Need for speed with an Intel Core 2 Quad Q9650 CPU
1,150 (0.47/day)
Upstate NY
System Name Dual Socket HP z820 Workstation
Processor Twin Intel Xeon E5 2673 v2 OEM processors (thats a total of 16C/32T)
Motherboard HP Dual Socket Motherboard
Cooling Stock HP liquid cooling
Memory 64GB Registered ECC memory kit (octal channel memory on this rig)
Video Card(s) MSI RX 5700 XT Gaming X 8GB
Storage 2 x 512GB SSD in raid 0
Display(s) Acer 23" 75Hz Gaming monitors 1080P x2
Case Brushed Aluminium
Audio Device(s) Integrated (5.1)
Power Supply HP 1125W Stock PSU
Mouse gaming mouse
Keyboard Dell
Do you think 5.0Ghz is feasible? Air cooling with a Thermalright Ultra 120 extreme. Motherboard: Asus P5Q3. 8GB kit of G.skill Ripjaws 1600 CL7.
Here is my best effort so far. Not super familiar with this board so I'm a little in the dark. So far, at 4.5Ghz, my temps still seem good. I'm seeing low 80s at idle and mid 130s under load.
1,010 (0.29/day)
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) PCWINMAX RTX 3060 6GB Laptop GPU (80W)
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 11 Pro 64-Bit
On a Core 2 that'll be a big no unless your using sub-zero water cooling or a single stage phase change cooler at least. Plus most quads will not do too far past 500 FSB usually.
I hope your talking Fahrenheit and not Celsius. :p
3,030 (0.83/day)
With the voltage al ready above 1.5 volt, i would not reccomend trying out 5 ghz.
And as al ready told, i hope the temp are Fahrenheit. If celsius you stop right now and go back to lower clock, cause if celsius you are litterly burning the life out of that cpu. Intel cpu's shut not opperate at temp above 80 degree celsius and volt is also dangerously high already.
my advise: dont go higher, infact lower your oc until its stable at max 1.4 volt if you want the cpu to last a while longer.
INSTG8R
Vanguard Beta Tester
8,082 (1.10/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
866 (0.23/day)
Processor ryzen 5 5600x
Motherboard AB350m Pro4
Cooling custom loop
Memory TEAMGROUP T-Force TXKD416G3600HC18ADC01 16gbs XMP
Video Card(s) HP GTX1650 super 4gb
Storage MZVLB256HBHQ-000H1 PM981a (256GB)/3TB HDD
Display(s) Nitro XF243Y Pbmiiprx
Case Rosewill CULLINAN
Power Supply Corsair 750w
Mouse Best Buy Insignia
Keyboard Best Buy Insignia
Software Win 10 pro
if your going to be pushing this setup hard you should add some fans to cool the boards chipset and power phases. 1.5v is about as high as you should take that chip. if i had the other parts of the board cooled really well then i would probably run 1.55v as max. this is assuming the temps really are floating around 130F. something else to consider is the board you are trying to oc on is about 10 years old and pc components do break down. keeping the setup as cool as possible is a must.
good luck and keep us posted. its always interesting to see how far people can push these setups.
1,150 (0.47/day)
Upstate NY
Mouse gaming mouse
Keyboard Dell
Yes sir! All good we are talking in degrees F.
And yes, currently stuck with my vcore @ 1.512 if I want to keep this O/C stable. I don't want to go back down to 1.4v I have lots of core 2 quad chips they are plentiful and cheap so it's not the end of the world if I pop this one. That being said, I don't think harm will come to this CPU so long as I keep it cool. Like F_F said lots of fans are a must. I have a small fan on VRMs and another fan on my NB. Another 120mm exhaust fan as well. Other overclock specifications include:
AI tuner set to manual
9.0 clock multiplier
502Mhz FSB
FSB Strap = 400
DRAM RATIO
1.5125 vcore
DRAM set to 1.68v
NB set to 1.4v
SB set to 1.4v (seemed to help stability but maybe not required?)
LLC set to enable
New OC with 502 Mhz FSB:
3,030 (0.83/day)
502Mhz FSB
FSB Strap = 400
DRAM RATIO
1.5125 vcore
DRAM set to 1.68v
NB set to 1.4v
LLC set to enable
That is already a great overclock for a air cooled core 2 quad cpu.
I have also got some great oc results on air, but that is on x58 cpu's. My current i7 980x can go to 4.75 ghz at 1.55 volt air cooled.
Keep us updated as you progress your oc.
1,150 (0.47/day)
Upstate NY
Mouse gaming mouse
Keyboard Dell
Overclock is not 100% stable yet. I'm having trouble with a couple benchmarks within the AIDA64 Suite. I've been playing around with the FSB strap. Someone explained this as gears in a transmission but I'm still having trouble defining it in my own overclocks. Don't know exactly what to do with it short of it not being able to post at the 266Mhz strap. I am currently set to 333mhz strap which brought my memory speed down to 754Mhz, although we are still getting pretty good bandwidth in the memory department:
1,933 (0.61/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
To be more exact : "Strap" determines what Performance Level you can run. Lower is better (because it's kinda like timing).
With lower strap, you can try lowering your AI Transaction Booster value (ie. Performance Level).
Also, is tRAS at 25 really needed for ~1500MHz frequency ?
911 (0.38/day)
Al Balqa', Jordan
Processor AMD Ryzen 5 2600 (Covered with Cooler Master MasterGel Pro)
Motherboard ASRock B450 Steel Legend, BIOS Version: 10.31 [Beta]
Cooling Cooler Master MasterLiquid ML120L V2 RGB, 5x Galax Vortex Wind-02 (3x Front Intake + 2x Top exhaust)
Memory Kingston FURY Beast RGB 3600 MT/s 32 GB (4x 8GB), (KF436C17BBA/8)
Video Card(s) Palit GeForce GTX 1660 Ti Dual OC
Storage Kingston NV2 1 TB
Display(s) MSI PRO M251 (HDMI), Running @104 Hz
Case Cooler Master MasterBox MB520
Audio Device(s) HP H360G USB
Power Supply Cooler Master MWE 550 80+ White
Mouse HP G200 Black
Keyboard Redragon MITRA K551-1 RGB
Software Windows 11 Home
OP , why don't u give the Pentium dual core E6500K a shot? , it's unlocked.
1,150 (0.47/day)
Upstate NY
Mouse gaming mouse
Keyboard Dell
The Wolfdale chips have been done before... I've run and benched the E7500 (although it's locked). Plus, the E6500 only has 2MB Level 2 cache.
Agent 007, I am currently not using the AI Transaction Booster at all. It's just left alone in the BIOS.
1,933 (0.61/day)
System Name BOX
Keyboard HP KB-9970
Auto setting, ok.
Like I said, you MAY be able to go lower.
However, with 4x DIMMs, it might not be possible (or stable at your current NB Voltage).
1,150 (0.47/day)
Upstate NY
Mouse gaming mouse
Keyboard Dell
What do you recommend for TRAS @ 1500Mhz ? Please explain a little bit more here.
Also note we only have two DIMMS not four. NB voltage bumped up to 1.46 for this one (and a bump in CPU core as well)
1,933 (0.61/day)
System Name BOX
Keyboard HP KB-9970
Oh, that's good (two sticks) :)
tRAS is usually around 24 or less for 1600MHz. I don't see why you would increase it unless system wasn't stable...
Sure it's fractions of percent difference, BUT it's still something.
I would try 18, if unstable 21 if stable trying 20.
24 value should be stable regardless.
202 (0.04/day)
Tottenham ON
System Name Current
Processor i7 12700k
Motherboard Asus Prime Z690-A
Cooling Noctua NHD15s
Memory 32GB G.Skill
Video Card(s) GTX 1070Ti
Storage WD SN-850 2TB
Display(s) LG Ultragear 27GL850-B
Case Fractal Meshify 2 Compact
Power Supply Seasonic 1000W Titanium
Only managed 3.65GHz on my q9550, although stable from day 1 and still in use. 5GHz and stable, even on a faster model, seems like quite a reach.
Mine was a C1 not the E0 stepping though.
1,150 (0.47/day)
Upstate NY
Mouse gaming mouse
Keyboard Dell
Here we are approaching the 4.6Ghz barrier.... (will fix memory timings on my next reboot) - System appears to be stable with the NB bump to 1.46 as noted above.
3,629 (0.50/day)
System Name TheReactor / HTPC
Processor AMD 7800x3d 5050Mhz / Intel 10700kf (5.1ghz All Core)
Motherboard ASrock x670e Taichi / ROG Strix z490-e gaming
Cooling HeatKiller VI CPU/GPU Block -2xBlackIce GTX 360 Radiators - Swiftech MCP655 Pump
Memory 32GB G.Skill 6000Mhz DDR5 / 32GB G.Skill 3400Mhz DDR4
Video Card(s) Nvidia 3090ti / Nvidia 2080ti
Storage Crucial T700 2TB Gen 5 / Samsung Evo 2Tb
Display(s) Acer Predator xb271hu - 2560x1440 @144hz
Case Corsiar 550
Audio Device(s) on board
Power Supply Antec Quattro 1000W
Keyboard Corsair Gaming k70
On Socket 775 500FSB+ is really hard to get without Liquid Nitrogen. A cheaper route would be to get a QX with unlocked multiplier.
1,042 (0.33/day)
Pristina
System Name My PC
Processor 4670K@4.4GHz
Motherboard Gryphon Z87
Cooling CM 212
Memory 2x8GB+2x4GB @2400GHz
Display(s) HP envy 32 1440p
Case CM Mastercase 5
Audio Device(s) Sbz ZXR
Power Supply Antec 620W
Mouse G502
Keyboard G910
Software Win 10 pro
I think it's a good hoby if this makes you happy so enjoy experimenting with vintage cpu :)
911 (0.38/day)
Al Balqa', Jordan
Mouse HP G200 Black
1,150 (0.47/day)
Upstate NY
Mouse gaming mouse
Keyboard Dell
What was the highest frequency u reached with the E7500? I'm using the E7600.:)
I reached somewhere around 4.5Ghz don't recall exactly what I hit. I actually have an E7500 inbound with different stepping for perhaps better results.
1,933 (0.61/day)
System Name BOX
Keyboard HP KB-9970
911 (0.38/day)
Al Balqa', Jordan
Mouse HP G200 Black
I can reach 4.0 GHz with my shitty board but with decreasing the memory frequency , which gives so much stuttering in games.
1,150 (0.47/day)
Upstate NY
Mouse gaming mouse
Keyboard Dell
And highest clock speed CPUZ validation... I think I will settle for this. Daily use probably dial it back to 4.5Ghz.
You are kinda sending the thread off topic. Also please keep your language PG rated. Thanks!
1,150 (0.47/day)
Upstate NY
Mouse gaming mouse
Keyboard Dell
So I dialed it back to 4.5Ghz for the time being and I'm happy with the result.
Specs include:
Thermalright Ultra 120mm extreme cooler
Thermaltake TR2 550W PSU
Intel DC 3500 80GB SSD
Asus P5Q3 motherboard
G.Skill Ripjaws 8GB memory kit (DDR3 1600 CL7)
1,150 (0.47/day)
Upstate NY
Mouse gaming mouse
Keyboard Dell
Well, I'm back at it.
CPU multi down to 8.0 and FSB up to 510... so far so good. Will post some screenshots up later.
