Need help on how to setup correctly fan speed
Nicolanapa
2 (0.00/day)
I have just recently built my first PC but my parents are giving me problems about the fans loudness so I want to lower their speed without affecting much temperatures. The images I uploaded shows the fan configurations, they're a bit outdated since I u tried lowering a bit the general speed. In sys_fan1 there's 6 fans (5 P12 PWM, 1 stock 4000d airflow fan) connected to a fan hub and two CPU fans (Thermalright Phantom Spirit 120 SE ) in the cooler. I'm giving more informations if it can help. Have a 7800x3d and sapphire 7800 xt. The currently average temperature are about 30C but haven't monitored constantly the temperatures while gaming but I've seen the graphics card getting to 59 degrees in heavy load
631 (0.60/day)
Processor AMD Ryzen 7 5800X3D
Cooling Custom Watercooling
Display(s) Samsung G7 27" x2
Mouse Logitech G903
Keyboard Steelseries Apex Pro
The fan speed is usually controlled by the CPU temperature, not the GPU. I have seen some motherboards that let you chose the source though.
You could probably remove some fans, just have more fans pushing air in than out of the chassis.
You can let the fans run at a low rpm for more degrees. Start ramping up at 40C instead of 20C for example. Then have a steeper ramp up. And there is no point setting them to 100% at 60C. You can put that at 90-95C or even never go higher than 80-90% fan speed. Temps will get worse, but monitor them and see if they are still within the acceptable range. Experiment some with different settings. Find out at what percentage the fans get annoying and try to stay below that, even at higher temperature
179 (0.11/day)
System Name The New, Improved, Vicious, Stable, Silent Gaming Space Heater
Motherboard MSI B450 Tomahawk Max
Cooling be quiet! DRP4 (w/ added SilentWings3 120mm), 4x Noctua A14x25G2 (3 @ front, 1 @ back)
Memory Teamgroup DDR4 3600 16GBx2 @18-22-22-22-42 -> 18-20-20-20-40
Video Card(s) PowerColor RX7900XTX HellHound
Storage ADATA SX8200Pro 1TB, Crucial P3+ 4TB (w/riser, @Gen2x4), Seagate 3+1TB HDD, Micron 5300 7.68TB SATA
Display(s) Gigabyte M27U @4K150Hz, AOC 24G2 @1080p144Hz vertical, ASUS VP228H@1080p60Hz vertical/ double4Kwhen?
Case Phanteks P600S
Audio Device(s) Creative Katana V2X gaming soundbar
Power Supply Seasonic Vertex GX-1200 (ATX3.0 compliant)
Mouse Razer Deathadder V3 wired
Keyboard Keychron Q6Max w/ Gateron G Pro 3.0 Black linear switches
Blasting 100% early on is not necessarily a wrong way to setup fans. It will bring a very minor performance boost. But if the main concern is noise...
I would test out "What is the highest level of that specific set of fans I can set without bothering me / the user?"
Say, it's 60%.
I would then limit the fan speed to 60% until the CPU is really overheating. On the 7800X3D, if I remember correctly it will be fine <90C.
Note that normally the fan speed settings in BIOS cannot do anything about GPU temperature.
For your graphics card, assuming you haven't done anything to bump up the fan speed, 59C is very good and there's nothing to worry about.
661 (0.31/day)
Denmark - Aarhus
System Name Iglo
Processor 5800X3D
Motherboard TUF GAMING B550-PLUS WIFI II
Memory 32 gigs - 3600hz
Video Card(s) EVGA GeForce GTX 1080 SC2 GAMING
Storage NvmE x2 + SSD + spinning rust
Display(s) BenQ XL2420Z - lenovo both 27" and 1080p 144/60
Case Fractal Design Meshify C TG Black
Audio Device(s) Logitech Z-2300 2.1 200w Speaker /w 8 inch subwoofer
Power Supply Seasonic Prime Ultra Platinum 550w
Mouse Logitech G900
Keyboard Corsair k100 Air Wireless RGB Cherry MX
Software win 10
Benchmark Scores Super-PI 1M T: 7,993 s :CinebR20: 5755 point GeekB: 2097 S-11398-M 3D :TS 7674/12260
Welcome to TP, this is the one of the right places to ask those sort of questions.
Best way usually to set fan speeds are via the Bios.
Are you confident enough to try editing it?.
Or you just wanna go the way windows programs let you deside stuff ?.
825 (0.44/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
Just do stress tests and monitor the temperatures, I would limit the max speed to 80% if they are too loud
6,130 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Use FanControl:
59C on GPU while gaming is nothing.
Based on your BIOS photos:
1st curve does nothing, SYS Temperature won't reach 60C, it will probably move in the range of 1-2C
2nd and 3rd curve should be replaced with 2nd curve only and both fans connected through Y splitter to the CPU Fan header. CPU OPT is pretty much dedicated to pumps for AIOs. If you have matching fans on the CPU cooler it would make sense to run them with matching speeds.
Meanwhile FanControl will let you setup triggers based on GPU temps, deltas, etc. I setup mine so that CPU fan runs at 70% up until 50C on the CPU then auto ramp to max of 100% at 65C (but that's with SilentWing fan on the DR4). Front and rear fans are set to 32%/70% if GPU is below 65C, when it crosses that point they go up to 50%/100% and once it cools to 40C they go back to original speeds.
2,965 (2.06/day)
Germany
Case Streacom BC1 V2 Black
VR HMD Oculus Rift S
Software ~2000 Video Games
go into your bios. set the highest static fan speed that does not bother you. F10 and you're golden.
229 (0.10/day)
Processor Intel i5-13600KF
Motherboard ASRock Z790 PG Lightning
Cooling NZXT Kraken 240
Memory Corsair Vengeance DDR5 6400
Video Card(s) XFX RX 7800 XT
Storage Samsung 990 Pro 2 TB + Samsung 860 EVO 1TB
Display(s) Dell S2721DGF 165Hz
Case Fractal Meshify C
Power Supply Seasonic Focus 750
Mouse Logitech G502 HERO
Keyboard Logitech G512
average temperature are about 30C...graphics card getting to 59 degrees in heavy load
Those temps are fine. Maybe lower fan speed until temps are an issue? Sometimes many fans can work against each other creating turbulence. Getting the right number of fans in the right place at the right speed can be tricky. Populating every available fan mount and running full blast isn't the best plan.
I also vote for using the software called Fan Control:
One thing you can do is adjust curves in you OS while you are gaming so you can see how it sounds in real world use, then taking pictures of those fan curves and duplicating them in your BIOS. As Chomiq said, the another thing is to use Fan Control to link fans to your GPU's temp.
