Need help flashing bios
Draver
21 (0.01/day)
Hello, I’ve got a bricked a rx 570 and a ch341a spi flasher ,and I can select my backup bios and write it to the chip but it won’t really program it.after “programming” it still remains the same bios in the chip .What could I do ? Thanks.
42,936 (6.71/day)
10,885 (1.56/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
What is the card make/model? Does it have dual bios?
42,936 (6.71/day)
10,885 (1.56/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
Thanks, I don't see dual BIOS. I'm wondering about flashing it while the card is in the slot and the PC is on, using IGPU.
Draver
21 (0.01/day)
That doesn’t work ,that’s why I bought the external flasher , btw weird thing I found out while I was testing the ch341a flasher with a voltage meter and it was showing on pin 8 and 7 about 7v and 5v on rest of the pins (without 4 (4 is ground)) and i was wondering if that’s why I get those weird readings. Also it is dual bios ,but still wouldn’t work if switched.
11 (0.01/day)
System Name old baby
Processor E5 2640V3
Motherboard huananzhi x99-TF
Cooling snowman 4 tube
Memory 1866 Mhz 4x4 corsair по 16$ за штуку 4 channel
Video Card(s) r9 fury asus strix anlock
Storage m2 240gb Tlc . ssd sata 480gb tlc . hdd 5400 500 gb
Display(s) acer 144 Hz VA
Case Cougar MX350 Mesh-X
Audio Device(s) a4tech g500
Power Supply CoolerMaster MWE Bronze 700W
Mouse a4tech q51
Keyboard за 5 $
Software win 10 корпоративная
[QUOTE = "Дравер, должность: 4199688, участник: 193779"]
Здравствуйте, у меня есть кирпич RX 570 и sp34 флеш-накопитель ch341a, и я могу выбрать свой резервный BIOS и записать его в чип, но он на самом деле не запрограммирует его. После «программирования» он все равно остается тем же самым в чип. Что я мог сделать? Благодарю.
[ATTACH = полный] 143677 [/ ATTACH]
[/ QUOTE] вставь другую видеокарту затычку в слот №1, а в №2 свою rx 570. на ней замкни 1 й и 8 мой контакт микросхемы bios (контакты находятся по бокам от ключа . спереди. сам ключ это небольшое углубление на микросхеме - дырочка ) . Затем запускай компьютер . как запуститься windows разомкни контакт на микросхеме. затем шей . прошивай программой Ati WinFlash.
42,936 (6.71/day)
English please
866 (0.23/day)
Processor ryzen 5 5600x
Motherboard AB350m Pro4
Cooling custom loop
Memory TEAMGROUP T-Force TXKD416G3600HC18ADC01 16gbs XMP
Video Card(s) HP GTX1650 super 4gb
Storage MZVLB256HBHQ-000H1 PM981a (256GB)/3TB HDD
Display(s) Nitro XF243Y Pbmiiprx
Case Rosewill CULLINAN
Power Supply Corsair 750w
Mouse Best Buy Insignia
Keyboard Best Buy Insignia
Software Win 10 pro
try this software instead:
run "driver-- 24CXX25XX.EXE" to install the driver for that reader before running the application.
set the fields on the left like in the image. this is assuming your rom is 256KBytes or smaller.
also, what is the size of the rom you are trying to flash. please also post a picture of your reader. its easy to set the wiring up wrong.
  • CH341A.zip
10,885 (1.56/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
I rescued a motherboard with a flashcat SPI, but it would only work when the board was powered on. Something to do with resistive losses, and it was support at Flashcat that recommenced that me. Ergo, why I suggested it... putting the flasher on the card and power up the card in a PC before trying to flash it.
Draver
21 (0.01/day)
The size of the rom I want to flash is 256KB
The bios chip is a GD25Q20CT,and here are the pictures
I didn’t try that yet since I was afraid I could mess up the gpu even more , but why not , I also have some old gpus lying around with compatible chips for the spi , weird thing they do the same they can only be read if I click like 5 times on the read button no matter the software I’m using (as programmer works the best since it has more compatible chips) (also while trying this with 2 other gpus result is quite the same I can read them ,then it shows me some gibberish but it doesn’t say “Nvidia” or “Advanced Micro Devices” just some random hex stuff.
866 (0.23/day)
Cooling custom loop
Software Win 10 pro
your cable is on wrong.
should look like this:
10,885 (1.56/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
I had the same problem flashing a motherboard. It would work one time, then 5 or 10 other times it simply wouldn't. Flakey as hell.
42,936 (6.71/day)
Might be on wrong chip
10,885 (1.56/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
It's hard to mix up an 8 pin SPI chip. Even on a motherboard loaded with IC's, you couldn't miss it.
Edit, I take that back:
Draver
21 (0.01/day)
I’m pretty sure I used the correct one,the one at the bottom since the other bios chip (on the backplate) is right under this one ( underneath the cooler) and it was very easy to spot.
42,936 (6.71/day)
Ask zettabit.lab or elitech or actually hardcore overclocking about it on youtube
866 (0.23/day)
Cooling custom loop
Software Win 10 pro
i believe the bios chip is on the back of the card. can i get a pick of the front of the card and back. if your camera can get a clear picture of the numbers on them i can look them up, ill also be able to tell if its the bios by the way its printed. also put your cable on the way i showed you. make sure you also have the jumper connected to the programmer as shown.
edit: saw your other thread, i need the numbers off of the circled chips. if i had to guess i would say the bios is the chip circled in green and red.
Draver
21 (0.01/day)
i believe the bios chip is on the back of the card. can i get a pick of the front of the card and back. also put your cable on the way i showed you. make sure you also have the jumper connected to the programmer as shown.
It has two bios chips , one on the front and one on the back and they’re the exact same model chips.It doesn’t matter which chip I try it on it doesn’t detect it if I put the cable the same as you and tried that with multiple gpu bios chips.
866 (0.23/day)
Cooling custom loop
Software Win 10 pro
this is your bios.
make sure the red stripped line is connecting to the side of the chip with the little indentation. also, those clips can be a pain in the ass to get right, you really need two make sure you hold the clip and apply a slight downward force on it to make good connection.
.jpg
