NCase M1 watercooling ideas?
4,520 (0.70/day)
Perth AU
Processor Intel Core i9 10980XE @ 4.7Ghz 1.2v
Motherboard ASUS Rampage VI Extreme Omega
Cooling EK-Velocity D-RGB, EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
Memory G.Skill Trident Z RGB F4-3000C14D 64GB
Video Card(s) Asus ROG Strix GeForce RTX 4090 OC WC
Storage M.2 990 Pro 1TB / 10TB WD RED Helium / 3x 860 2TB Evos
Display(s) Samsung Odyssey G7 28"
Case Corsair Obsidian 500D SE Modded
Power Supply Cooler Master V Series 1300W
Hey guys looks like a custom loop is a must for me in my M1 my dual fan 780 TI just gets to hot and ill lose money changing cards now so i mite as well just get a custom loop to save me wasting more money.
I'm looking at these follow parts.
M1 NCase Reservoir ( FIXED PART)
Swiftech Apogee Drive II CPU Waterblock Pump
Swiftech MCR220-XP eXtreme Performance Dual 120mm Radiator
EK GeForce 780 GTX Ti VGA Liquid Cooling Block - Acetal (EK-FC780 GTX Ti
Any ideas are welcome i haven't made a custom loop before so any feed back is welcome.
6,782 (1.36/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
That is one tough case to watercool in. I know ncase tested the swiftech 220 in the case but just for the cpu. Getting the gpu into the loop will be a little difficult but not impossible.
It kind of defeats the purpose of a small case but have you considered an external radiator?
4,520 (0.70/day)
Perth AU
I've seen photos of it done will a slim rad affect it to much if I run my gpu as well off it?
6,782 (1.36/day)
Processor 7800x3d
Case ThermalTake P3
it would work. It is just not ideal. I can't say with certainty if it will perform any better than it does now on air.
4,520 (0.70/day)
Perth AU
I can fit a biger one in there but its really pushing it and how would you install it with out having long hoses.
6,782 (1.36/day)
Processor 7800x3d
Case ThermalTake P3
You are going to have to be creative. One thing that might help would be angled barbs/compression fittings. There will be a lot of trial and error. Be prepared for that.
Have you considered bigger better aircooling. Maybe a bigger artic xcellero heatsink or something. I know the m1 has space for a triple slot cooler. That will only help so much. What I think you really need is better airflow, specifically exaust.
I am surprised I am the only one to comment here. There are more knowledgeable people here than I. I knew the general attitude to watercooling here is go big or go home but this really seems to proves it too me.
4,520 (0.70/day)
Perth AU
Well thanks any way man but looks like ill be ether using the M1 for a media build or selling the thing just cant do that to my hardware it was like trying to put a cat in a shoe box.
3,685 (0.85/day)
GMT +2
System Name Red Radiance l under construction
Processor 5800x
Motherboard x470 taichi
Cooling stock wrath
Memory TridentZ Neo rgb 3600mhz (2x8 kit)
Video Card(s) Sapphire Vega 64 nitro+
Storage 970 evo nvme
Display(s) lc27g75tq
Case tt core x5 tge
Audio Device(s) sennheiser's pc323d usb soundcard
Power Supply corsair AX860i
Mouse roccat burst pro
Keyboard roccat ryos mk fx
Software windows 10
hm
what is airflow direction of your h100i
4,520 (0.70/day)
Perth AU
Hey guys what type of fittings do i need and hose does this seem right ? The 90 Degree fittings are for the GPU?
2 for waterblock
2 for rad
2 for res
2 90 degree GPU
3,842 (0.87/day)
System Name Zotan
Processor i9-10850K
Motherboard Gigabyte Z490 Gaming X AX
Cooling H100
Memory 32GB Viper 3200
Video Card(s) Zotac RTX3080
Case Airflow 275R
Power Supply RMX850
Benchmark Scores d1nky@hwbot.org
ive seen loads of pics of this case either modded or watercooled with a very short simple loop.
you have the right idea about the swiftech waterblock/pump, my only concern is that there will be very little water volume and not much heat dissipation.
10,954 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 1:1 CL30-36-36-96 FCLK 2000
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply RIP Corsair SF750... Waiting for SF1000
Keyboard 65% HE Keyboard
is there an exhaust, or is it a toaster?
4,520 (0.70/day)
Perth AU
Arr thanks i remember seeing these before just couldn't find where, So ill need 4 90 degree fittings.
And for the water volume you can see the M1 Res is a lot bigger it actually goes over the grommets.
Because the case is so small you have the rad fans pushing air out the side, While air is getting sucked in from the top.
6,782 (1.36/day)
Processor 7800x3d
Case ThermalTake P3
In their testing they used a 3770k and a 7970 and had better than stock temps for quieter.
@d1nky, I don't get why water volume would be a concern. My loop uses very little water, 1/4 a gallon roughly, and I get excellent temps on a 240mm radiator. Although it is the 80mm thick monsta radiator with push pull fans. Less waters means you will just hit max temps sooner.
3,842 (0.87/day)
System Name Zotan
Processor i9-10850K
Cooling H100
Case Airflow 275R
Power Supply RMX850
this is my point, with less dissipation (thin rad) temps will get to max quickly and not be cooled enough. especially with a cpu/gpu at max etc.
this is my only concern
6,782 (1.36/day)
Processor 7800x3d
Case ThermalTake P3
Small case means no space for bigger rad or more water unless he uses an external anything, defeating the purpose. I am mostly worried he wont be able to supply the fans with enough air.
4,520 (0.70/day)
Perth AU
The H00i did fine in there it just the hoses where to bent up, I think it will be fine a lot of people are doing the same set up as me.
4,520 (0.70/day)
Perth AU
Hey guys im no longer going to use the Swiftech Apogee Drive II CPU Waterblock Pump now im looking a good small pump any ideas?
was looking at the
EK-DDC 3.2 PWM (12V PWM pump) or
EK-DDC 3.25 (12V DC pump)
