Need help with Asus X570-I strix motherboard
Swiftv
4 (0.00/day)
Hi, I have a asus x570-i itx motherboard. And I have a small problem with it. There was a little resistor that fell of the back and I saw it fall onto the carped but its too small for me to find it. So basically I need to know the value of that resistor, I suspect its a 59c resistor but I dont wana guess and make things worse. I looked online for pictures but I couldn't find any good ones. So my request is if someone with the same motherboard can take a look and tell me whats writen on top of the resistor or just take a picture. I have a picture in which I can almost read it but I dont want to be guessing. Thanks, your help will be greatly appreciated!
Also when I power it up the yellow qled comes on for dram issue. Which is probably caused by this resistor missing.
95Viper
Super Moderator
12,797 (2.22/day)
Just an FYI.
I don't have the motherboard... however, I lost an electrical part in the carpet... I got out the vac and sucked up the area.
Dug thru the mess and found it in the dust and dirt.
Swiftv
4 (0.00/day)
Just an FYI.
Thanks for the tip. I have thought of that but I didnt think I would be able to find it in the vacum cuz it so small.
95Viper
Super Moderator
12,797 (2.22/day)
Just gotta go slow and dig around... good luck, Swiftv.
Also, if it is under warranty... I would RMA it.
5,455 (1.03/day)
Gougeland (NZ)
System Name Cumquat 2021
I'm picking it will be the same resistor for all of the Strix f, e and i variants of the mobo
Swiftv
4 (0.00/day)
I looked at the other motherboard variants and I didnt see any similar circuit. If you know where to look or have a picture I would like to see it.
5,455 (1.03/day)
Gougeland (NZ)
Without pulling my Strix X570 F-Gaming out of my system I can't quite see that area but from what I've seen both the F and E variant has what you are looking for on the front side see pic bellow
Swiftv
4 (0.00/day)
I looked at it and the circuit is similar and probably is the same one but its layed out differently and I cant tell which resistor it is. If you know which one then do let me know. Thanks.
Got a picture. I think it says 822. So im going to get a resistor of that value and try jt out. Hopefully nothing blows up.
