- Apr 7, 2009
- 332 (0.06/day)
Processor | Intel® Core™ i5-2500K (4.6GHz @ 1.28-1.33v) |
Motherboard | ASRock Z68 Pro3 Gen3 |
Cooling | Prolimatech Megahalems Rev.C + Blue Vortex 140mm |
Memory | Kingston HyperX Fury White (2x8GB, DDR3-1866, 10-11-10-30, 1.5v) |
Video Card(s) | MSI GTX 970 Gaming |
Storage | Crucial C300 128GB, WD Green 2TB |
Display(s) | BenQ XL2420T |
Case | Antec Twelve Hundred |
Audio Device(s) | Onboard Realtek audio |
Power Supply | Corsair HX 650W |
Software | Win7 Ultimate (64-bit) |
Hello everyone!
If any of you have lots of free time on your hands AND could explain to me these BIOS settings it would be greatly appreciated
My motherboard is an ASRock Z68 Pro3 Gen3 (a value model but with everything I need) and assume most of the BIOS on this manufacturer's boards will be close to identical so here it goes:
OC Tweaker tab, page 2
1) Advanced Turbo 50 - what is this mode? I see people OC without it, is this something like the MSI OC Genie? So you disable it to oc manually I assume?
2) Interna PLL Overvoltage - I read in some guide that you shouldn't touch it (not sure if on enabled or disabled), what is it and does it matter much if it's enabled or disabled?
3) Turbo Boost Power Limit - should this be tweaked/enabled or whatever when ocing manually? How do I know what Short and Long limits to set? Long Duration Maintained? What it is and what should be set in that too?
4) Additional Turbo Voltage - should it be enabled/disabled/auto when ocing and not? Why?
5) Core Current Limit - what is this, why and does it need to be set/disabled?
6) Spread Spectrum - what does it do? should it be enabled/disabled/auto when ocing and not? Why?
7) Power Saving Mode - how is this different to SpeedStep? Does it need to be enabled? Does it interfere with ocing? How effective is it?
8) CPU Load-Line Calibration - so hard to decide on this as I heard people for and against it while ocing. Question is what are those levels and how should I know what level to choose?
Advanced tab, CPU Configuration submenu
1) Hardware and Adjacent Cache Line Prefetchers - what are they? Enable them for oc? Do they matter at all?
2) CPU Thermal Throttling - what does it do? Enable/disable for oc?
3) Intel Virtualization Technology - never used it, but I heard it's for people running several OSs at the same time. I only sit on 1 OS - Win7, so I can disable it right? No other use for this option?
4) No-Execute Memory Protection - what is this? Enable/disable for oc?
1 more question - how do I disable Lucid Virtu GPU on the CPU in BIOS? I'll enable it back in BIOS when I need it.
I may add more stuff later when I get back home since this is only what I want to know from erocker's posted BIOS screenshots on tpu
Anyway, if you have any suggested settings one should use in BIOS just let us know
