Need help cooling my laptop
69 (0.04/day)
System Name Dell Latitude 7490
Processor I7-8650U
Motherboard 0KP0FT
Memory 16GB RAM
Video Card(s) Intel UHD Graphics 620
Yesterday my nt-h1 has arrived and I immediately repaste my laptop but it seems like the temps have no differences after all. The previous thermal paste was mx-4.
You can see the pic above that most of the internal components like vrms, ram and the others are left uncooled. I was planning to put thermal pads on my laptop and put it on vrm and ram connecting to the heatsink pipe or should I just make the thermal pads reach the metal back of the laptop's case so it'll move the heat to the case. What do you guys think?
anyone?
1,150 (0.46/day)
Upstate NY
System Name Dual Socket HP z820 Workstation
Processor Twin Intel Xeon E5 2673 v2 OEM processors (thats a total of 16C/32T)
Motherboard HP Dual Socket Motherboard
Cooling Stock HP liquid cooling
Memory 64GB Registered ECC memory kit (octal channel memory on this rig)
Video Card(s) MSI RX 5700 XT Gaming X 8GB
Storage 2 x 512GB SSD in raid 0
Display(s) Acer 23" 75Hz Gaming monitors 1080P x2
Case Brushed Aluminium
Audio Device(s) Integrated (5.1)
Power Supply HP 1125W Stock PSU
Mouse gaming mouse
Keyboard Dell
Unless you are in a very hot climate or into serious overclocking, you should be able to leave the RAM and VRMs as they are right now. Is the rig overheating on you?
You may be able to undervolt your CPU using throttlestop, if you have an intel based system and unlocked processor.
Another factor to mitigate heat would be to run an external cooler underneath the laptop to get better airflow and the heat out.
825 (0.43/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
The VRM and RAM will be fine without any changes, for the CPU, a cooling pad underneath the laptop is a easy option. Also you can check if the vents on the outer case for air intake is limiting the airflow, I once had a laptop with poor vent design so I cut that area into a hole to allow maximum airflow into the fan and the temperatures dropped about 10 degrees.
69 (0.04/day)
Processor I7-8650U
Motherboard 0KP0FT
Memory 16GB RAM
I've undervolted the cpu already, I managed to do -200mv on core and -100mv on cache and yet the temps arent improving but only the performances.
I had a cheap cooler but in the end it doesn't help the airflow as much as I expected.
That may be one of the problems since there's no cooling on those components so I thought that putting thermal pads on it can transfer the heat.
I would do that too but for now the laptop is still in warranty so I might need to take some precautions.
36 (0.02/day)
System Name Hp Omen 15 2019
Processor i7-9750H
Motherboard Intel Cannon Point HM370, Intel Coffee Lake-H
Cooling HP THERMAL MODULE N18E G2
Memory SK hynix HMA81GS6JJR8N-VK x2
Video Card(s) nVIDIA GeForce RTX 2070 with Max-Q Design (HP)
Storage Intel Optane H10
Display(s) AUO82ED
Audio Device(s) SPDIF Interface (FiiO USB DAC-E10)
Power Supply 200w
IMHO, If it's already giving you a headache, and you have the chance to return it, do it. It's not worth to fix a brand new laptop or any product.
69 (0.04/day)
Processor I7-8650U
Motherboard 0KP0FT
Memory 16GB RAM
It's not giving me any headache at all, I just wanted to maximize it's potential.
2,098 (0.52/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
What temps are we talking about?
in idle and under load?
69 (0.04/day)
Processor I7-8650U
Motherboard 0KP0FT
Memory 16GB RAM
Both. The idle temps used to reach 40c but then after a year it can get as low as 46c while the under load reaches up to 90c when playing.
785 (0.22/day)
System Name Fat NCASE
Processor Ryzen R9 3900X
Motherboard ASUS TUF GAMING B550M ZAKU (WIFI) Edition
Cooling Scythe Fuma with 3 SCYTHE Wondersnail 2400RPM + Arctic MX2
Memory Corsair Vengeance 128GB @3200Mhz Cl16 (32GB X 4)
Video Card(s) Palit RTX 3060 StormX ITX 12GB
Storage MX500 4TB SATA + Toshiba MG08 16TB HDD
Display(s) LG 27UL500 4K monitor
Case Jonsbo W2 black
Audio Device(s) Onboard realtek 1200 & Soundblaster G3 usb
Power Supply ASUS ROG STRIX 850W Gundam Edition
Mouse Elecom wireless mouse :)
Keyboard RK100 Royal Kludge
Software Windows 10 HOME
Benchmark Scores Don't know any benchmark. It runs good enough for me.
For laptop this is actually quite the norm to be that hot given the constrain of laptop cooling. As long as you are NOT throttling or it NOT passed shutdown temperature it is good enough.
If you laptop have a metal base that is great. With thick enough thermal pad you can turn it into a heatsink. It would give you a massive cooling boost even plastic bases laptop like mine with this mod give great cooling. Only down side the base is hot and could no longer be a "laptop" on your lap.
The other thing you can do is cut a hole for fan intake replacing with a tiny metal grill for maximum cooling though this mod would void warranty.
69 (0.04/day)
Processor I7-8650U
Motherboard 0KP0FT
Memory 16GB RAM
That's what I've been planning for but what if I connect the thermal pads with the heatpipes instead of using the metal back cover?
18,584 (2.66/day)
System Name AlderLake
I would also add another ram stick so you get dual channel memory for better performance. :)
2,098 (0.52/day)
Wouldn't modifying it in any way make you loose your warranty on it?
1,150 (0.46/day)
Upstate NY
Mouse gaming mouse
Keyboard Dell
Are you saying that after lowering your core voltage, you are seeing better performance?
Adjusting the core voltage will not effect performance of your machine (until you reach the margins on both sides) so it must be something else that's contributing factor to the better performance. At least if I understand you correctly.
Not sure, but if it does I can easily remove it after.
What are your expectations with this cooling upgrade? As in goals? Laptops naturally run hot, it's just a fact of life when you cram a computer in a confined space. I don't want to bash your expectations but do keep them in check. In all likelihood, you wont see much of an improvement in temps, no matter what you do. Occasionally, you can seek out a better OEM heatsink/cpu cooler from a higher end / newer laptop and retrofit in your machine. I know people used to do this with the Lenovo T61s and it does make a world of difference. Just not sure if there is anything to upgrade to with your model.
69 (0.04/day)
Processor I7-8650U
Motherboard 0KP0FT
Memory 16GB RAM
Yeah, undervolting usually lowers the voltage and most laptops usually have power limit on how much power you can draw to them depends on the manufacturers to prevent laptops from overheating yet they make the performances limited by limiting the power draw. With that, making the cpu almost impossible to run at it's full potential.
The expectations aren't much but I feel like theres more room to improve the temperatures on the laptop as right now I can't afford to buy a new one.
2,098 (0.52/day)
1,150 (0.46/day)
Upstate NY
Mouse gaming mouse
Keyboard Dell
lol devon68 your avatar is pretty funny... that's hilarious!
@TheTigerJunior
What CPU are you running in this laptop? Have you confirmed higher performance with benchmarks? If so, I'd like to see them.
EDIT: are you not seeing advertised clock speeds with your laptop? Is it thermal throttling under heavy load?
69 (0.04/day)
Processor I7-8650U
Motherboard 0KP0FT
Memory 16GB RAM
Yes, the cpu is designed to run at 3.9 ghz all 4 cores but it gets throttled during heavy load due to the power limitation. Luckily, I can use throttlestop to adjust the Turbo Power Limit to remove the limitation but it gets thermal throttle.
I7-8650U. Usually the cpu runs at 2.2 ghz when drawing 15 watt and then after I undervolted it can reach 2.6 Ghz.Unfortunately, I haven't benchmarked it yet.
edit : just realised the clockspeed got lower it used to be 2.8 ghz undervolted. do my performances degrade over time?
unclewebb
8,156 (1.33/day)
it used to be 2.8 GHz undervolted
Double check and make sure your undervolt is still being applied. Many laptops have had automatic BIOS updates applied during the last year. This has disabled CPU voltage control.
69 (0.04/day)
Processor I7-8650U
Motherboard 0KP0FT
Memory 16GB RAM
Still applied with the same undervolt but different clockspeed
69 (0.04/day)
Processor I7-8650U
Motherboard 0KP0FT
Memory 16GB RAM
I knew the internal components are heating inside the laptop. After putting the thermal pads it only works when the metal case of the laptop is cold and it reaches back to normal temps when gaming but then I put ice pack below it and the idle temps are much colder than before.
edit : sadly, the ice pack could only last for few hours. i might need to think of a new way to cool down the vrm
