- Jan 12, 2020
- 5 (0.00/day)
- Sri Lanka
Processor | Core i5 3470 @ 3.2Ghz |
Motherboard | Asrock B75M-GL |
Cooling | CM H212 |
Memory | TeamGroup 8GB @ 1600Mhz DDR3 |
Video Card(s) | Gigabyte RX 570 Gaming 4G |
Storage | 128GB Kingston SSD + Hitachi 1TB HDD |
Display(s) | 24" 1080p TV |
Case | Custom Mod |
Audio Device(s) | Onboard Audio |
Power Supply | Ultron VP500s |
A year ago i bought a Gigabyte RX 570 Gaming 4G card. It's paired with an Intel i5 3470 + Asrock B75M-GL + 8GB @ 1600Mhz RAM + A crappy PSU named Ultron VP500s 500W. When i'm on 19.10.2 driver i faced this problem once while i'm using MEMU Android Emulator. After Restarting PC then its gone. Recently I installed 19.12.2 v2020 drivers i played Sniper Contracts, Forza Horizon 4, MAFIA 3 @ High Settings without an issue. But sometimes when i'm working on the emulator screen goes off & Fans ramped up to 100%. But coz it didn't appear when gaming i didn't care it
3 Days ago same thing happen. Then i updated the bios via Gigabyte Flash from F4 to F6. But problem remained same. Now it is randomly off the screen and fans ramping 100% even without opening a game or whatever gpu intensive. All i have to do is disconnect the from the wall. Then When I turn ON the computer again Black screen appears & Fans 100% even without getting into bios. I google the issue & found on the linustechtips forum that a person with rx 480 got the same problem & after he replaced the thermal paste on the gpu problem solved. Then i replaced the thermal paste twice yesterday & problem remained stil.
Today Morning i turn on the computer and it loads into the Windows
Then I quickly download the FurMark GPU Stress test and installed it. Then error appeared & i turned off the pc. Then after few hours it turn it on & Run FurMark to if there's an thermal throttling or VRM Heating issue. Test completed with 100% utilization all the time & Reached 60 °C. i can't understand WTF is happening. Then i uninstalled the v19.12.2 driver & try to install v19.10.2 error appears again.
Sum
HELP!!!!
![Frown :( :(](https://tpucdn.com/forums/data/assets/smilies/frown-v1.gif)
![Smile :) :)](https://tpucdn.com/forums/data/assets/smilies/smile-v1.gif)
Sum
- GPU : Gigabyte RX 570 4GB Gaming
- Error : Turn OFF the screen & Fans spinning @ 100% speed
- Replaced the thermal paste twice
- No thermal throttling ( Furmark Confirmed it)
- Updated the GPU BIOS & Reset Motherboard BIOS
- Tried using a different PCI-E Slot
- issue Randomly appearing without a gpu intensive task
- when turn off from the wall after issue appeared and if immediately try to turn on the issue appear right in the moment even without loading BIOS
- Uninstalled v19.12.2 driver & Error appears when v19.10.2 installing
HELP!!!!
