Need Help With Adobe Photoshop CS4 Error
sandiegoborn32
62 (0.01/day)
Somewhere in California...
System Name The Green Fox
Processor Intel Core i7 3770K @ 4.0GHz (100MHz x 40)
Motherboard Gigabyte Z68XP-UD3
Cooling XSPC RASA 750 RS360
Memory 16GB (4x4GB) of G.Skill Sniper Series DDR3 1600 Gaming Memory
Video Card(s) 2X Sapphire Radeon HD 6950s running in Crossfire
Storage Two 60GB OCZ Solid III SSDs in RAID 0, and Two Seagate Barracuda 7200 RPM HDDs (one 750GB drive, and
Display(s) 2X Sceptre X226W-1920 22" Monitors
Case Cooler Master HAF-X
Audio Device(s) ASUS Xonar Essence STX
Power Supply Sunbeam 750 Watt 80 Plus Power Supply
Software Windows 7 Home Premium 64 Bit SP1
Just recently did a system restore for my friend's photo editing PC. When I restarted the machine, I tried to fire up Adobe Photoshop CS4, and got this error message -
"AMT Subsystem Failure
This product has encountered a problem which requires that you restart your computer before it can be launched.
If you continue to see this message after restarting your computer, please contact either your IT administrator or Adobe technical support for help, and mention the error code shown at the bottom of this screen.
Error: 1
http://www.adobe.com/support/"
I restarted the machine and it still displays the error.
Any help will be most appreciated!
My friend's OS is Windows Vista Home Premium 32 Bit with Service Pack 2 installed.
His machines is Dell Dimension E521
Specs -
CPU - AMD Athlon 64 X2 Dual Core Processor 4400+ @2.30GHz
Memory - 2.0GB
GPU - ATI Radeon X1300 Pro 256MB GDDR2
4,966 (0.90/day)
System Name i7-PC / HTPC / iMac
Processor i7 3820 / Phenom II 940
Motherboard GIGABYTE G1.ASSASSIN2 / M3A79-T Deluxe
Cooling Corsair Hydro H100i / Scythe II (HS only)
Memory G.SKILL Trident X Series 8GB (2 x 4GB) DDR3 1600mhz / 4GB DDR2 1066 (@800) Corsair Dominator
Video Card(s) GB Radeon HD 7950s 3GB / GB Radeon HD 7950s 3GB
Storage 2x 80GB Intel X-25, 2x600gb SATA, 1x1tb 5400RPM storage /1x600GB, 3x500GB,1x160,1x120 SATA
Display(s) 1x 27" Yamakasi / Vizio 42" HDTV
Case Lian Li Lancool PC-K58 / Antec 900
Audio Device(s) HT Omega Striker 7.1 / Onboard and HDMI from ATi Card
Power Supply PC Power & Cooling 750W / 610W
Software Ubuntu / Windows 8.1 Pro / OS X / PHPStorm / Gaming
it most likely needs to be reinstalled.
adobe software is heavily pirated and in turn protected, i have had a system ghost
work with older versions, but any CS version i would venture to bet it will have to
be reinstalled.
of course i don't know for sure. but i have spent enough time trying to fix adobe
related problems to learn sometimes the easiest way is to just reinstall.
not very techie of me i know, but i have work to do ;)
sandiegoborn32
62 (0.01/day)
be reinstalled.
Thank you so much for your reply.
If I reinstall it for him, will I need to provide his product key again? If I do, then I'll need to search his computer for his product key that he had saved in a text document somewhere on his machine. If I don't need to re-enter the key when I reinstall the program, then please let me know, because that will save me the trouble of looking through all of his documents for that text document that contains his product key. Thanks again. :)
4,966 (0.90/day)
you can try reinstalling without uninstalling first, if that works it shouldn't require
the key again.
other than that,an uninstall/reinstall would require the key. there is a repair
process but you have to contact adobe support to do it. you'd probably have
to verify the key with them as well.
sandiegoborn32
62 (0.01/day)
the key again.
Okay thanks man! I'll try that and see what happens.
