy stuff first?1 Open Start and type "msconfig" and pres Enter.
2 On top, click on "Boot" → "Advanced Options" and look for "Maximum Memory"
Make sure the box is unchecked.
great to hear it worksSo i removed both stickes of ram and replugged them and now its works fine thanks guys
