My rx580's FireStrike score is too low. Which vbios should i choose?
tech2nara
1 (0.00/day)
Hello friend.
The graphics card I bought from Aliexpress came.
I know it's the same as the rx580 2048sp 8GB with rx570.
Booting or using is normal, but the 3DMmarks score is too low.
When the shloud is disassembled, the information of the chipset and memory is as follows.
gpu adda 215-0910052.
215-0910052
G727 7JA47 D9SXD
It is similar to the original RX570 chipset and micron memory die.
화재 공격
This is a score in its pure state, with nothing touched.
The vbios of my card is this: This is what I posted.
Select the BIOS that you need to choose to run correctly.
Thanks for the help
No bios flash is going to make it better use msi afterburner
Because you choose to buy from Ali, and you choose to buy a real chinese card, we do not have a real alternative for your current BIOS.
So yeah, this is the cruel truth: the copy is not close to the original card.
But at least your card was not a miner one.
So...you can celebrate at least that your card is running.
That is not an RX 580 2048SP because those were never shipped in 8GB variants. Most likely it's an overclocked RX 570X. Be happy that it works at all and don't try to mess around with the BIOS because you're likely to end up bricking it.
