Lightkeeper25
- Jan 7, 2024
- 3 (0.01/day)
Hello. I'd like to kindly ask for help with choosing motherboard that would support this control panel: https://www.moddiy.com/products/5.25-Inch-All-in-One-Card-Reader-LCD-Fan-Controller.html. My CPU will be i5-12500 so LGA1700 socket. I understand this control panel is mostly obsolete so not everything will be connect-able on modern motherboard, but I would like to request advice for which internal connectors (or which adapters, if they exist) should I look out for to be able to connect as much things as possible (aside from power itself, I would mostly like to connect the USBs and the fan controllers + the audio). I also found image with the similar control panel's connectors, attaching below. Thank you very much in advance for any advice!
