(NAS) - Drobo replacement...
121 (0.49/day)
System Name [ JUNE_2024 ]
Processor LGA1700 i5-12600K / 3.7Ghz / 10 cores
Motherboard Asus Prime Z790Mplus D4
Cooling Abysm Snow 4 Duo120mm
Memory Kingston Fury Beast 32Gb DDR4-3600
Video Card(s) Asus RTX 4070 Dual 12Gb
Storage M2 Corsair MP600 CoreXT 1Tb
Display(s) Asus 32" VG1A
Case Cooler Master Q300L ATX
Power Supply Corsair RM 750w Modular
Drobo company is gone and my dad's old Drobo is a 2017 NAS of 4-bays, recently showing its age with often drive errors, specially each time he replugs the NAS (we recently swapped to a new pc, where i've reinstalled him the latest drobo UI without problem) so, today i've watched a bunch of YT videos, that mention all the latest NAS brands on the market but none are cheap... a minimum 2-bays fetch for 300$, so a DIY system is tempting... here's a resume of his NAS workflow (picture below):
1) - his Drobo is not connected to the internet, no cloud-synch nor remote-access needed for his home PC.
2) - he has a main 3.5" HDD of 2Tb (bay #1) with another identical HDD (bay #2) for ghost-image of the main (redundancy)
3) - he only uses it to backup office work and images - from excel to photos and even bureaucracy - IRS and banking data (he doesn't trust his data connected online to a 3rd-party cloud)
4) - he opens a file from Drobo main drive, works on that file on his desktop, then saves it back to the NAS original directory - which Drobo saves a second-copy into the ghost drive.
5) - when he switches on his PC, the drobo automatically turns on also and takes a few minutes to make 6Tb available on File Explorer (same thing for shutting down the pc)
NOTE - for some reason he has a 3rd drive HDD of 2Tb slotted in bay #3 (not sure if Drobo uses it at all) so i count a disc space of 3 x 2Tb = 6Tb... but somehow File Explorer shows 15Tb in total
...my Questions are:
- can i transfer all his drobo data into smaller formats SSD 2.5" discs and secure these, inside the pc AXT case, alongside the PC windows SSD ?
- is there a stand-alone & easy-to-use program, for the drives D & E to work in-synch allowing backup & cloning?
- my dad is 85 years old and he's afraid that he forgets to backup files manually (doing 2 copies to each drive, is troublesome) or that he erases an original file, or copies over the good one, or even does a cut instead of a copy action - so he wants a program that does a double-backup automatically and alerts him when disc is full, basically...
all feedback is welcome, thank you!
EDIT: from a video i saw, i think it should be called a DAS (Direct) and not a NAS (Network) since it doesn't use an internet connection.
