Need help with an old AOC LED 22'' TV and a old Intel HD Graphics card resolution issue!!!
HighFrog
3 (0.00/day)
Hi guys.
I recently found an old laptop that my father used to have (i3-2nd generation with Intel HD 3000) so I try to connect the laptop via HDMI to an old AOC TV, the problem is that when I try to put the 1920x1080 resolution it looks ugly, the letters were ugly, it was blocky and fuzzy. This just happen with that resolution, bc when I change to 1680x1050, the colors return to the normal scale and the sharpness on the edges disappear at all.
My question is if there's a solution for this, like tweak the settings on the Intel software or something...
Thanks...
1,294 (0.17/day)
hi, what is the native resolution & refresh rate of this AOC ? (you can get the info in the on-screen display menu)
1,470 (0.21/day)
Processor Ryzen 1600AF @4.2Ghz 1.35v
Motherboard MSI B450M PRO-A-MAX
Cooling Deepcool Gammaxx L120t
Memory 16GB Team Group Dark Pro Sammy-B-die 3400mhz 14.15.14.30-1.4v
Video Card(s) XFX RX 5600 XT THICC II PRO
Storage 240GB Brave eagle SSD/ 2TB Seagate Barracuda
Display(s) Dell SE2719HR
Case MSI Mag Vampiric 011C AMD Ryzen Edition
Power Supply EVGA 600W 80+
Are you sure the TV is actually 1080p and not just 720p (HD ready) like a lot of older TV's were? Also older tft TV's don't look as good as actual computer monitors and you will find text blurred and see pixels/just get an overall poorer quality picture
9,800 (3.23/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
I had a TV that accepted 1080p but was in fact a 768p panel and it would look horrible. Probably the same with yours.
Rei
656 (0.38/day)
Guam
System Name 1 Desktop/2 Laptops/1 Netbook
Processor AMD Athon X2 64/Intel Pentium 997/Intel Pentium 4/Intel Atom
Motherboard EpoX ATX motherboard/Samsung/Toshiba/Lenovo
Cooling Stock
Memory 4 GB/4 GB/2 GB/2 GB
Video Card(s) Asus GeForce GTX 780 Ti/Intel HD Graphics/GeForce 4MX/Intel GMA
Storage 6+ TB Total
Display(s) HP Pavilion 14 Inch 1024x768@60Hz 4:3 Aspect Ratio CRT Monitor
Case None
Audio Device(s) Various
Power Supply Seasonic 500 Watt & VenomRX 500 Watt
Mouse Wayes Iron Man Wireless Mouse
Keyboard Rexus VR2 Wireless Keyboard
Software Win10 & WinXP SP3
Benchmark Scores It sucks...
Seems like some sort of incompatibility with the aspect ratio going on there between your GPU, connector & TV. You are trying to display a 16:9 aspect ratio while the image seems better with a 16:10 aspect ratio. What is your TV's native resolution & aspect ratio?
14,546 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Using the Laptop's display settings, Detect the external display and set to fit to screen and native resolution.
HighFrog
3 (0.00/day)
Hi guys, I was a little bit busy sorry for taking to long to answer.
I found this information on the user manual of the TV:
Also I found this information about resolutions if it's useful on something:
The TV model is the L22A1321
I was thinking a lot on that, bc it was a little bit cheap, but I'm curious about why the 1920x1080 resolution doesn't seems to work
I try to reach the TV setting to apply the "explorer mode" but doesn't seems to be active on the settings.
Rei
656 (0.38/day)
Guam
Cooling Stock
Storage 6+ TB Total
Case None
Your TV model is the middle chart with the 22 inch panel size right?
What about your laptop's native and/or max resolution as well as aspect ratio?
Also try out Caring1's solution.
HighFrog
3 (0.00/day)
Yeah is the middle chart, mmm I think the native and max resolution on the laptop is 1366 x 768 and the aspect is 16:9. The thing is that I connected the same laptop to a 45'' Smart TV, the resolution was on 1920x1080 and it was ok, I think is more a problem of the TV.
14,546 (3.79/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
Look through the input menu on the AOC TV and select PC if it has it otherwise HDMI will have to do.
As mentioned previously go through the display settings of the laptop and find the display layout settings and detect the second screen, you can also set the AOC as primary if you wish and it will detect settings for that screen.
