need help for asrock rx590 gme bios
33 (0.02/day)
thanks frist!
i got a asrock rx590 gem
gpu:215-0910066
memory:Samsung K4G80325FC
now it's bios is this one,like the photo follow
boost clock:1385 MHz
but it's unwork!
so i think the right bios is follow
boost clock:1413 MHz
bu i can't find it ,so anyone can help?
thanks again!
Hello.
Would you be so kind and make a photo from GPU-z main screen?
After that put it here.
Thanks
We do not need the clock freq.
We need the exact device ID and sub ID
After i checked your BIOS i can confirm that you have a modded BIOS for mining. At the moment i am still searching for the right BIOS for your card.
Until now what i found is :
A short guide how to flash the card :
Take your time mate.
Keep us informed.
this bios is unwork too。gpu clock and memory all 0
OK.
Please answer the following questions :
- your card was bought from a known source ? It was used for mining ?
- how do you know that you have Samsung K4G80325FC memory chips ? You opened the card ?
OK.
1,it is a normal card but it was used for mining。it isnt a only for mining card。
2,i m sure very much,I opened and looked it。
From my personal experience i could confirm that MOST but not all mining cards have some problems.
I mean in most cases the memory chips were abused so it is not a surprise when your card does not start or give a 43 error in windows.
Yes we try to flash the right BIOS in them but that does not solve the hardware problem.
That only correct the abnormal timings used for mining purposes.
