RampageDesign
- Nov 23, 2014
- 4 (0.00/day)
Hi guys, I want to introduce my most recent build, which is in an Ncase M1v2 case.
Here is the main component list:
-Core i7 4790K
-Asus Z97i Plus
-Corsair Dominator Platinum 8GB 2133mhz
-Asus GTX 760 Mini
-Crucial M500 240GB M2 SSD
-Silverstone SX600-G
Watercooling component list:
-EK Supremacy ELITE
-Laing D5 from Alphacool
-Bitspower D5 mod top
-Bitspower D5 mod kit
-Swiftech MCR-H220 Radiator
-Masterkleer 16/10 Black Tubing
-1x Bitspower dual rotary adapter for pump
-4x 16/10 black nickel compression fittings
Other stuff list:
-MNPCTech case feet
-Acrylic sheet
-White led lightning with rigid pcb.
-White leds for d5 top
-Black Vandal switch with white led ring
-16AWG black cable
-connectors for custom cables
-MDPC-X black sleeving
-Cable combs
Now you have seen the specs, and now here are the pictures:
First the case itself:
[img=[url]https://lh5.googleusercontent.com/-...AAABpg/PoFugDFUtBM/w958-h639-no/IMG_7233.JPG][/url]
I made a custom side panel for the case from 5mm thick tinted plexi:
I got some magnetic strips to attach the side panel:
Custom case feet from MNPCTECH:
I've painted them with black Plasti-dip:
Cable combs:
Pump with Bitspower mod kit:
Swiftech rad:
Fans:
EK Supremacy Elite:
I assembled the case and did some testfit for the sidepanel and made a custom bracket for the vandal switch. Here is some pics how it looks now:
I designed a custom case from aluminium for my KBC Poker 2 keyboard, and my friend CNC milled it.
Here is the result:
Got some led strips from MNPCTECH: http://mnpctech.com/pc-led-lights/
Thats it for now. Im currently working on the custom cables and on the watercooling. Next week the tubing will arrive, then I will be able to finish the cooling loop for the cpu. When the cooling is ready im gonna take some proper pics from the hardware.
-Core i7 4790K
-Asus Z97i Plus
-Asus GTX 760 Mini
-EK Supremacy ELITE
Other stuff list:
-MNPCTech case feet
-Acrylic sheet
-16AWG black cable
-Cable combs
![](/forums/proxy.php?image=https%3A%2F%2Flh5.googleusercontent.com%2F-oJVcXcQJMcs%2FVG8quw9UGuI%2FAAAAAAAABng%2FeKSzmt4uHRI%2Fw958-h719-no%2FIMG_20141121_130550.jpg&hash=6e9ea6600a937faad700bee73a957766)
Cable combs:
![](/forums/proxy.php?image=https%3A%2F%2Flh4.googleusercontent.com%2F-MMYICYYFgjU%2FVDK0IQiMzdI%2FAAAAAAAABZo%2FhhW7jt98jxg%2Fw958-h719-no%2FIMG_20141006_144951.jpg&hash=b9bda97fbf7178955ad31e6b036c0c4c)
![](/forums/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-Y6Ox4nGVY9o%2FVDK0LHaK9aI%2FAAAAAAAABZ0%2FqFrUNGgna2Q%2Fw958-h719-no%2FIMG_20141006_145140.jpg&hash=1ebb8901fb784595779ce13f2cdb78bc)
![](/forums/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-SwC1nAJeaYQ%2FVDK0OD7m5SI%2FAAAAAAAABaA%2F-pa9wKKz4VI%2Fw958-h719-no%2FIMG_20141006_145152.jpg&hash=b8a6ebbc5dea639f2e827858d8a9dc23)
![](/forums/proxy.php?image=https%3A%2F%2Flh5.googleusercontent.com%2F-9iDbz0OaFec%2FVDK0YfktmaI%2FAAAAAAAABaw%2F1trokhyiteI%2Fw958-h719-no%2FIMG_20141006_145254.jpg&hash=22d68e9a1f7ccfd9059639e52a51385b)
![](/forums/proxy.php?image=https%3A%2F%2Flh6.googleusercontent.com%2F-r7CEjyCXqvQ%2FVDK0assN2aI%2FAAAAAAAABa8%2FlFt8JYCzbgA%2Fw958-h719-no%2FIMG_20141006_145303.jpg&hash=f1ac9b64bb1cf32fa709dcf39c0b3fd1)
![](/forums/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-4h4CXFeqMWU%2FVDK0TAwmV0I%2FAAAAAAAABaY%2F7jGwuUCzJWk%2Fw958-h719-no%2FIMG_20141006_145239.jpg&hash=759897957dfab9f7f6d96ec53852c286)
Swiftech rad:
Fans:
![](/forums/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F--HfobwelQ9Q%2FVHDSK1i3T1I%2FAAAAAAAACGs%2F-HIHbOmlQNQ%2Fw958-h719-no%2FIMG_20141122_191131.jpg&hash=3628c840392dbb0de5eb8ff91e3404e9)
![](/forums/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-29Zta3JUQ9g%2FVHDSOmL8WoI%2FAAAAAAAACG4%2FZw3nz0RrJvM%2Fw958-h719-no%2FIMG_20141122_191152.jpg&hash=e2ea5642f82573d27707e5f4351353c9)
![](/forums/proxy.php?image=https%3A%2F%2Flh4.googleusercontent.com%2F-q9cm1qdskuE%2FVHDSSY3MRII%2FAAAAAAAACHE%2FCn29MX3WCt0%2Fw958-h719-no%2FIMG_20141122_191219.jpg&hash=23d4a6b55f11fc17fcec92abe44da972)
EK Supremacy Elite:
![](/forums/proxy.php?image=https%3A%2F%2Flh5.googleusercontent.com%2F-CKu6TvkEL5U%2FVG8z6_q6b3I%2FAAAAAAAABoY%2FykRb4Nk5e74%2Fw958-h719-no%2FIMG_20141121_134422.jpg&hash=f9bf48c18d336c013509c14a963c8317)
![](/forums/proxy.php?image=https%3A%2F%2Flh4.googleusercontent.com%2F-xC0K6uXtq4I%2FVG8zzkbu6CI%2FAAAAAAAABn0%2F7__owCmxuiI%2Fw958-h719-no%2FIMG_20141121_134228.jpg&hash=f9c9bb726b294e8ffc5b0e439229866e)
![](/forums/proxy.php?image=https%3A%2F%2Flh4.googleusercontent.com%2F-0RrXdBEpBIo%2FVG8z2K1OLXI%2FAAAAAAAABoA%2FUdIWNByNcbI%2Fw958-h719-no%2FIMG_20141121_134250.jpg&hash=2ea43fc9c87253a0fe887ba049da6946)
![](/forums/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-QTlFAKp-irM%2FVG8z4ToW_TI%2FAAAAAAAACF0%2Fe114EE7G-Zk%2Fw637-h849-no%2FIMG_20141121_134357.jpg&hash=2c6f58663c9dca474380de11c4340754)
Here is the result:
![](/forums/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-3YFK9pk-HQE%2FVHCISNaq_QI%2FAAAAAAAACGA%2Fom8vM30y-qY%2Fw958-h719-no%2FIMG_20141122_135605.jpg&hash=4e16e9820948991032e8298cff8578d2)
![](/forums/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-E0eq0hHX2CY%2FVHCIUh06eZI%2FAAAAAAAACGM%2Fy-t-VBFF8T4%2Fw958-h719-no%2FIMG_20141122_135618.jpg&hash=1d410edf697d3100a202c6ab3f4fb5cc)
![](/forums/proxy.php?image=http%3A%2F%2Fmnpctech.com%2Fimages%2Fthumbnails%2F280%2F186%2Fdetailed%2F1%2Fwhite_darkside_dazmode_led_rgb_super_bright_strip_pc_dimmable_sleeved1.jpg&hash=1f4531d6712084abf7dd997a2598d2dc)
![](/forums/proxy.php?image=https%3A%2F%2Fmnpctech.com%2Fimages%2Fcompanies%2F3%2Finstall_darkside_pc_led_rgb_white_uv_red_blue_green_orange.jpg&hash=6ac64b889daa40ba3ffc124b88140213)
![](/forums/proxy.php?image=https%3A%2F%2Fmnpctech.com%2Fimages%2Fcompanies%2F3%2Finstall_darkside_pc_led_rgb_white_uv_red_blue_green_orange1.jpg&hash=e8844d49bf33dc3d7b485cec25b7d5e5)
![](/forums/proxy.php?image=https%3A%2F%2Fmnpctech.com%2Fimages%2Fcompanies%2F3%2Finstall_darkside_pc_led_rgb_white_uv_red_blue_green_orange2.jpg&hash=ff8bab43caeb97898a75a0080772d1c8)
