Need help undervolting/Overclocking Ref RX 6900 Xt
sidthree16
1 (0.00/day)
Hello all,
Recently I managed to get reference version of rx 6900xt. I was watching few videos online and reading some comments here and there where some people have managed to undervolt this gpu to insane level (something like 1080 mv UV, 2500/2600 MHz OC). I am trying to do exact same but my gpu keep crashing and giving me error during 3d mark timespy benchmark. After few trial and error I managed to change my unvervolt to 1155, clock freq. to 2349-2249, power draw to 15% but now when I do timespy benchmark my junc temp is hitting 100C and current temp goes around 80C. I would really appritiate your guys help if I can start undervolting and lowering these temps (I am noob to undervolting/overclocking).
Here is the picture of my current setting in AMD software
My specs are:
AMD 5600x CPU
32 GB 3200 MHz memory
rx 6900xt
Thanks
1,679 (0.87/day)
Processor 7800X3D 2x16GB CO
Motherboard Asrock B650m HDV
Cooling Peerless Assassin SE
Memory 2x16GB DR A-die@6000c30 tuned
Video Card(s) Asus 4070 dual OC 2610@915mv
Storage WD blue 1TB nvme
Case Corsair D4000 Airflow
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Benchmark Scores Superposition 8k 5267 Aida64 58.5ns
Use afterburner and curve editor if it works on RDNA2. I had several problems with the AMD overclocking utility and undervolt with my 5700XT, afterburner worked like a charm.
2,891 (2.10/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
keep the card at it's stock clock and reduce the voltage only.
going above the stock clock will move the whole "V/F Curve" so far away that you actually can not undervolt.
reducing the clock and undervolt results in much worse performance and very quickly instability.
try stock at 1120-1130mv. (that should result in ~ 1081mv-1093mv under full load and around 30W of power savings + lower hotspot temps)
Edit:
100°C on the hotspot is "okay" especially in timespy.
913 (0.63/day)
System Name 1. Glasshouse 2. Odin OneEye
Processor 1. Ryzen 9 5900X (manual PBO) 2. Ryzen 9 7900X
Motherboard 1. MSI x570 Tomahawk wifi 2. Gigabyte Aorus Extreme 670E
Cooling 1. Noctua NH D15 Chromax Black 2. Custom Loop 3x360mm (60mm) rads & T30 fans/Aquacomputer NEXT w/b
Memory 1. G Skill Neo 16GBx4 (3600MHz 16/16/16/36) 2. Kingston Fury 16GBx2 DDR5 CL36
Video Card(s) 1. Asus Strix Vega 64 2. Powercolor Liquid Devil 7900XTX
Storage 1. Corsair Force MP600 (1TB) & Sabrent Rocket 4 (2TB) 2. Kingston 3000 (1TB) and Hynix p41 (2TB)
Display(s) 1. Samsung U28E590 10bit 4K@60Hz 2. LG C2 42 inch 10bit 4K@120Hz
Case 1. Corsair Crystal 570X White 2. Cooler Master HAF 700 EVO
Audio Device(s) 1. Creative Speakers 2. Built in LG monitor speakers
Power Supply 1. Corsair RM850x 2. Superflower Titanium 1600W
Mouse 1. Microsoft IntelliMouse Pro (grey) 2. Microsoft IntelliMouse Pro (black)
Keyboard Leopold High End Mechanical
Hello all,
My specs are:
AMD 5600x CPU
rx 6900xt
Thanks
Apparently a hotspot below 110C is okay for this card but personally you should be looking at trying to dial in 90C on the junction temp. Your power limit is unnecessarily high. I would start by reducing that to 0 and working up from there to see if there are any gains in pumping it. Otherwise you're just feeding heat into the card. Improve your fan curve to max at 80% when the card reaches 90C. I think the frequency setting is about right and what the card should be able to do. Needless to say if you have crashes you may need to adjust up the voltage.
