Need help for upgrade my PC
7 (0.01/day)
Hello everyone, I want to ask about upgrade my computer, I have been using it for about 2 years, never overclock or something like that and I want to upgrade it and I already have a plan to upgrade it and its:
CPU Intel® Core™ i7-13700K
RAM Acer Predator Pallas II Black DDR5 6000MHz 32GB (2x16GB)
Motherboard Gigabyte Z790 Eagle AX
I was planning to get these (above) but I would love to hear another recommendations, I really appreciate it. I use my computer to work sometimes like Photoshop and Illustrator, but mainly I want to upgrade to play games in 1080p like Black Myth: Wukong and FFXVI and some online multiplayer/gacha games. my budget is around 800$-1000$ (and I will sell the old parts too) thanks in advance!
Current specs:
CPU Intel® Core™ i5-9400f
Cooler be quiet Pure Rock 2
VGA AMD RX 6600 XT OC 8G Gigabyte
RAM 2x8GB V-GeN DDR4 Platinum
Motherboard Gigabyte H370M DS3H
PSU be quiet PURE POWER 11 600W CM - 80 Plus Gold
SSD Seagate 240GB, SSD 1TB 870 EVO Samsung, and 1TB HDD
Monitor 24" Gigabyte G24F 165Hz FHD
101 (0.08/day)
System Name Silicon Graphics O2
Processor R5000 / 180MHz
Cooling noisy fan
Memory 384 MB
Storage 4 GB
Case the one with the old logo and proud of it ;)
Software IRIX 6.5
PSU be quiet PURE POWER 11 600W CM - 80 Plus Gold)
Not an LGA-1700 expert, but running a K-series CPU on a 600W PSU seems a bit optimistic. You will also need a better CPU cooler, preferably a 240mm AIO.
Considering that the next generation (Arrow Lake) is around the corner, you might want to wait till early October, especially since 13th gen Intel CPUs will basically have no resale value in the future thanks to the quality issues of the 13th & 14th gen CPUs.
Alternatively, you could go for a R7 7800X3D and a similar priced B650(E) motherboard. You might be able to re-use your air cooler. However, depending on where you are living, it might be a bit more expensive than the i7. The difference between the CPUs in Photoshop and Illustrator should be minor, gaming will probably be faster on the X3D, especially in MMO-type of games.
7 (0.01/day)
I forgot that 13th and 14th have instability issues, thank you for reminding me of that.
R7 7800X3D and B650(E) alternatively is a good option for now and the price just a little expensive but it’s ok, the budget around 800-1000$ now (I think 800$ kinda tight for upgrade this one) but we’ll see the other option
thank you!
dgianstefani
TPU Proofreader
4,791 (1.97/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Motherboard ASUS ROG Strix X670E-I, chipset fans removed
Cooling Optimus Block, HWLABS Copper 240/40 + 240/30, D5/Res, 4x Noctua A12x25, 2x A4x10, Mayhems Ultra Pure
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front panel pump/res combo
Audio Device(s) Audeze Maxwell Ultraviolet, Razer Nommo Pro
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Keyboard Wooting 60HE+, TOFU-R CNC Alu/Brass, SS Prismcaps W, Jellykey, Lube/Mod, TLabs Leath/Suede Wristrest
Software Windows 10 IoT Enterprise LTSC 19044.4046
Benchmark Scores Legendary
Wait for Arrow Lake, or dump your entire budget into 4070 Ti Super. Both are good options.
Getting 2*16 GB RAM and a 9700 later is a good idea too.
Your GPU is too weak to focus on a platform upgrade.
1,814 (1.39/day)
Alaska USA
PCPartPicker Part List
CPU: *Intel Core i7-13700 2.1 GHz 16-Core Processor ($319.99 @ Amazon)
CPU Cooler: *Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler ($35.90 @ Amazon)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard ($145.26 @ Amazon)
Memory: *Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($90.97 @ Amazon)
Power Supply: *Thermaltake Toughpower GF A3 - TT Premium Edition 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($85.99 @ Amazon)
Total: $678.11
Prices include shipping, taxes, and discounts when available
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2024-08-26 20:26 EDT-0400
CPU: *AMD Ryzen 7 7700 3.6 GHz 8-Core Processor ($280.00 @ Amazon)
Motherboard: *MSI PRO B650-S WIFI ATX AM5 Motherboard ($139.99 @ MSI)
Total: $632.85
Generated by PCPartPicker 2024-08-26 20:30 EDT-0400
